Please help. Not all movies displaying in library
matt.szewczykmatt.szewczyk Posts: 20Members, Plex Pass Plex Pass
edited April 11 in Roku
Greetings. This is my first plex forums post, and yes, i have thoroughly searched around the web and the forums for a solution.
In short, I have a rather large movie library, but recently a good chunk of my library just stopped showing up in my roku player. The library just stops halfway through the letter "S" and nothing comes up after that.
I am running server version 1.12.3.4947 on Ubuntu 16 LTS, and my Roku is an Ultra. I am gigabit wired to the LAN where the plex server lives, and other devices (smart tvs, fire tvs, phones, etc) are displaying the library correctly. I have removed the plex app from the roku and re-added it, i have re-scanned the library, i have rebooted all devices....i really cant find anything that could be causing this on the web (except things that are 6 years old).
Any help would be greatly appreciated!!!
Best Answer
  • ChuckPAChuckPA Posts: 21,673Members, Plex Pass, Plex Ninja, Plex Team Member Plex Team Member
    edited April 17 Accepted Answer
    There is no "Due Date" on the schedule right now. I see the work is in the queue. Since I'm not on the management team, I don't know its priority. It might be number 1 or 2 and it might be number 10. That level is hidden from me.
    The limitation is due to memory. What is on the schedule is a complete rewrite of that entire mechanism. The goal is to remove memory limitations. I do know the existing limitation is based on older Roku compatibility. Should it be viable to drop those older units, the "How to get 10 lbs into a 5 lb bucket" becomes moot.
    In regards to "other Dark Humor", I'll share one last thought. :D
    ...They're coming to take him away, ha ha. They're coming to take him away, ho ho, hee hee, ha ha. To the funny farm where life .....
    (literary license thoroughly abused here.. HAHA) :)
    Please DISABLE Verbose logging until requested
    Please search before posting
    Primary support forums: Linux, Synology, and QNAP
    Please remember to report back. This benefits others.
    Useful links
     Installation and Basic Setup |  Media Preparation (How to name your media files)  |  Linux Permissions
     Handling TV Specials | Handling Movie extras  |  Nas Compatibility
     Reporting Plex Server issues | Plex Media Server FAQ | Linux Tips
    Other useful guides: Local Subtitles | The Plex "dance" | Synology FAQ | PMS Release Announcements
    Hosts: Fedora, QNAP, Synology, most Linux distros in VM
    No technical support via PM unless offered
    Please remember to mark the appropriate answer(s) which solved your issue.
«13
Answers
  • Elijah_BaleyElijah_Baley Posts: 4,886Members, Plex Pass Plex Pass
    I have never seen such a problem but I can guess that something may be screwy in the apps catch or internal memory. When you remove the app you need to restart the Roku before you re-install the app. That is the only way to clear the internal memory the Plex app was using.
    Although it is not used for streaming at all there have been more than a few reports of SD cards causing unusual problems so, if you have one installed, it might be a good idea to remove it for testing. The SD card is only used for apps to be stored on to allow for faster initial loading and, unless you have a HUGE number of apps installed, you will notice no difference while running without it.
    Those are the only two things that occur to me right now. Try them and see what happens.
    "If you pick up a starving dog and make him prosperous, he will not bite you. This is the principal difference between a dog and a man." - Mark Twain
    "If knowledge can create problems, it is not through ignorance that we can solve them." - Isaac Asimov
    “There is a cult of ignorance in the United States, and there has always been. The strain of anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that "my ignorance is just as good as your knowledge.” - Isaac Asimov
  • matt.szewczykmatt.szewczyk Posts: 20Members, Plex Pass Plex Pass
    Sounds good, i don't have an SD card installed, and i dont have many apps installed either...but i didnt reboot the roku in between uninstalling the app and reinstalling. I will give that a shot tonight and keep you posted. Thanks Elijah.
    Unfortunately this was not the solution
    Update: i have a roku 3 that i hooked up, and its experiencing the same problem. here is a screenshot of what i'm referring to:
    i thought it might be a corrupt movie, so i went to the last movie that IS showing up and deleted the next one in my library...still no dice. Everything shows up in the plex for the web and android devices.
  • NewPlazaNewPlaza Posts: 1,617Members, Plex Pass Plex Pass
    You might try the Plex Pass Preview Channel for Roku.
    https://forums.plex.tv/discussion/comment/1647129/#Comment_1647129
    I just installed the plex pass preview version and i am experiencing the same symptoms.
    Damn. That was my goto answer. I have no idea what's causing your issue.
    How big(movie count) is your movie library?
    11,478 movies total in this library.
    edited April 16
    WOW! Okay...
    You know, as a test... Do you happen to have about 1,478 movies in the T, U, V, W, X, Y, Z, and some of S?
    Bingo (i deleted a movie), but the "missing" movies count 1477. Looks like the Roku app for some reason stops at 10,000 movies.
    Here's the question....I've been building this library for years obviously, and I didn't just add 1477 movies to it the other day. This stopped working suddenly....how can I fix it?
    edited April 16
    Could be a bug with the latest version of PMS. I know not linux so if you can try to uninstall the version you currently have and install an older version...
    I posted in the Plex Pass General discussion forum. hopefully it will get some traction there. Thanks for the help so far!
    edited April 16
    Not to be a sh*t but you will have far better success here or in the general (public) discussion.
    To be honest because you have PMS on Linux I think @ChuckPA should be summon.
    Understood. I posted a copy of the plex pass general discussion in the regular general discussion. Thanks for the help, im new to the forums.
    No problems.. I hope we can all help with your issue.. I know I'll be in your shoes in a year or so(at 6800 movies, lol).
    Aaaaaaand they just closed the one in general discussion non-plex pass. sigh
    edited April 16
    Oh ya.. They'll do that if its a duplicate from section to section.
    edited April 16
    The fact that they closed the public one kinda pisses me off but if I don't like it then I should buy PLEX Inc., then take over the forums so i can do whatever I want.. I'm not there yet, lol
    There are hundreds of nonplexpass members that could of help..but... will never see the plex pass section...
    Perhaps @ljunkie should be included in this discussion.
    In the spirit of shining a little humor on a problem,
    PMS is meant to index and play your media and not serve as an archiver of over 10,000 movies. Have you actually watched them all ? :D
    I will not ask how you acquired such a, umm, 'collection'. >:)
    To the matter at hand:
    Doesn't seem a bit unreasonable to put so many movies clumped into one library? Given how the display scrolling works, how long does it take to find what one is looking for? Minutes? Hours? :)
    My first reaction is:
    1. Likely a memory limitation of the Roku app on a 4200x but have reached out to the dev for specifics
    2. Roku app is undergoing changes and a bug might have gotten by. Needs investigating
    3. General media management. Break it up a little?
    Useful links
«13
