Synology DS918+ Plex pauses and then playback not possible after 30 minutes into a movie
thedukeo8thedukeo8 Posts: 18Members, Plex Pass Plex Pass
I have installed PMS from Synology's package center. I'm running PMS version
This issue has now happened the last 3 days. I have started a movie and after about 30 min it simply stops, then PMS reports there is a problem with playback. I try to restart and it won't pick up where it left off. If I restart from the beginning and fast forward to right before it paused it will stop again at the exact same spot. This is getting very frustrating.
I tried to change the directory where the temp transcoding happened, but that didn't seem to have any effect. Or am I supposed to restart PMS after I make that change?
Logs from today are attached.
Any guidance as to why this is happening and how to resolve would be greatly appreciated. Let me know if any more info is needed.
Best Answer
