Roku is unable to playback a movied with a specific audio stream
iXôiXô Posts: 30Members, Plex Pass Plex Pass
edited January 11 in Roku
Hello,
It is a first for me, a movie don't want to be played using the french audio stream. VLC is reading it fine, and Plex WEB too.
First play (french audio as default) : playing english audio, switchting to english : english audio, switch back to french : still english audio.
PMS and Client on the same local network.
I will have to check but I am fearly sure that the media is transcoded.
PMS v1.11.0.4666 on FreeBSD.
Roku Plex client v5.0.9.4387-9c86a612-
Media XML attached.
Best Answer
  • iXôiXô Posts: 30Members, Plex Pass Plex Pass
    Accepted Answer
    Ok. I managed to switch to the wanted audio stream : using * button during playback, switching to English then back to French did the trick.
    Thanks.
Answers
    Accepted Answer
    Thanks.
