Hey folks, there is a new Podcast category for forums https://forums.plex.tv/categories/podcasts
RGB Limited settings
DalsimDalsim Posts: 2Members
Hello,
For some reason Rasplex starts up in the limited RGB colorspace on my Raspberry Pi Model B on my 1080p HD Samsung LCD TV.
I was wondering if there is anywhere I can change the setting so Rasplex starts up in 0-255 (Full RGB) colorspace as the colors look washed out and blacks are currently grey. I had to change the settings when I used Openelec on the Pi but cannot find it in Rasplex.
Is there a Xorg.conf file or another settings file? Or do I perhaps need to create one? If so, can anyone tell me what I need to put in it and where it needs to go on the Pi?
Any help would be appreciated.
Thank you.
Dalsim
Best Answer
  • daniel_karlssondaniel_karlsson Posts: 4Members, Plex Pass Plex Pass
    Accepted Answer
    You can edit this in your config.txt, the setting is called hdmi_pixel_encoding and should have a value of 2 for full rgb
Answers
    Accepted Answer
  • DalsimDalsim Posts: 2Members
    Ah, Superb!
    That was exactly the information i needed. I could not find an existing ""hdmi_pixel_encoding" line, so I added one under "the "hdmi_drive" line and all is working perfectly now.
    Thank you for hour help Daniel and for such a quick reply. Really appreciated.
  • RooDBwoYRooDBwoY Posts: 9Members ✭✭
    I’ll be trying this on mine in a minute too. Thanks!
    Worked like a charm, thanks again!
  • gary_parkergary_parker Posts: 4Members, Plex Pass Plex Pass
    Just wanted to add that I was having exactly the same problem with a RasPi3 going through a Sony HT-RT5 to a Panasonic Viera 50CS520 TV. The left hand side of the picture was very washed out and low contrast. Adding this line to my config.txt fixed the problem.
