Our forum migration to Discourse is underway and scheduled to last through June 21. During the migration, the forums will be read-only, except for a single temporary forum (contents of which will not be getting transferred). Read our announcement post for more information about the forum migration.
Hey folks, there is a new Podcast category for forums https://forums.plex.tv/categories/podcasts
Help re Sonos, Plex, and Ubiquiti Unifi
mpcmpc Members, Plex Pass Posts: 6 Plex Pass
@johnclayton
I am authenticated with Plex in the Sonos app but unable to see my Plex media server in Sonos desktop or mobile controllers. I always see: "No Plex Media Server available"
Can you provide guidance to fix this?
Here is my config:
  • An all Ubiquiti Unifi managed network (USG, UAPs, Cloudkey, managed switches)
  • Verizon Fios with their ONT and router. This means double NAT, which isn't a problem for any other of my network usage
  • Two Synology NAS units, each running PMS 1.13.2.5102. Only one NAS has my music
  • Over a dozen Sonos One speakers
  • Remote access for PMS on the NAS with music is enabled. However, it is not Internet accessible.
  • Secure connections are required (though I have tested with preferred based on your earlier comments)
  • Following your recommendation, I have added two NAS IPs in Plex's network configuration "e.g. https://10.0.0.2:32400, https://10.0.0.3:32400"
  • Lifetime Plex Pass
My understanding with 2.06 is that NAT loopback is no longer required. Which is good because I don't believe Unifi supports this. Port forwarding is an option but I am not currently using it. And I really prefer not to open PMS to the Internet.
However, my understanding is that DNS rebinding is now required. I am unclear whether Unifi supports this based on older threads re Plex in their forum.
Answers
  • virgiliomivirgiliomi Members, Plex Pass Posts: 77 Plex Pass
    edited May 31
    Your Plex server being internet accessible is a requirement too. Sonos devices communicate with cloud-based servers to get info on what music is in your library, so those cloud servers need to be able to connect to your Plex server. While the music is streamed locally (when possible) once it starts playing, remote access from the internet is necessary to browse your library and get to that point.
  • mpcmpc Members, Plex Pass Posts: 6 Plex Pass
    Thank you @virgiilomi. However, the FAQ states:
    Even if you can’t get Remote Access successfully enabled, you should still be okay. So long as you don’t explicitly disable Remote Access, then your server will still be able to set up a “Relay” connection, even if Remote Access isn’t fully configured. Our Relay feature allows a limited connection to be established to your Plex Media Server even if the normal Remote Access isn’t working.
    So, I gather that the relay isn't working. I am not sure what logs to look at to confirm.
    I should add, this did work briefly for me when the Plex for Sonos first left beta. However, it would only play several songs, then error out that it couldn't find the Plex server. It would continue to try to play the next songs in the playlist until stopping. I could then start playback again from within the Sonos controller and it would work. So, something changed from when the GA version of Plex was released that prevents me from even seeing the PMS in Sonos now.
