Hey folks, there is a new Podcast category for forums https://forums.plex.tv/categories/podcasts
Plex won't seem to close any subprocesses? Stops working after running for a couple hours.
trsqltvtrsqltv Posts: 11Members ✭✭
Hey Guys, the title says it all.
Pretty much the server becomes unusable after a certain period of time, this is generally a couple hours. After it gets to this point, even if I ask it to refresh metadata or scan library for changes, it just runs forever without making any progress. I've tried optimizing the database without much effect/outcome. The only way I'm able to get it out of this state is by restarting the server. Doing sudo service plexmediaserver restart restarts the server but doesn't fix the issue (output of sudo service plexmediaserver status after trying to stop plex: https://hastebin.com/rudaqofivi.vbs ).
Obviously, here's some more information/log dump/status info after starting the server and letting it run for some time:
Plex Server Version = 1.13.1.5063
Systemd Status Output = https://hastebin.com/usoqajinus.js
plexmediaserver Service File = https://hastebin.com/tofizigoxu.ini
Server Specs:
Storage: 480GB SSD
CPU: Dual Xeon E5-2670
Memory: 32GB
Connection: 1GB
I've verified /var/lib/plexmediaserver is owned by plex:plexand has 755 permissions.
Also attached is the Log output after stopping and restarting the server.
Any one with any experience would be appreciated!
Thank you!
Best Answer
  • trsqltvtrsqltv Posts: 11Members ✭✭
    Accepted Answer
    So I ended up restarting, switching OS's and trying from scratch and had a bit more luck. I guess Plex doesn't play well with Ubuntu 18.04.
    Thanks for the intermittent help!
Answers
  • ChuckPAChuckPA Posts: 22,836Members, Plex Pass, Plex Ninja, Plex Team Member Plex Team Member
    edited May 25
    Your database is a mess given you have dual Xeon E5. It should never take this long.
    Libaries -> ... -> Optimize Database
    You might also want to enable automatic optimization Settings - Server - Scheduled Tasks
    What's happening is Plex's processes are trying to communicate and timeout with each other. Eventually it will get all jammed up.
    Your logs show:
    May 24, 2018 23:17:25.899 [0x7fb85c3fe700] WARN - SLOW QUERY: It took 340.000000 ms to retrieve 27 items.
    and
    May 24, 2018 22:31:38.117 [0x7f211dbf8700] WARN - SLOW QUERY: It took 210.000000 ms to retrieve 39 items.
    May 24, 2018 22:31:38.117 [0x7f2128bfe700] DEBUG - Setting container serialization range to [0, 137] (total=138)
    May 24, 2018 22:31:38.118 [0x7f211dbf8700] DEBUG - Setting container serialization range to [0, 38] (total=138)
    May 24, 2018 22:31:38.137 [0x7f211e3f9700] DEBUG - We're going to try to auto-select an audio stream for account 1.
    May 24, 2018 22:31:38.137 [0x7f211e3f9700] DEBUG - Selecting best audio stream for part ID 4585 (autoselect: 1 language: en)
    May 24, 2018 22:31:38.137 [0x7f211e3f9700] DEBUG - We're going to try to auto-select a subtitle.
    May 24, 2018 22:31:38.137 [0x7f211e3f9700] DEBUG - Audio Stream: 9007, Subtitle Stream: -1
    May 24, 2018 22:31:38.138 [0x7f211e3f9700] DEBUG - We're going to try to auto-select an audio stream for account 1.
    May 24, 2018 22:31:38.138 [0x7f211e3f9700] DEBUG - Selecting best audio stream for part ID 12837 (autoselect: 1 language: en)
    May 24, 2018 22:31:38.138 [0x7f211e3f9700] DEBUG - We're going to try to auto-select a subtitle.
    May 24, 2018 22:31:38.138 [0x7f211e3f9700] DEBUG - Audio Stream: 26820, Subtitle Stream: -1
    May 24, 2018 22:31:38.140 [0x7f211e3f9700] DEBUG - We're going to try to auto-select an audio stream for account 1.
    May 24, 2018 22:31:38.140 [0x7f211e3f9700] DEBUG - Selecting best audio stream for part ID 14313 (autoselect: 1 language: en)
    May 24, 2018 22:31:38.140 [0x7f211e3f9700] DEBUG - We're going to try to auto-select a subtitle.
    May 24, 2018 22:31:38.140 [0x7f211e3f9700] DEBUG - Audio Stream: 32035, Subtitle Stream: -1
    May 24, 2018 22:31:38.143 [0x7f2158bff700] DEBUG - Completed: [127.0.0.1:42560] 200 GET /hubs/home/onDeck (21 live) GZIP Page 0-11 144ms 2538 bytes (pipelined: 11)
    May 24, 2018 22:31:38.151 [0x7f2158bff700] DEBUG - Completed: [127.0.0.1:42592] 200 GET /hubs/home/recentlyAdded?type=1 (21 live) GZIP Page 0-38 83ms 15061 bytes (pipelined: 2)
    May 24, 2018 22:31:38.163 [0x7f211c3f5700] WARN - SLOW QUERY: It took 330.000000 ms to retrieve 50 items.
    May 24, 2018 22:31:38.177 [0x7f211b3f3700] WARN - SLOW QUERY: It took 550.000000 ms to retrieve 13 items.
    May 24, 2018 22:31:38.197 [0x7f211b3f3700] DEBUG - It took 70.000000 ms to retrieve 164 items.
    Please DISABLE Verbose logging until requested
    Please search before posting
    Primary support: Linux, Synology, and QNAP
    Please remember to report back. This benefits others.
    Useful links
     Installation and Basic Setup |  Media Preparation (How to name your media files)  |  Linux Permissions
     Handling TV Specials | Handling Movie extras  |  Nas Compatibility
     Reporting Plex Server issues | Plex Media Server FAQ | Linux Tips
    Other useful guides: Local Subtitles | The Plex "dance" | Synology FAQ | PMS Release Announcements
    Hosts: Fedora, QNAP, Synology, most Linux distros in VM
    No technical support via PM unless offered
    Please remember to mark the appropriate answer(s) which solved your issue.
    Hey!
    I've been optimizing my Plex database almost every time I do something in Plex (Scan Library Files, Analyze Library, Refresh Metadata, Fix a Match etc) and also optimize before running something as well and keep running into this issue.
    I also have everything enabled under Scheduled Tasks:
    Could this be related to the database itself and/or sqlite?
    Thank you.
    edited May 25
    How many items do you have indexed, in total?
    Is the Library on a HD, SSD, or elsewhere?
    Useful links
    Current Library:
    • Music: 4000 songs
    • TV Shows: 900 episodes
    • Movies: 150 movies
    All the content is stored on Read Only drives that are hosted in the cloud. However, Plex itself and its metadata + database + files are hosted off an SSD.
    Also, after running sudo service plexmediaserver, I'm getting this:
    ```● plexmediaserver.service - Plex Media Server for Linux
    Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
    Active: active (running) since Thu 2018-05-24 23:16:59 CDT; 18h ago
    Process: 16717 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" (code=exited, status=0/SUCCESS)
    Main PID: 16726 (sh)
    Tasks: 167 (limit: 4915)
    CGroup: /system.slice/plexmediaserver.service
    ├─ 426 /usr/lib/plexmediaserver/Plex Media Scanner --analyze-deeply --item 5763 --log-file-suffix Deep Analysis
    ├─ 1573 /usr/lib/plexmediaserver/Plex Media Scanner --scan --section 3 --directory /home/plexadmin/tv-gd/Bob's Burgers --refresh --item 10109 --force
    ├─ 1692 /usr/lib/plexmediaserver/Plex Media Scanner --scan --section 3 --directory /home/plexadmin/tv-gd/Bob's Burgers --refresh --item 10109 --force
    ├─ 2418 /usr/lib/plexmediaserver/Plex Media Scanner --scan --section 3 --directory /home/plexadmin/tv-gd/Bob's Burgers --refresh --item 10109 --force
    ├─ 2430 /usr/lib/plexmediaserver/Plex Media Scanner --scan --section 3 --directory /home/plexadmin/tv-gd/Bob's Burgers --refresh --item 10109 --force
    ├─ 2454 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10228
    ├─ 2845 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10229
    ├─ 3107 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10230
    ├─ 3337 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10231
    ├─ 3561 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10231
    ├─ 4160 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10227
    ├─ 4162 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10232
    ├─ 4363 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10233
    ├─ 4366 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10228
    ├─ 4819 /usr/lib/plexmediaserver/Plex Media Scanner --scan --section 3 --directory /home/plexadmin/tv-gd/Bob's Burgers --refresh --item 10109 --force
    ├─ 4887 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10233
    ├─ 4890 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10229
    ├─ 5014 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10230
    ├─ 5170 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10235
    ├─ 5382 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10236
    ├─ 5613 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10237
    ├─ 5751 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10237
    ├─ 6024 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10239
    ├─ 6156 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10239
    ├─ 6394 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10240
    ├─ 6555 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10240
    ├─ 6831 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10241
    ├─ 6988 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10242
    ├─ 7224 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10243
    ├─ 7340 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10244
    ├─ 7579 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10245
    ├─ 7703 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10245
    ├─ 7929 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10246
    ├─ 7931 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10240
    ├─ 8051 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10238
    ├─ 8053 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10241
    ├─ 8276 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10242
    ├─ 8402 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10243
    ├─ 8626 /usr/lib/plexmediaserver/Plex Media Scanner --analyze --log-file-suffix Analysis --item 10244
    ├─15660 /usr/lib/plexmediaserver/Plex Media Scanner --analyze-deeply --item 9247 --log-file-suffix Deep Analysis
    ├─16726 /bin/sh -c LD_LIBRARY_PATH=/usr/lib/plexmediaserver "/usr/lib/plexmediaserver/Plex Media Server"
    ├─16727 /usr/lib/plexmediaserver/Plex Media Server
    ├─16786 /usr/lib/plexmediaserver/Plex Media Scanner --scan --refresh --section 2
    ├─16847 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-b4605f76e/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.13.1.5063-b4605f76e /usr/lib/plexmediaserver
    ├─16931 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.13.1.5063-b4605f76e 32600 /waitmutex
    ├─18929 Plex EAE Service
    ├─19377 /usr/lib/plexmediaserver/Plex Media Scanner --scan --section 3 --directory /home/plexadmin/tv-gd/Archer (2009) --refresh --item 5201 --force
    ├─21526 Plex Plug-in [com.plexapp.agents.plexmusic] /usr/lib/plexmediaserver/Resources/Plug-ins-b4605f76e/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.13.1.5063-b4605f76e /usr/lib/plexm
    └─25152 /usr/lib/plexmediaserver/Plex Media Scanner --analyze-deeply --item 5481 --log-file-suffix Deep Analysis
    May 25 11:18:48 SB sh[16726]: Sqlite3: Sleeping for 200ms to retry busy DB.
    May 25 15:32:07 SB sh[16726]: Sqlite3: Sleeping for 200ms to retry busy DB.
    May 25 16:41:34 SB sh[16726]: Sqlite3: Sleeping for 200ms to retry busy DB.
    May 25 17:23:26 SB sh[16726]: Sqlite3: Sleeping for 200ms to retry busy DB.
    Entire logs please? (Settings - Server - Help - Download Logs)
    I need to see what else is going on in the other log files. I can tell nothing from a fragment
    Useful links
    Apologies, I've attached the logs. I haven't purged them since the last time I uploaded them so their might be a lot of older logs.
    I also don't seem to be able to edit past messages but that's no biggie.
    Did you put your Transcoder Temp directory in RAM /dev/shm/Transcode as the logs show?
    I would like you to conduct a test for me.
    1. Stop PMS
    2. In /var/lib/plexmediaserver rename Library to Library.prev
    3. Start PMS
    4. Stand up a new, bare minimal server with no extra 'tweaks' (e.g. transcoder temp) and only one media library (a small one) .
    5. when you see all metadata has been retrieved and nothing is playing or was added (no plug-ins or cert), grab the logs again and attach.
    Useful links
    edited May 28
    Hey!
    So I did that, created a library with 4 movies and grabbed the logs. They should be attached to this post.
    Also, I updated the server to 1.13.2.5102.
    Thanks!
    Thanks for the logs.
    There are no errors nor any unexpected results for a fresh installation with database migrations active as PMS starts.
    Can you show me which processes (wide view) are left running? Some do stay running
    Useful links
    When you mean Wide-View, I'm guessing you want the full text for the systemd processes:
       Active: active (running) since Tue 2018-05-29 02:17:32 CDT; 1min 3s ago
      Process: 11652 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" (code=exited, status=0/SUCCESS)
     Main PID: 11654 (sh)
        Tasks: 62 (limit: 4915)
               ├─11654 /bin/sh -c LD_LIBRARY_PATH=/usr/lib/plexmediaserver "/usr/lib/plexmediaserver/Plex Media Server"
               ├─11655 /usr/lib/plexmediaserver/Plex Media Server
               ├─11667 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-4898d7d96/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.13.2.5102-4
               ├─11716 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.13.2.5102-4898d7d96 32600 /waitmutex
               ├─11741 Plex Plug-in [com.plexapp.agents.imdb] /usr/lib/plexmediaserver/Resources/Plug-ins-4898d7d96/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.13.2.5
               └─11789 /usr/lib/plexmediaserver/Plex Relay -p 443 -N -R 0:localhost:32401 -o StrictHostKeyChecking=yes -o UserKnownHostsFile=/var/lib/plexmediaserver/Library/Application Support/Plex Media Ser
    May 29 02:17:32 S5 systemd[1]: Starting Plex Media Server for Linux...
    May 29 02:17:32 S5 systemd[1]: Started Plex Media Server for Linux.
    To confirm please:
    1. This shows the processes which are live (running) and also visible in ps -efl when PMS stops responding?
    2. If so, did you manually grab a tar or ZIP archive of the Logs directory? ( so we catch it in the act )
    Useful links
    Hey Chuck,
    I haven't gotten the Plex Server to stop working/streaming/etc with the 4-movie Test library I captured. I deleted my current library and created a new Test library with a couple more movies (about ~20) and then repeated all the steps you outlined above:
    1. Systemd Status (on first startup): https://pastebin.com/EP1mfs8W
    2. Systemd Status (after first library scan/update): https://pastebin.com/B9DG2jSz
    3. Output of ps -efl (after first library scan/update): https://pastebin.com/76RKSZhA
    4. Logs after First Library Scan: Plex Logs Auto Export.zip
    5. Logs after First Library Scan (manually captured as a tar.gz): Plex Logs Manual Export.tar.gz
    To reiterate, the server doesn't seem to break with the current library, its once I add bigger libraries that stuff breaks. Right now, with the current library of just under 20 movies (18), the server seems to work fine. However, if I point it at my actual movie library (same happens with TV Shows and Music) , then it starts doing what I described above.
    You have something bizarre happening and I can't find it.
    I am beginning to think it's at the OS itself. Being Ubuntu 18.04 it's VERY likely that's the root cause.
    I've been seeing the stupidest problems and I can't do anything about them cause they are in the kernel
    Have you gotten any Ubuntu updates yet?
    Useful links
    edited June 1
    @ChuckPA I should have all the latest Ubuntu18.04 updates downloaded. I regularly make sure to apt update & apt upgrade. I've also got the Canonical Livepatch system enabled just in case.
    Could perhaps uninstalling/removing specific updates help?
    What's strange is I was experiencing very similar issues on Ubuntu 16.04 before wiping the server and starting over.
    EDIT: I also have this upgrade line in my apt update:
    W: Conflicting distribution: https://downloads.plex.tv/repo/deb public InRelease (expected public but got )
    So what can I do? What could be done to help either fix this issue or better understand what and why.
    I was experiencing almost exactly the same issues running with a similar setup on Ubuntu 16.04x so I'm not really sure.
    Thanks for the help thus far, hopefully there is a fix or explanation. :|
    Accepted Answer
    Actually, it's 18.04. It's so fresh out of the box that we're finding bugs everywhere. It should settle down after the first major update
    Last night I had to craft an NFS automount service for one of the Developers. Seems it was forgotten in the nfs-common package distribution.
    Useful links
