Plex HW acceleration in LXC container - anyone with success?
Johnnyh1975Johnnyh1975 Posts: 33Members, Plex Pass, TunerTester Plex Pass
I am currently struggling to configure my lxc container for Plex as such that hw acceleration of my xeon e3-1275 v6 is recognized and used. Has anyone succeeded?
My base system is running Proxmox V5.1 with Linux kernel 4.13.13
«1
Comments
  • ChuckPAChuckPA Posts: 22,245Members, Plex Pass, Plex Ninja, Plex Team Member Plex Team Member
    I do not know proxmox but if proxmox supports udev, and the kernel presents /dev/dri as a member of the video group, the udev rule plex provides should give it. I do not know what happens in the container but suspect /dev/dri is not being made directly available.
    Please DISABLE Verbose logging until requested
    Please search before posting
    Primary support: Linux, Synology, and QNAP
    Please remember to report back. This benefits others.
    Useful links
     Installation and Basic Setup |  Media Preparation (How to name your media files)  |  Linux Permissions
     Handling TV Specials | Handling Movie extras  |  Nas Compatibility
     Reporting Plex Server issues | Plex Media Server FAQ | Linux Tips
    Other useful guides: Local Subtitles | The Plex "dance" | Synology FAQ | PMS Release Announcements
    Hosts: Fedora, QNAP, Synology, most Linux distros in VM
    No technical support via PM unless offered
    Please remember to mark the appropriate answer(s) which solved your issue.
  • Johnnyh1975Johnnyh1975 Posts: 33Members, Plex Pass, TunerTester Plex Pass
    I am passing through the /dev/dri/card0 to the container
    Do I need to have vaapi installed on the host as well?
    Is plex taking care of it inside the container?
    Or do I need to install vaapi inside the container by myself.
    The host operating system is based on Debian stretch
    The Container operating system is ubuntu 17.10
    If you have proper passthrough, PMS handles the rest. PMS has the libraries included.
    What are the udev permissions? What you're describing is common on NAS processors and docker containers where udev is not working correctly.
    As a test, configure a /etc/rc.local script which sets chmod -R 666 /dev/dri/card* /dev/dri/render*. If this allows it to work, your container doesn't have udev or it's not working correctly. (the PMS installer supplies the rules for udev)
    Useful links
    @ChuckPA, thanks for your assistance. Got it working in LXC container.
    I switched from mounting the dev/... files to
    lxc.cgroup.devices.allow = c 226:0 rwm
    and subsequent
    mknod -m 666 ${LXC_ROOTFS_MOUNT}/dev/dri/card0 c 226 0
    same for the renderD128
    and now it works!
    Great processor use down by more than 50% compared to before!
    would you mind coming up with a complete step-by-step? I'll take it and post it in Linux Tips and tag it for Proxmox.
    Useful links
    will do tonight - rather simple approach
    edited January 4
    Moderator edit: This guide has been formalized thanks to @Johnnyh1975 and is now published permanently here:
    https://forums.plex.tv/discussion/301781/pms-installation-guide-when-using-a-proxmox-5-1-lxc-container
    Installation guide for Plex Server under Proxmox 5.1 within an LXC Container
    1. Create an LXC Container (standard approach, well documented in Proxmox)
    Use the standard approach within Proxmox and create a privileged Container (incl. definition of hostname, root password)
    Select the your target operating system template, e.g. ubuntu 16.04, ubuntu 17.04 or ubuntu 17.10. (you have to download it from the Proxmox server)
    Define the memory and cpu allocation for your Plex container: e.g. 8 cores, 20GB RAM,... as well as network parameters
    2. Install on Intel Graphics acceleration drivers on Proxmox Host**
    First install on the Proxmox host the intel graphics acceleration drivers. (e.g. via Shell JS in the Proxmox manager)
    Proxmox host is running Debian stretch.
    apt-get install i965-va-driver
    Test if the driver is working. Install vainfo
    apt-get install vainfo
    Running vainfo should give you an output comparable to
    error: can't connect to X server!
    libva info: VA-API version 0.39.4
    libva info: va_getDriverName() returns 0
    libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
    libva info: Found init function __vaDriverInit_0_39
    libva info: va_openDriver() returns 0
    vainfo: VA-API version: 0.39 (libva 1.7.3)
    vainfo: Driver version: Intel i965 driver for Intel(R) Kabylake - 1.7.3
    vainfo: Supported profile and entrypoints
    VAProfileMPEG2Simple : VAEntrypointVLD
    VAProfileMPEG2Simple : VAEntrypointEncSlice
    VAProfileMPEG2Main : VAEntrypointVLD
    VAProfileMPEG2Main : VAEntrypointEncSlice
    VAProfileH264ConstrainedBaseline: VAEntrypointVLD
    VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
    VAProfileH264Main : VAEntrypointVLD
    VAProfileH264Main : VAEntrypointEncSlice
    VAProfileH264High : VAEntrypointVLD
    VAProfileH264High : VAEntrypointEncSlice
    VAProfileH264MultiviewHigh : VAEntrypointVLD
    VAProfileH264MultiviewHigh : VAEntrypointEncSlice
    VAProfileH264StereoHigh : VAEntrypointVLD
    VAProfileH264StereoHigh : VAEntrypointEncSlice
    VAProfileVC1Simple : VAEntrypointVLD
    VAProfileVC1Main : VAEntrypointVLD
    VAProfileVC1Advanced : VAEntrypointVLD
    VAProfileNone : VAEntrypointVideoProc
    VAProfileJPEGBaseline : VAEntrypointVLD
    VAProfileJPEGBaseline : VAEntrypointEncPicture
    VAProfileVP8Version0_3 : VAEntrypointVLD
    VAProfileVP8Version0_3 : VAEntrypointEncSlice
    VAProfileHEVCMain : VAEntrypointVLD
    VAProfileHEVCMain : VAEntrypointEncSlice
    VAProfileHEVCMain10 : VAEntrypointVLD
    VAProfileHEVCMain10 : VAEntrypointEncSlice
    VAProfileVP9Profile0 : VAEntrypointVLD
    VAProfileVP9Profile0 : VAEntrypointEncSlice
    VAProfileVP9Profile2 : VAEntrypointVLD
    Well done your host is supporting the appropriate acceleration.
    3. GPU passthrough configuration to Plex Container
    Find out the right parameter of your graphics card
    ls -l /dev/dri
    this should give you a comparable output to the following
    crw-rw---- 1 root video 226, 0 Dec 29 14:06 card0
    crw-rw---- 1 root video 226, 128 Dec 29 14:06 renderD128
    Note down the numbers behind video
    card0 has the id 226, 0
    renderD128 has the id 226,128
    Additionally take the fb0 devices as well
    ls -l /dev/fb0
    This gives the following output
    crw-rw---- 1 root video 29, 0 Dec 29 14:06 /dev/fb0
    so fb0 has the id 29,0
    Next define the gnu passthrough by adding the following lines at the end of your 100.conf file (use the appropriate number 100, 101,... that you assigned before to the Plex container). Please adjust the following lines with the id numbers for your graphics system you have noted down just before. In the last line replace the 100 with the Plex container id of your system.
    nano /etc/pve/lxc/100.conf
    lxc.cgroup.devices.allow = c 226:0 rvm
    lxc.cgroup.devices.allow = c 226:128 rvm
    lxc.cgroup.devices.allow = c 29:0 rvm
    lxc.autodev: 1
    lxc.autodev.hook: /var/lib/lxc/100/mount_hook.sh
    The last line calls at boot of the container a shell script that you need to create to mount the devices appropriately..
    Let's create it:
    nano /var/lib/lxc/100/mount_hook.sh
    Add the following lines and adjust the id's to your graphics system:
    mkdir -p ${LXC_ROOTFS_MOUNT}/dev/dri
    mknod -m 666 ${LXC_ROOTFS_MOUNT}/dev/dri/renderD128 c 226 128
    mknod -m 666 ${LXC_ROOTFS_MOUNT}/dev/fb0 c 29 0
    Save the file and make it executable.
    chmod 755 /var/lib/lxc/100/mount_hook.sh
    Your Plex LXC container is ready to boot up incl. GPU passthrough. Well done!
    1. Boot-up your container and install Plex media server
      Via Console JS of your container execute the following steps
    Login with root and the assigned password in step 1
    Make sure your system is up-to-date
    apt-get update && sudo apt-get upgrade
    Head to the Plex Downloads page. Download the current ubuntu package and make it available inside the container.
    Alternatively copy the download link from the web page. Use wget to download the installer via the copied link:
    wget https://downloads.plex.tv/...amd64.deb
    Make sure to exchange in this command the url by the copied one from the web page.
    This example uses the current link for Ubuntu, at the time of writing. Be sure to use the up-to-date version supplied on the Plex website.
    Use dpkg to install the Plex server:
    dpkg -i plexmediaserver*.deb
    Enable Plex Media Server to start on reboot, and then start the server:
    systemctl enable plexmediaserver.service
    systemctl start plexmediaserver.service
    The rest is than standard Plex configuration and media file management which is well documented. So I will not repeat it.
    Last step to make sure your Plex server is using hardware acceleration. Within the Plex web interface, go on "settings>server>transcoder". Make sure that advanced options are shown. And checkmark "use hardware acceleration when available"
    And now enjoy a fast transcoding experience within an LXC container. On my system the CPU usage was reduced by 50% compared to before :-)
    @ChuckPA - Step-by-step Guide is posted
    Thank you.
    I will transfer to Linux Tips, credit you, direct any errata to you?
    Useful links
    @Johnnyh1975
    I have a few questions:
    1. PMS download direct link is not advisable. 1.5.5 did not support HW transcode. Will this work with any version supporting HW transcoding?
    2. Do you know the link (or starting point) for Intel drivers (your step #2)
    Useful links
    edited December 2017
    @ChuckPA
    yes it will work - exchange it with the newest link and it's fine.
    (I was a bit lazy so I copied the link from another guide I used in the past)
    the intel drivers are part of the normal Debian repository so apt-get will find it. It's a standard package
    Would you mind making those minor updates? I don't want to make any mistakes.
    Useful links
    @ChuckPA
    updated the download link to the latest public Plex download
    Looking good... Except:
    You're still using a direct-download link (wget) in the container.
    Would you rework that such that:
    1. Download current via the web page
    2. Make the downloaded file available in the container.
    If this isn't possible, use the approach of right-click / copy URL for the desired version.
    Useful links
    @ChuckPA
    your suggestion is incorporated
    Useful links
    @ChuckPA
    Found some typos, but can‘t edit the post directly
    3rd line in 1st Paragraph: erase ‚the‘
    2nd titel: erase first ‚on‘ and erase ‚**‘ at the end
    3rd Paragraph, 5th bullet: ‚gnu‘ should be ‚gpu‘
    Rest Looks good
    edited January 4
    There you go. Edits applied.
    Barring any last second gaffs on my part which you may find, It's Open for business
    Thank you for all your help and patience.
    :+1:
    Useful links
  • 4Me4Me Posts: 12Members, Plex Pass Plex Pass
    Hey,
    thank you for the great tutorial.
    I have some small corrections:
    xc.cgroup.devices.allow = c 226:0 rvm rwm
    lxc.cgroup.devices.allow = c 226:128 rvm rwm
    lxc.cgroup.devices.allow = c 29:0 rvm rwm
    lxc.autodev: 1
    lxc.autodev.hook: lxc.hook.autodev:/var/lib/lxc/100/mount_hook.sh
    @4Me
    @ChuckPA
    in the Post 12 - the corrections are valid. Sorry for the typos...
«1
