Plexamp as remote
matthewdiasmatthewdias Posts: 15Members, Plex Pass Plex Pass
Which players can we control with plexamp? I was hoping I could control android from it, but my player doesn't appear in the list.
Answers
  • elanelan CTO and Co-founder MauiPosts: 9,779Members, Plex Employee, Plex Pass, Plex Ninja Plex Employee
    In theory, any Plex player (but clearly they need to have the remote control option available). I've tested with Android and it seemed to work fine. If you select any of the player options in the menu (including the currently selected one) it'll refresh the list, which can be helpful...
    instagram @elan // the wife's photography site.
    the Medium page // the dog's twitter feed.
  • matthewdiasmatthewdias Posts: 15Members, Plex Pass Plex Pass
    Hmm that didn't seem to work. Are there any other ways to get it to recognize it? Or something I can do to troubleshoot?
    Are you positive the remote control functionality is enabled on your Android device, and you're signed in?
    Yep, double-checked. "Advertise as player" is enabled, and i'm signed in.
    In that case you'd need to check Application.log and see why it's not able to find a connection for your Android player.
    Feb 09, 2018 18:07:14.963 INFO - APP: Switching to new player
    Feb 09, 2018 18:07:14.969 INFO - DEVICE: Fetching latest provider list from cloud.
    Feb 09, 2018 18:07:14.969 INFO - DEVICE: Fetching latest list from cloud.
    Feb 09, 2018 18:07:15.601 INFO - DEVICE: Fetched 7 devices from the cloud.
    Feb 09, 2018 18:07:15.602 INFO - DEVICE: Finding best connection for Nexus 5X
    Feb 09, 2018 18:07:15.603 INFO - HTTP: Issuing request to http://192.168.1.14:48606/resources
    Feb 09, 2018 18:07:15.603 INFO - DEVICE: Finding best connection for Pixel 2
    Feb 09, 2018 18:07:15.603 INFO - HTTP: Issuing request to http://<redacted>:41783/
    Feb 09, 2018 18:07:20.606 WARN - DEVICE: Player connection http://192.168.1.14:48606 didn't work for Nexus 5X: timeout of 5000ms exceeded
    Feb 09, 2018 18:07:20.606 WARN - DEVICE: Connection testing failed for Nexus 5X
    Feb 09, 2018 18:07:20.607 WARN - DEVICE: Server connection http://<redacted>:41783 didn't work for Pixel 2: timeout of 5000ms exceeded
    Feb 09, 2018 18:07:20.607 WARN - DEVICE: Connection testing failed for Pixel 2
    Feb 09, 2018 18:07:20.607 INFO - APP: Refreshing player/server menu.
    Feb 09, 2018 18:07:25.810 INFO - DEVICE: Persisting devices because Google Drive was dirty.
    Feb 09, 2018 18:07:25.811 INFO - DEVICE: Persisting devices.
    To be clear, Pixel 2 is the one i'm trying to connect to
    If you try to connect to/curl that URL, does it work?
    Nope. Can't connect.
    Then it appears there's some issue reaching the app on the Android phone; not sure why a priori, it works over here. You sure there's no NAT aspect?
    I don't believe so. Both devices are on the same subnet.
