Plex Will not Start
RatokaRatoka Posts: 17Members, Plex Pass Plex Pass
When upgrading FreeNAS to U2, Plex will no longer start with the following error:
Mar 01, 2018 11:29:12.047 [0x80a2c6f00] INFO - Plex Media Server v1.11.3.4803-c40bba82e - FreeBSD PC amd64 - build: freebsd-x86_64 freebsd - GMT -08:00
Mar 01, 2018 11:29:12.047 [0x80a2c6f00] ERROR - Failed to determine system locale: locale::facet::_S_create_c_locale name not valid. Defaulting to en-US.
Mar 01, 2018 11:29:12.047 [0x80a2c6f00] INFO - FreeBSD version: 11.1-STABLE (FreeBSD 11.1-STABLE #0 r321665+de6be8c8d30(freenas/11.1-stable): Tue Feb 20 02:38:09 UTC 2018 root@gauntlet:/freenas-11-releng/freenas/_BE/objs/freenas-11-releng/freenas/_BE/os/sys/FreeNAS.amd64), language: en-US
Mar 01, 2018 11:29:12.047 [0x80a2c6f00] INFO - Processor AMD FX(tm)-6300 Six-Core Processor
Mar 01, 2018 11:29:12.047 [0x80a2c6f00] INFO - /usr/local/share/plexmediaserver-plexpass/Plex_Media_Server
Mar 01, 2018 11:29:12.044 [0x80a218000] WARN - Default locale is invalid; falling back on classic+UTF-8
Mar 01, 2018 11:29:12.053 [0x80a218000] INFO - SQLITE3:0x10, 283, recovered 784 frames from WAL file /config/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Mar 01, 2018 11:29:12.207 [0x80a218000] INFO - SQLITE3:0x10, 283, recovered 901 frames from WAL file /config/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db-wal
Mar 01, 2018 11:29:12.227 [0x80a218000] ERROR - HttpServer: Error binding acceptor: Can't assign requested address
Mar 01, 2018 11:29:12.228 [0x80a218000] ERROR - Error: Unable to set up server: listen: Can't assign requested address (N5boost16exception_detail10clone_implINS0_19error_info_injectorINS_6system12system_errorEEEEE)
I can revert to U1, and Plex will again start. Is there anything that can be tweaked on the Plex side, or is there additional information that I can provide to the FreeNAS team for help on the server side?
I found a topic about setting EnableIPv6 to 0, but I did not have this setting in my preference file. Adding the preference made no difference for me.
Thank you in advance!
  • gbooker02gbooker02 Posts: 670Members, Plex Employee, Plex Pass, Plex Ninja Plex Employee
    You likely have something already running on the port or you may be missing the loopback interface.
