PlexConnect running on a QNAP NAS
AndrozAndroz Posts: 8Members, Plex Pass Plex Pass
Hi fellow Plexians!
I've managed to get PlexConnect running on a QNAP TS-459 Pro II (3.8.2) and ATV3 (5.2.1), so I thought to share a short install guide. I'm no hacker why my solutions might no be the most elegant ones, but they work, at least for me. Please provide your experiences.
  1. First, download and extract PlexConnect package (this is release 0.1)
    https://github.com/iBaa/PlexConnect/archive/v0.1-iOS-pre5.1.zip
  2. Then configure the DNS setting on your ATV, see below link, and follow steps 3-5, in the same guide, to edit the "Settings.py" file.
    https://github.com/iBaa/PlexConnect/wiki/OSX-and-ATV-with-5.2-firmware-and-ethernet-internet-connection-installation-guide
  3. Install and activate Python for QNAP. Version 2.7 is available in the QPKG Center.
  4. Check if your web server on the QNAP is running. If so, you might need to change the port 80 to something else or turn off the web server.
  5. Use SSH to log on as admin to the QNAP. Upload all the PlexConnect files to a preferable location. I placed my files here.
    /root/Library/PlexConnect/
    Might be better locations?
  6. Then open up a Terminal window and connect to your QNAP. Locate your folder and execute PlexConnect.py.
    cd /root/Library/PlexConnect
    ​./PlexConnect.py
  7. PlexConnect should now be running and you will see the output in your terminal window. Hopefully without any errors. Mine worked at the first try so I haven't any hints for troubleshooting. On the downside, when you close the terminal you will terminate PlexConnect. But I managed in a simple way to get the PlexConnect autorun on my QNAP, explained in the next steps.
  8. In order to run PlexConnect on NAS startup you need to create a run script that is disguised as QPKG. I followed all steps in the "QPKG-based method" in the guide below.
    http://wiki.qnap.com/wiki/Running_Your_Own_Application_at_Startup
  9. My "autorun.sh" script looks like this.
    #!/bin/sh
    /share/MD0_DATA/.qpkg/Python/bin/python /root/Library/PlexConnect/PlexConnect.py -d
  10. Remember to set the execute bit and then restart your NAS. Hopefully PlexConnect will automatically run when your NAS has booted up.
Good luck! :D
«134567
Comments
  • cpeartcpeart Posts: 2Members, Plex Pass Plex Pass
    Thanks for the detailed worksheet. My SSH skills are near nil and I got stuck at the following step.
    "5. Use SSH to log on as admin to the QNAP. Upload all the PlexConnect files to a preferable location. I placed my files here."
    I'm able to SSH to the QNAP, no problem. How do I create a folder in the root folder and how do I copy the installation python files to that folder? Is this accomplished via the QNAP Web UI or SSH? If via SSH, could you elaborate on the required steps?
    Thanks in advance.
  • robertpolsonrobertpolson Posts: 133Members
    edited June 2013
    treeshaker99 wrote on June 6 2013, 8:15 PM: »
    Thanks in advance.
    1. To create a folder, type "mkdir" and give it a name
    2. I usually copy files to one of my folders on Qnap and then use "cp" command to copy files from /share/HDA_DATA/Multimedia/Inbox to wherever you need to copy things.
    Thanks for the feedback. I was able to use the 'mkdir' command and then after much futzing, I was able to figure out the 'scp' command when logged into Terminal on my Mac.
    scp -r ~/Desktop/PlexConnect-XML_templates/* admin@0.0.0.0:/root/Library/PlexConnect/
    Where 0.0.0.0 is the local address of my QNAP.
    Getting closer.
    Cool, I did not know about "scp" - "The general format for the command to upload to the server"
  • technowartechnowar Posts: 27Members
    edited June 2013
    With item #4. What will happen if my QNAP's web server is running? Is it fine to change my web server's port from 80 to any number? Will this prevent from having a conflict with PlexConnect's?
    So after disabling Web Server of my QNAP, this is the error:
    PlexConnect : ***
    PlexConnect : PlexConnect
    PlexConnect : Press ENTER to shut down.
    PlexConnect : ***
    PlexConnect : IP_self: 192.168.0.3
    PlexGDM : ***
    PlexGDM : looking up Plex Media Server
    PlexGDM : ***
    PlexGDM : servers discovered: 1
    DNSServer : ***
    DNSServer : Starting up.
    DNSServer : intercept trailers.apple.com: 192.168.0.3
    DNSServer : forward other to higher level DNS: 124.106.7.2
    DNSServer : ***
    WebServer : Failed to connect to port 80 (http): [Errno 98] Address already in use
    PlexConnect : WebServer not alive. Shutting down.
    DNSServer : Shutting down.
  • apatel87apatel87 Posts: 40Members, Plex Pass Plex Pass
    I am probably not the best person for this process but I hope you guys can help me. I was able to set this up on my computer so I am not a total noob but have never SSH'ed in my NAS. How do I go about doing that. I am essentially confused from step 4 onwards. thanks
  • nerdynerdy Posts: 27Members, Plex Pass Plex Pass
    I noticed that after disabling the webserver my QNAP started another webserver called Qthttpd within a minute or so. I just killed it with
    killall Qthttpd
    and then started the PlexConnect.py before it kicked in again.
    apatel87 wrote on June 8 2013, 3:05 AM: »
    ssh admin@0.0.0.0
    Change the ip address to that of your qnap.
    I enabled back my Web Server, but this time I changed the port to 888.
    Ran back ./PlexConnect.py and this is the output:
    ./PlexConnect.py
    PlexConnect : ***
    PlexConnect : ***
    PlexGDM : ***
    PlexGDM : ***
    DNSServer : ***
    DNSServer : ***
    WebServer : ***
    WebServer : WebServer: Serving HTTP on 0.0.0.0 port 80.
    WebServer : ***
    It has been like this for around 10 minutes or so. Is there something wrong with this?
    have you set your dns server in your atv to the ipaddress of the qnap?
    Yes. The IP Address of my QNAP is 192.168.0.3 so I changed my aTV3 DNS to 192.168.0.3.
    In Settings.py, I changed 8.8.8.8 to 124.106.7.2, which is the DNS given by my ISP.
    Thanks for that that was really helpful. I am now stuck on Step 5 sorry.
    [~] # mkdir
    BusyBox v1.01 (2013.04.25-16:38+0000) multi-call binary
    Usage: mkdir [OPTION] DIRECTORY...
    Create the DIRECTORY(ies) if they do not already exist
    Options:
    -m set permission mode (as in chmod), not rwxrwxrwx - umask
    -p no error if existing, make parent directories as needed
    This is where I am at. I can now SSH in. I type in mkdir and I get this directory. How do I name the folder? I see the scp command in one of the posts but I am having a hard time with this part
    nerdy wrote on June 8 2013, 3:07 AM: »
    ssh admin@0.0.0.0
    edited June 2013
    apatel87, please follow post #4
    edited June 2013
    technowar wrote on June 8 2013, 3:55 AM: »
    Is it working? The terminal will scroll through as it receives requests from PlexConnect.
    In the Setting.py I also changed the following to my PMS ip.
    10.1.1.212 is my PMS ip so change to your PMS ip.
    def getIP_PMS():  # default IP, if GDM fails... todo: do we need this fall back?
        return '10.1.1.212'
    edited June 2013
    I added Photo to my Sections. I can access the photos from aTV 3's Trailer. But when I try to access the Music section, it displays 'Trailer is unavailable'.
    WebServer : serving application.js
    192.168.0.2 - - [08/Jun/2013 12:32:49] "GET /appletv/us/js/application.js HTTP/1.1" 200 -
    WebServer : serving /share/HDA_DATA/.qpkg/PlexMediaServer/Library/PlexConnect/assets/plexconnect.xml
    192.168.0.2 - - [08/Jun/2013 12:32:49] "GET /plexconnect.xml HTTP/1.1" 200 -
    WebServer : serving .xml: /library/sections
    192.168.0.2 - - [08/Jun/2013 12:32:50] "GET /library/sections HTTP/1.1" 200 -
    WebServer : serving .xml: /channels/all&PlexConnect=Channels
    192.168.0.2 - - [08/Jun/2013 12:32:50] "GET /channels/all&PlexConnect=Channels HTTP/1.1" 200 -
    WebServer : serving /share/HDA_DATA/.qpkg/PlexMediaServer/Library/PlexConnect/assets/search.xml
    192.168.0.2 - - [08/Jun/2013 12:32:50] "GET /search.xml HTTP/1.1" 200 -
    WebServer : serving .xml: /&PlexConnect=Settings
    192.168.0.2 - - [08/Jun/2013 12:32:50] "GET /&PlexConnect=Settings HTTP/1.1" 200 -
    WebServer : serving  /share/HDA_DATA/.qpkg/PlexMediaServer/Library/PlexConnect/assets/settings.js
    192.168.0.2 - - [08/Jun/2013 12:32:50] "GET /settings.js HTTP/1.1" 200 -
    WebServer : serving .xml: /library/sections/1/recentlyAdded?stack=1&X-Plex-Container-Start=0&X-Plex-Container-Size=25&PlexConnect=SectionPreview-artist
    DNSServer : DNS request received!
    DNSServer : Source: ('192.168.0.2', 57082)
    DNSServer : Domain: itunes-cdn.apple.com.akadns.net
    DNSServer : ***forward request
    DNSServer : -> DNS response from higher level
    192.168.0.2 - - [08/Jun/2013 12:32:51] "GET /library/sections/1/recentlyAdded?stack=1&X-Plex-Container-Start=0&X-Plex-Container-Size=25&PlexConnect=SectionPreview-artist HTTP/1.1" 200 -
    DNSServer : Source: ('192.168.0.2', 55611)
    DNSServer : Domain: ax.init-cdn.itunes.apple.com.akadns.net
    192.168.0.2 - - [08/Jun/2013 12:32:52] "GET /library/sections/1 HTTP/1.1" 200 -
    WebServer : serving .xml: /library/sections/1/all
    By the way, is 10.1.1.212 the IP in your aTV's DNS?
    EDIT
    I added a movie having an M4v filetype. I could play it when accessing via web. So I tried to access it using my aTV and finally I could see the thumbnail of the movie, but when there's this 'Trailer is unavailable' error when trying to play it.
  • f00b4rf00b4r Posts: 2,885Members, Plex Pass Plex Pass
    technowar wrote on June 8 2013, 4:25 AM: »
    EDIT
    If you press the play button rather than the middle select button does it play (i.e. you skip the pre play screen)?
    This issue has been fixed i the latest source code.
    Plex @ aTV - think different: PlexConnect
    -> the missing link between Plex Media Server and your AppleTV - 2 or 3, jailbroken or not.
    Wiki: click here
    How to report an issue: click here
    Github (download the app): click here
    Donations (Paypal): [US-$], [EUR]
    Which play button do you mean?
    edited June 2013
    technowar wrote on June 8 2013, 2:08 PM: »
    On the ATV remote there is a play button (bottom right) and a select button (in middle of black circle).
    If you select a movie or episode it brings you to a pre-play screen.
    If you hit the play button when on a movie or episode it will skip the pre-play screen and immediately start playing.
    On Elan's branch and some of the older main branch source code there is a bug in the pre-play screen that causes an issue like described.
    Wiki: click here
    It is very likely the bug that i described above - the instructions at the top link to Elan's branch.
    There have been a lot of bug fixes and changes in the main branch since then!
    Not too long before Elan's eye candy is merged back in ;)
    Wiki: click here
    edited June 2013
    I pressed the center button instead of the small play/pause button. Needs to check this out tomorrow. Will keep you posted.
    By the way, who's Elan? Any link to the updated PlexConnect?
«134567
