Hey folks, there is a new Podcast category for forums https://forums.plex.tv/categories/podcasts
Public Service Announcement - Max Memory for Synology x18 Series - J3x55 CPU
ChuckPAChuckPA Posts: 22,836Members, Plex Pass, Plex Ninja, Plex Team Member Plex Team Member
edited May 23 in Synology
For all who read this:
There is incorrect information circulating in the forums . The maximum addressable memory on an Intel J3355 or J3455 CPU is 8 GB per the Intel "Ark".
The Synology BIOS reads the DIMM information, totals the value, and displays to you what it finds. It cannot use more than 8 GB.
For best use in Plex, if you are adding memory, you should upgrade using an '8 GB kit' . These come as two matched sticks of 4 GB. This is what allows dual channel mode to enable and speed up hardware transcoding by doubling total memory bandwidth available (2 paths of 64 bits instead of 1 when mismatched). It will not improve CPU audio transcoding performance but does allow the GPU/ASIC to better coexist with the CPU, which is doing audio transcoding, resulting in less contention for the memory bus when both are occurring simultaneously.
https://ark.intel.com/products/95594/Intel-Celeron-Processor-J3455-2M-Cache-up-to-2_3-GHz
Similarly, the J3355 CPU also has the same 8 GB memory limitation.
https://ark.intel.com/products/95597/Intel-Celeron-Processor-J3355-2M-Cache-up-to-2_5-GHz?q=j3355
Please DISABLE Verbose logging until requested
Please search before posting
Primary support: Linux, Synology, and QNAP
Please remember to report back. This benefits others.
Useful links
 Installation and Basic Setup |  Media Preparation (How to name your media files)  |  Linux Permissions
 Handling TV Specials | Handling Movie extras  |  Nas Compatibility
 Reporting Plex Server issues | Plex Media Server FAQ | Linux Tips
Other useful guides: Local Subtitles | The Plex "dance" | Synology FAQ | PMS Release Announcements
Hosts: Fedora, QNAP, Synology, most Linux distros in VM
No technical support via PM unless offered
Please remember to mark the appropriate answer(s) which solved your issue.
This discussion has been closed.
