Plex Audio Skipping on Roku 2 (Solved)
jonny_boy130@hotmail.comjonny_boy130@hotmail.com Posts: 1Members, Plex Pass Plex Pass
I was looking through the forums and trying to trouble an issue where my roku audio would intermittently skip or drop, basically cut out for less than a second, but it would happen every few seconds.
I didn't notice this on any other Roku apps, but I did notice that my restarting of the Roku was taking longer than usual. So I removed the MicroSD card and VIOLA! All is well now. No more skipping. I'm not sure why Plex was the only one showing those symptoms, but that's how I fixed it and thought it should be written somewhere for others facing the same issue.
Comments
  • Elijah_BaleyElijah_Baley Posts: 4,536Members, Plex Pass Plex Pass
    edited January 7
    FWIW: There have, in the past but not recently that I remember, been reports of various Roku problems when there was an SD card installed. It does not really relate to any particular brand but Sandisk is reported more often by far than others.
    I have noticed that people with large cards, 16 gb or larger mostly, have more problems than those that have a smaller card or no card at all. It should also be noted that no card larger than 4 gb (2 gb is usually plenty) will have its extra space used at all and the only thing that an SD card is used for is storing app code so that the apps do not need to be loaded from an online source. An SD card is NOT used for video storage or buffering or for app data storage or anything else in Roku operations except for storing app code for faster loading and if you do not have a fairly large number of apps you gain nothing from an SD card.
    I never install an SD card as it would gain nothing for me. Also I have never seen the need for more than about 20-25 apps maximum. I only have 12 apps installed and I rarely use more than 6 of those in any month.
    For those of you that have installed cards like 64 gb or 128 gb you are wasting that card in your Roku no matter how many apps you have installed.
    But all that is pretty much off topic. My recommendation is that if you have any SD card in your Roku you seriously consider removing it unless you are absolutely sure that you are really gaining something from the card.
    "If you pick up a starving dog and make him prosperous, he will not bite you. This is the principal difference between a dog and a man." - Mark Twain
    "If knowledge can create problems, it is not through ignorance that we can solve them." - Isaac Asimov
    “There is a cult of ignorance in the United States, and there has always been. The strain of anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that "my ignorance is just as good as your knowledge.” - Isaac Asimov
