Direct play on some 4k HEVC files and transcodes some. Exact same codec
Hi!
I get my LG and Samsung 4K TV to direct play some of my mkv files with 4K HEVC. For some reason 50% of the files doesn't direct play and Plex tries to transcode them.
On the ones not working it has DTS-HD audio so I changed it to AC3, so now my TVs direct play the audio but the video still tries to get transcoded.
Any ideas why?
Answers
  • slansislansi Posts: 10Members ✭✭
    You need to give more info on the files that aren't direct playing as well as the plex app version and plex server version
  • stefan.engblomstefan.engblom Posts: 2Members, Plex Pass Plex Pass
    edited March 13
    Latest Plex version.
    This file is working with direct stream both video and audio:
    Format : Matroska
    Format version : Version 4 / Version 2
    File size : 51.5 GiB
    Duration : 1h 43mn
    Overall bit rate mode : Variable
    Overall bit rate : 71.5 Mbps
    Encoded date : UTC 2017-11-30 15:35:55
    Writing application : mkvmerge v17.0.0 ('Be Ur Friend') 64-bit
    Writing library : libebml v1.3.5 + libmatroska v1.4.8
    Video
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : Main 10@L5.1@High
    Codec ID : V_MPEGH/ISO/HEVC
    Duration : 1h 43mn
    Bit rate : 65.9 Mbps
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) fps
    Color space : YUV
    Chroma subsampling : 4:2:0 (Type 2)
    Bit depth : 10 bits
    Bits/(Pixel*Frame) : 0.331
    Stream size : 47.4 GiB (92%)
    Title : MPEG-H HEVC Video / 65896 kbps / 2160p / 23.976 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / HDR / BT.2020
    Default : Yes
    Forced : No
    Color range : Limited
    Color primaries : BT.2020
    Transfer characteristics : PQ
    Matrix coefficients : BT.2020 non-constant
    Mastering display color primaries : Display P3
    Mastering display luminance : min: 0.0000 cd/m2, max: 1000 cd/m2
    Maximum Content Light Level : 814 cd/m2
    Maximum Frame-Average Light Level : 192 cd/m2
    Audio #1
    Format : TrueHD
    Format profile : TrueHD+Atmos / TrueHD
    Codec ID : A_TRUEHD
    Duration : 1h 43mn
    Bit rate mode : Variable
    Bit rate : 4 914 Kbps
    Maximum bit rate : 7 719 Kbps
    Channel(s) : Object Based / 8 channels
    Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE
    Sampling rate : / 48.0 KHz
    Frame rate : 1 200.000 fps (40 SPF)
    Compression mode : Lossless
    Stream size : 3.54 GiB (7%)
    Title : Dolby Atmos/TrueHD Audio / 7.1-Atmos / 48 kHz / 5554 kbps / 24-bit
    Language : English
    Default : Yes
    Forced : No
    This file Plex tries to transcode both video and audio.
    Format : Matroska
    File size : 45.2 GiB
    Duration : 1h 46mn
    Overall bit rate : 60.6 Mbps
    Encoded date : UTC 2018-03-11 16:39:46
    Writing application : mkvmerge v21.0.0 ('Tardigrades Will Inherit The Earth') 64-bit
    Video
    Format : HEVC
    Duration : 1h 46mn
    Bit rate : 58.2 Mbps
    Color space : YUV
    Bit depth : 10 bits
    Bits/(Pixel*Frame) : 0.293
    Stream size : 43.4 GiB (96%)
    Title : English
    Language : English
    Default : Yes
    Forced : No
    Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
    Maximum Content Light Level : 323 cd/m2
    Maximum Frame-Average Light Level : 144 cd/m2
    Audio
    Format : DTS
    Format/Info : Digital Theater Systems
    Format profile : MA / Core
    Codec ID : A_DTS
    Duration : 1h 46mn
    Bit rate mode : Variable / Constant
    Bit rate : 2 411 Kbps / 1 509 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Frame rate : 93.750 fps (512 SPF)
    Bit depth : 16 bits
    Compression mode : Lossless / Lossy
    Stream size : 1.80 GiB (4%)
    Title : English
    Language : English
    Default : Yes
    Forced : No
    No subtitles enabled I'm assuming? If so disable them and try again, if not try this.
    Try playing the second file through Plex DLNA. First you'll have to delete the preset profile used for Samsung bc it is not updated for HEVC. By deleting the profile plex will default to a universal profile which is compatible
    You will most likely find profiles located under
    C:\Program Files (x86)\Plex\Plex Media Server\Resources\Profiles
    Then find the file name Samsung SmartTV.xml and delete it. It will ask for administration clearance just accept it.
    Now try to play the file. If it plays without transcoding then it's the Plex app that is limited( They have alot of work to do for 4k compatability)
