Our forum migration to Discourse will be going on starting late today June 19 to 21. During the migration, the forums will be read-only, except for a single temporary forum (which will not be getting transferred). Read our announcement post for more information.
Hey folks, there is a new Podcast category for forums https://forums.plex.tv/categories/podcasts
Problems with Settings page not found
philionphilion Posts: 21Members, Plex Pass Plex Pass
I've been having problems with the Plex server and remote connections on a new router, and no my Plex seems completely FUBAR. I deleted and installed a fresh Plex Media Server, started it up.... Plex reports the new service isn't up. When I look at the service, via the browser:
http://127.0.0.1/web/index.html#!/settings/server
I get:
"You must be lost."
"This page doesn't exist."
This is using the pulldown menu Plex > Preferences....
I've never seen this before, and regardless of any remote access problems I've had I've always been able to access plex locally or on the local lan.
Answers
  • sa2000sa2000 Posts: 31,462Members, Plex Pass, Plex Ninja, Plex Team Member Plex Team Member
    edited June 12
    That url does not look right - it should have port 32400
    Could you get a screenshot
    Also get the server logs
    See https://support.plex.tv/articles/200250417-plex-media-server-log-files/
    Could you first try ‘http://127.0.0.1:32400/web
    And then click on settings
    Help given free on forums.            Fee-Based Personal Support & Help.
    _______________________________________________________________________________________
    Plex Support Information              Troubleshooting               FAQs
    Plex Media Server:   Reporting Issues        Plex Web App: Debug Log    Plex Apps: Support pages and Logs    Logs: All Logs
    Please do not send logs by Private Message unless specifically requested to
  • philionphilion Posts: 21Members, Plex Pass Plex Pass
    My mistake: The 32400 was there, but damn Safari was hiding it.
    The underlying problem is that the server hadn't fully started up. It seems the server is taking several minutes before it is ready to handle requests (noticeably longer than when I original installed the server).
    I research why, using the logs referenced above. I'm in there already trying to track down the remote access issues I'm having.
    Thanks,
    • Paul
    Thanks,
    • Paul
    There has been a number of database schema changes recently which would delay the availability of the server until the database changes are completed
    For Remote Access use a dhcp reserved local IP and a port forward in the router and manually specifying the public port in server settings would be the more reliable option
    for troubleshooting - see https://support.plex.tv/articles/200931138-troubleshooting-remote-access/
    If you have issues - raise a separate forum topic with appropriate title for the problem
