Daily Plexamp Quirks (Visual Studio / Monitor Change)
dsjbdsjb Posts: 2Members, Plex Pass Plex Pass
Hi Guys
Loving Plexamp so far and now using it 100% while working. However I have two quirks which both are forcing me to restart the app daily.
1) It appears you have globally assigned the CTRL+ALT+SPACE key binding, this overrides the same key binding in Microsoft Visual Studio for the "Show parameter info" shortcut which I (and others) use all the time. If this could be changed to another combination or not made global that would really really help.
2) Every time i dock my surface pro and the monitors resize (some from high to low DPI) the Plexamp UI kind of screws up, only way to correct is to restart.
Best Answer
Answers
