[Solved] Trouble with Hades Canyon NUC and Hardware Decoding
millercentralmillercentral Posts: 87Members, Plex Pass Plex Pass
edited May 15 in Linux
I recently received one of the new Hades Canyon NUCs (NUC8i7HVK) with hopes of it becoming my next powerhouse Plex server.
My hope was to use linux, and take advantage of hardware transcoding, but unfortunately I have run into some trouble. I installed Ubuntu 16.04 LTS server and plex,, but the plex server setup UI does not show the Hardware Transcode option, and transcoding is happening on the CPU. Looking in the logs I see:
TPU: hardware transcoding: zero-copy support not present
however, if I run vainfo on the nuc, this is what I get:
error: can't connect to X server!
libva info: VA-API version 0.39.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_0_39
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.39 (libva 1.7.0)
vainfo: Driver version: Intel i965 driver for Intel(R) Kabylake - 1.7.0
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264MultiviewHigh : VAEntrypointVLD
VAProfileH264MultiviewHigh : VAEntrypointEncSlice
VAProfileH264StereoHigh : VAEntrypointVLD
VAProfileH264StereoHigh : VAEntrypointEncSlice
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileVP8Version0_3 : VAEntrypointVLD
VAProfileVP8Version0_3 : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointVLD
Any other suggestions before I switch over to Windows?
Thanks!
«1
Comments
  • ChuckPAChuckPA Posts: 22,245Members, Plex Pass, Plex Ninja, Plex Team Member Plex Team Member
    If you look at /dev/dri and don't find /dev/dri/renderD128, you have your answer.
    It means the motherboard is not making the iGPU available at the known device node (which is the standardized name above).
    Some machines disable it and provide secondary hardware acceleration. Is that happening here?
    One other thing to look.. Make certain the udev package is installed . If you didn't do a standard desktop installation, it might have been missed. Without that, user plex won't have permission to read /dev/dri/renderD128 even if it does exist
    Please DISABLE Verbose logging until requested
    Please search before posting
    Primary support: Linux, Synology, and QNAP
    Please remember to report back. This benefits others.
    Useful links
     Installation and Basic Setup |  Media Preparation (How to name your media files)  |  Linux Permissions
     Handling TV Specials | Handling Movie extras  |  Nas Compatibility
     Reporting Plex Server issues | Plex Media Server FAQ | Linux Tips
    Other useful guides: Local Subtitles | The Plex "dance" | Synology FAQ | PMS Release Announcements
    Hosts: Fedora, QNAP, Synology, most Linux distros in VM
    No technical support via PM unless offered
    Please remember to mark the appropriate answer(s) which solved your issue.
  • millercentralmillercentral Posts: 87Members, Plex Pass Plex Pass
    edited May 13
    Thank you for the help.
    /dev/dri contains /dev/dri/card0, /dev/dri/controlD64, and /dev/dri/renderD128.
    I did a server install, but sudo apt-get install udev reports: udev is already the newest version (229-4ubuntu21.2).
    Strange.
    Let me see the logs please after you attempt to use it again. Something isn't right.
    I also need to see the XML of what you're trying to play
    Useful links
    Fresh logs attached. I haven't tried many different types of media yet (this was one minute of play of a UHD rip).
    what are the permissions on that?
    they better be root:video and plex better be a member of group video. That's what udev relies on.
    If not, force perms to 666 for /dev/dri/*. If that works, you have a udev problem (uninstall and reinstall the package is your only hope)
    If that doesn't work, you're screwed. Hades Canyon is brand spanking new and is known for several issues (Anandtech)
    Useful links
    Afterthought.
    That box has it's own display/secondary GPU on board?
    IF SO
    I am willing to bet you will find renderD128 and renderd129 in /dev/dri (one for each).
    Turn off the motherboard GPU and you're golden (which I think is the root problem)
    Useful links
    I'll check permissions next, thanks. The Hades Canyon CPU has a AMD GPU block as part of the SOC -- not quite discrete graphics, but different than previous intel chips.
    FWIW, totally recognize this is a brand new platform and may not work. I just want to make sure my limited knowledge around linux and hardware transcoding isn't the problem, rather than an actual limitation of the hardware. Plus I enjoy the process of learning/experimenting here. :) In all other ways, this is a pretty amazing little chuck of computing power.
    Thanks again for the help. I'll update if I make any progress.
  • AchillesAchilles Posts: 2,261Members, Plex Pass, Plex Ninja Plex Ninja
    edited May 13
    Mine is on pre-order.
    All Kaby Lake-Gs support dual-channel DDR4-2400 (no ECC) memory. You'll notice that they also sport HD Graphics 630 and AMD's discrete GPU, too. Intel doesn't use its integrated engine for either NUC's display outputs. Instead, that hardware remains available for OpenCL-based compute workloads and QuickSync-accelerated software.
    do a ls -l /dev/dri so we can see if the developers need to account for the AMD Radeon VEGA being the primary and not the Intel HD Graphics 630
    If nothing shows there, either Ubuntu 16.04.4 LTS is not exposing QSV or Plex does not know how to use it in this design.
    Did you click on Show Advanced under Settings | Transcoder?
    edited May 13
    @Achilles - yes, unfortunately after pressing "Show Advanced", the "Use hardware..." option is not present.
    I added user plex to the group video and confirmed that the nodes in /dev/dri are root:video with 660 permissions (renderD128 is the only render-based node in that directory - see below), but even after a reboot no change -- hardware decode option still not present, logs still report zero-copy support not present.
    I checked the bios, there is no option to disable the AMD GPU block. The only option related to graphics at all is an option to disable the Intel iGD, and while I haven't tried that - disabling that seems counter to what we are trying to achieve...
    I'll probably experiment with Windows next to see how it interacts with the device.
    plex@redeye:/dev/dri$ ls -l
    total 0
    crw-rw----+ 1 root video 226, 0 May 13 11:17 card0
    crw-rw---- 1 root video 226, 64 May 13 11:17 controlD64
    crw-rw----+ 1 root video 226, 128 May 13 11:17 renderD128
    Thanks for that info.
    The AMD does not communicate using Intel Quick Sync video (QSV) protocol.
    There's no support for it at this time through the iGPU.
    If you disable what's onboard the CPU, loop it around and get all the libva drivers installed yourself (an arduous task in some cases), you'll have it BUT in most cases that'll mean you need to have the graphics running. The whole purpose of using QSV in the initial version of HW transcoding is to allow the server to be headless. (easiest problem to tackle)
    Useful links
    @millercentral Did you claim the server with your plex.tv account yet? HW transcoding is a Plex Pass feature and requires you to sign it in.
    Aha, I had not claimed the server yet -- since I'm just testing, I didn't want to expose other users to it. That could be it! I did not realize that could have an impact on hardware transcoding.
    However, I'm currently testing on Windows now. After I gather my results on Windows, I'll switch back to linux again and try that out. Great catch @Achilles!
    Windows requires an active login with a display connected. Linux is better for a headless setup.
    So hardware transcoding works on Windows. Interestingly, it uses the AMD GPU core for the process (there was an option in the AMD settings to use the GPU for Graphics or OpenCL workloads, so I chose OpenCL - don't know if that played a role here). I think the pegged CPU thread is the audio portion of the transcode (in this case it was transcoding 4K UHD HEVC to 4K h264 "Maximum" playback in a Firefox browser - playback was smooth):
    I'm going to experiment/stress test a bit more on Windows tomorrow, then switch back to linux and see if I can get it working there as well. I will say this is a very impressive little device...
    Last update on the Windows install before switching back to Linux. Running PMS on this NUC on Windows with hardware transcoding enabled allowed me to transcode three unique streams of 4K UHD rips simultaneously to remote clients without breaking a sweat. Really impressive, and a massive improvement over my current server.
    Now back to linux to see if I can replicate the results there. :)
  • havoc7701havoc7701 Posts: 16Members, Plex Pass Plex Pass
    edited May 15
    Hi @millercentral - This brand new CPU and Ubuntu 16.04 LTS may just be having trouble getting to know each other. The kernel support for i915 Coffee Lake CPUs and the i915 support in this new Hades Canyon CPU are not enabled by default and are considered alpha support. After some lengthy troubleshooting, ChuckPA helped me discover the problem and I found a fix here with a kernel boot parameter. My QSV hardware transcode works great now, except of course for PGS subtitles, as I have learned, which is a known issue. I’d be curious if this fix works for you, too.
    Success! @Achilles was spot on that without claiming the server, Hardware Transcoding was not available. When I re-setup linux on the device and this time claimed the server as part of Plex setup, the option appeared in Settings > Server > Transcoding, and works as expected. While I can't see the status of the GPU block from linux, here is what glances reports while streaming and transcoding two 4K UHD rips simultaneously:
    @havoc7701 Thank you very much for the tip, but it turns out that boot parameter was not needed in my case. I'm running a standard ubuntu 16.04.04 server install with kernel 4.4.0-116-generic.
    I'll likely stay in test mode for another few days and try some additional media types, then move it over to become my production server. I can't wait until others get their hands on this nuc as well and share their own findings.
    THANK YOU all for the advice and help getting me going, I very much appreciate it.
    edited May 15
    @millercentral
    sudo apt install intel-gpu-tools
    sudo intel_gpu_top to see the GPU usage stats.
    Interesting. That tool doesn't work on this device/OS:
    plex@skullnuc:~$ sudo intel_gpu_top
    (intel_gpu_top:2695) intel-mmio-CRITICAL: Test assertion failure function intel_mmio_use_pci_bar, file ../../lib/intel_mmio.c:145:
    (intel_gpu_top:2695) intel-mmio-CRITICAL: Failed assertion: !(error != 0)
    (intel_gpu_top:2695) intel-mmio-CRITICAL: Last errno: 1, Operation not permitted
    (intel_gpu_top:2695) intel-mmio-CRITICAL: Couldn't map MMIO region
    Stack trace:
    #0 [_init+0x83d9]
    #1 [_init+0x6036]
    #2 [_init+0x1301]
    #3 [__libc_start_main+0xf0]
    #4 [_init+0x2f61]
    #5 [+0x2f61]
    Test (null) failed.
    **** DEBUG ****
    **** END ****
    FAIL (-1.000s)
    AZ
«1
