EAE timeout! EAE not running, or wrong folder?
tcf909tcf909 Posts: 33Members, Plex Pass Plex Pass
edited April 2017 in Docker
I'm also having trouble with EAE using latest docker image. It appears to be using tmp, which has all permissions available. Haven't had a problem like this until 1.5.x. Log and subsequent info below:
I also noticed that EAE is using /tmp instead of my set transcode folder. Given the highly configurable nature of a docker container (and the potential horrible performance implications of /tmp being on an overlay filesystem, I would definitely hope that EAE would honor the set transcode folder settings (or provide a way to specify the EAE transcode folders).
My transcode folder is set to /config/transcode (and I've verified it is being used). Although, the incorrect use of /tmp does not explain the problem as a whole, just a side note.
Apr 22, 2017 23:35:52.000 [0x7f09873fe700] ERROR - [Transcoder] [ac3_eae @ 0x16f1560] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder/Convert to WAV (to 8ch or less)/7jpjb945mywgwxq4j60x82kk_8446-1-3.wav' Apr 22, 2017 23:35:52.006 [0x7f097c3fb700] ERROR - [Transcoder] [ac3_eae @ 0x16f1560] error reading output Apr 22, 2017 23:35:52.016 [0x7f09687fe700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
root@plex-1689959742-tdhls:/tmp# ls -alR /tmp
/tmp:
total 12
drwxrwxrwt 1 root root 4096 Apr 22 23:35 .
drwxr-xr-x 1 root root 4096 Apr 21 09:38 ..
drwxrwxrwx 3 root plex 4096 Apr 22 23:26 pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa:
total 12
drwxrwxrwx 3 root plex 4096 Apr 22 23:26 .
drwxrwxrwt 1 root root 4096 Apr 22 23:35 ..
drwxr-xr-x 8 root plex 4096 Apr 22 23:26 EasyAudioEncoder
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder:
total 32
drwxr-xr-x 8 root plex 4096 Apr 22 23:26 .
drwxrwxrwx 3 root plex 4096 Apr 22 23:26 ..
drwxr-xr-x 2 root plex 4096 Apr 22 23:26 Convert to Dolby Digital (High Quality - 640 kbps)
drwxr-xr-x 2 root plex 4096 Apr 22 23:26 Convert to Dolby Digital (Low Quality - 384 kbps)
drwxr-xr-x 2 root plex 4096 Apr 22 23:26 Convert to Dolby Digital Plus (High Quality - 384 kbps)
drwxr-xr-x 2 root plex 4096 Apr 22 23:26 Convert to Dolby Digital Plus (Max Quality - 1024 kbps)
drwxr-xr-x 2 root plex 4096 Apr 22 23:26 Convert to WAV (to 2ch or less)
drwxr-xr-x 2 root plex 4096 Apr 22 23:35 Convert to WAV (to 8ch or less)
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder/Convert to Dolby Digital (High Quality - 640 kbps):
total 8
drwxr-xr-x 2 root plex 4096 Apr 22 23:26 .
drwxr-xr-x 8 root plex 4096 Apr 22 23:26 ..
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder/Convert to Dolby Digital (Low Quality - 384 kbps):
total 8
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder/Convert to Dolby Digital Plus (High Quality - 384 kbps):
total 8
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder/Convert to Dolby Digital Plus (Max Quality - 1024 kbps):
total 8
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder/Convert to WAV (to 2ch or less):
total 8
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder/Convert to WAV (to 8ch or less):
total 80
drwxr-xr-x 2 root plex  4096 Apr 22 23:35 .
-rw-r--r-- 1 root plex 35840 Apr 22 23:35 7jpjb945mywgwxq4j60x82kk_8446-1-6.ac3
-rw-r--r-- 1 root plex 35840 Apr 22 23:35 7jpjb945mywgwxq4j60x82kk_8446-1-7.ac3
root@plex-1689959742-tdhls:/tmp# ps auxwwwf
USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
root      6269  0.0  0.0  20060  3392 ?        Ss   22:50   0:00 /bin/bash
root      8463  0.0  0.0  36128  3108 ?        R+   23:36   0:00  \_ ps auxwwwf
root         1  0.0  0.0    196     4 ?        Ss   Apr21   0:00 s6-svscan -t0 /var/run/s6/services
root        23  0.0  0.0    196     4 ?        S    Apr21   0:00 s6-supervise s6-fdholderd
root       265  0.0  0.0    196     4 ?        S    Apr21   0:00 s6-supervise plex_advertise_dns_update
root       268  0.0  0.0  19980  3372 ?        Ss   Apr21   0:03  \_ bash ./run
root      8461  0.0  0.0   6084   748 ?        S    23:35   0:00      \_ sleep 60
root       266  0.0  0.0    196    12 ?        S    Apr21   0:00 s6-supervise plex
root      6393  0.0  0.0   4508   756 ?        Ss   22:53   0:00  \_ /bin/sh -c LD_LIBRARY_PATH=/usr/lib/plexmediaserver /usr/lib/plexmediaserver/Plex\ Media\ Server
root      6395  3.7  0.2 768840 68076 ?        Sl   22:53   1:35      \_ /usr/lib/plexmediaserver/Plex Media Server
root      6407  0.4  0.2 1797328 64624 ?       SNl  22:53   0:10          \_ Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.5.5.3634-995f1dead /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/System.bundle
root      6454  0.0  0.0 438316  5964 ?        Sl   22:53   0:00          \_ /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.5.5.3634-995f1dead 32600 /waitmutex
root      6953  0.4  0.1 356224 39036 ?        SNl  23:04   0:07          \_ /usr/lib/plexmediaserver/Plex Media Scanner --index --analyze --section 1 --log-file-suffix  Analysis
root      7128  0.5  0.1 1171224 43920 ?       Sl   23:12   0:07          \_ Plex Plug-in [com.plexapp.agents.thetvdb] /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.5.5.3634-995f1dead /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/TheTVDB.bundle
root      7193  0.1  0.1 1023196 33680 ?       Sl   23:12   0:02          \_ Plex Plug-in [com.plexapp.agents.plexthememusic] /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.5.5.3634-995f1dead /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/PlexThemeMusic.bundle
root      7217  0.4  0.1 951228 35496 ?        Sl   23:12   0:05          \_ Plex Plug-in [com.plexapp.agents.opensubtitles] /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.5.5.3634-995f1dead /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/OpenSubtitles.bundle
root      8037  0.0  0.0  21576  2180 ?        S    23:26   0:00          \_ Plex EAE Service
root      8325 15.2  0.1 809260 51208 ?        SNl  23:32   0:34          \_ /usr/lib/plexmediaserver/Plex Transcoder -codec:v h264 -i /data/Media/Shows/Firefly/Season 01/Firefly - S01E02 - Bushwhacked [720p, x264, AAC].mkv -threads 0 -nostats -q 3 -loglevel quiet -progressurl http://127.0.0.1:32400/video/:/transcode/session/bif/progress -filter_complex [0:V:0] scale=w=320:h=240:force_original_aspect_ratio=decrease [out] -map [out] -r 0.5 /config/Library/Application Support/Plex Media Server/Media/localhost/e/95cb461ede08a743fc8adec464f02a6e9d4944e.bundle/Contents/Indexes/tmp/img-%06d.jpg
root      8442  4.8  0.1 307212 55276 ?        SNl  23:35   0:04          \_ /usr/lib/plexmediaserver/Plex Media Scanner --scan --refresh --section 2
root      8446 39.7  0.0 221960 21744 ?        Rl   23:35   0:27          \_ /usr/lib/plexmediaserver/Plex Transcoder -codec:0 h264 -codec:1 ac3_eae -eae_prefix:1 7jpjb945mywgwxq4j60x82kk_ -noaccurate_seek -i /data/Media/Shows/Lethal Weapon/Season 01/Lethal Weapon - S01E03 - Best Buds [720p, x264, AC3, HDTV].mkv -map 0:0 -metadata:s:0 language=eng -codec:0 copy -map 0:1 -codec:1 aac -ar:1 48000 -channel_layout:1 stereo -b:1 256k -f segment -segment_format matroska -segment_format_options live=1 -segment_time 1 -segment_header_filename header -segment_start_number 0 -segment_list http://127.0.0.1:32400/video/:/transcode/session/7jpjb945mywgwxq4j60x82kk/seglist -segment_list_type csv -segment_list_size 2147483647 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 chunk-%05d -start_at_zero -copyts -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/7jpjb945mywgwxq4j60x82kk/progress
root@plex-1689959742-tdhls:/tmp# df -h
Filesystem        Size  Used Avail Use% Mounted on
overlay            19G  5.6G   13G  32% /
tmpfs              15G     0   15G   0% /dev
tmpfs              15G     0   15G   0% /sys/fs/cgroup
/dev/xvdbb        118G   18G   95G  17% /config
/dev/xvdbc        246G  128G  107G  55% /data
/dev/xvda1         19G  5.6G   13G  32% /transcode
shm                64M  8.0K   64M   1% /dev/shm
tmpfs              15G   12K   15G   1% /run/secrets/kubernetes.io/serviceaccount
Local:Vault       1.1P  128G  1.1P   1% /data/Media
ACD_VAULT:/Media  1.0P     0  1.0P   0% /data/.Vault
Answers
  • gbooker02gbooker02 Posts: 680Members, Plex Employee, Plex Pass, Plex Ninja Plex Employee
    Given the lack of logs, I have to guess that your issue is the same as this one: https://forums.plex.tv/discussion/comment/1409740/#Comment_1409740
  • tcf909tcf909 Posts: 33Members, Plex Pass Plex Pass
    I'll give the fix a try, see if it resolves, and let you know. Thanks!
  • j9ac9kj9ac9k Posts: 34Members, Plex Pass Plex Pass
    I have the same error, here are the logs
    I ended up reinstalling the official docker container (previously was using the linuxserver.io docker container) and all works.
    I'm still having issues with anything past 1.5.1.
    After some period of time:
    Jun 02, 2017 10:56:38.000 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-31.wav'
    /tmp has all the right permissions, but I also hope /tmp would not be used as my transcode directory is set to /config/transcode (a special ssd volume).
    I have also increased the number of watches per another thread:
    sysctl -w fs.inotify.max_user_watches=100000
    Full Log:
    Jun 02, 2017 10:55:05.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-0.wav'
    Jun 02, 2017 10:55:05.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:05.002 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:08.000 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-1.wav'
    Jun 02, 2017 10:55:08.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:08.002 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:11.000 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-2.wav'
    Jun 02, 2017 10:55:11.002 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:11.003 [0x7fef84ffd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:14.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-3.wav'
    Jun 02, 2017 10:55:14.001 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:14.002 [0x7fef84ffd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:14.303 [0x7fefaefff700] ERROR - EventSource: Retrying in 15 seconds.
    Jun 02, 2017 10:55:17.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-4.wav'
    Jun 02, 2017 10:55:17.002 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:17.002 [0x7fef84ffd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:20.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-5.wav'
    Jun 02, 2017 10:55:20.001 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:20.003 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:23.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-6.wav'
    Jun 02, 2017 10:55:23.002 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:23.002 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:26.000 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-7.wav'
    Jun 02, 2017 10:55:26.001 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:26.002 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:29.000 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-8.wav'
    Jun 02, 2017 10:55:29.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:29.002 [0x7fefaffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:30.803 [0x7fefaefff700] ERROR - EventSource: Retrying in 15 seconds.
    Jun 02, 2017 10:55:32.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-9.wav'
    Jun 02, 2017 10:55:32.002 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:32.003 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:35.000 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-10.wav'
    Jun 02, 2017 10:55:35.002 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:35.002 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:38.001 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-11.wav'
    Jun 02, 2017 10:55:38.002 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:38.003 [0x7fefa1bfd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:41.000 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-12.wav'
    Jun 02, 2017 10:55:41.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:41.002 [0x7fef84ffd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:44.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-13.wav'
    Jun 02, 2017 10:55:44.001 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:44.002 [0x7fefaffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:47.000 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-14.wav'
    Jun 02, 2017 10:55:47.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:47.002 [0x7fefaffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:47.284 [0x7fefae7fe700] ERROR - EventSource: Retrying in 15 seconds.
    Jun 02, 2017 10:55:50.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-15.wav'
    Jun 02, 2017 10:55:50.002 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:50.003 [0x7fefa1bfd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:53.001 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-16.wav'
    Jun 02, 2017 10:55:53.001 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:53.002 [0x7fefaffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:56.001 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-17.wav'
    Jun 02, 2017 10:55:56.002 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:56.002 [0x7fefaffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:55:58.788 [0x7fef9ebff700] ERROR - Throttle: timed out trying to read chunk -1
    Jun 02, 2017 10:55:59.002 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-18.wav'
    Jun 02, 2017 10:55:59.003 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:55:59.007 [0x7fefa1bfd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:56:02.000 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-19.wav'
    Jun 02, 2017 10:56:02.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:56:02.002 [0x7fefa1bfd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:56:03.776 [0x7fefae7fe700] ERROR - EventSource: Retrying in 15 seconds.
    Jun 02, 2017 10:56:05.000 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-20.wav'
    Jun 02, 2017 10:56:05.002 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:56:05.002 [0x7fefa1bfd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:56:08.001 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-21.wav'
    Jun 02, 2017 10:56:08.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:56:08.002 [0x7fef85fff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:56:11.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-22.wav'
    Jun 02, 2017 10:56:11.002 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:56:11.003 [0x7fefa1bfd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:56:14.000 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-23.wav'
    Jun 02, 2017 10:56:14.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:56:14.002 [0x7fefa1bfd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:56:17.001 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-24.wav'
    Jun 02, 2017 10:56:17.002 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:56:17.002 [0x7fef85fff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:56:20.000 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-25.wav'
    Jun 02, 2017 10:56:20.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:56:20.002 [0x7fefaffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:56:20.248 [0x7fefae7fe700] ERROR - EventSource: Retrying in 15 seconds.
    Jun 02, 2017 10:56:23.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-26.wav'
    Jun 02, 2017 10:56:23.002 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:56:23.002 [0x7fefaffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:56:26.000 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-27.wav'
    Jun 02, 2017 10:56:26.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:56:26.002 [0x7fef85fff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:56:29.000 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-28.wav'
    Jun 02, 2017 10:56:29.001 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:56:29.002 [0x7fef85fff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:56:32.000 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-29.wav'
    Jun 02, 2017 10:56:32.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:56:32.002 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:56:35.000 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-30.wav'
    Jun 02, 2017 10:56:35.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:56:35.002 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:56:36.738 [0x7fefaefff700] ERROR - EventSource: Retrying in 15 seconds.
    Jun 02, 2017 10:56:38.001 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
    Jun 02, 2017 10:56:38.002 [0x7fef85fff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
    Jun 02, 2017 10:56:40.847 [0x7fefb13ff700] ERROR - JobManager: child process killed by signal: 9 (Killed)
    Jun 02, 2017 10:56:40.891 [0x7fefaefff700] ERROR - [TranscodeOutputStream] Streaming Session 0x7fefa2cebce0 appears to have died from under us
    Jun 02, 2017 10:56:40.915 [0x7fef87fff700] WARN - Got a request to stop a transcode session without a session GUID (or with an invalid one).
    To add, a quick visual inspection of the /tmp directory showed .a number of the files being asked for there (and then would vanish):
    root@plex-4286764477-lwdkf:/tmp# find
    ./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36
    ./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder
    ./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to Dolby Digital (Low Quality - 384 kbps)
    ./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)
    ./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-12.ac3
    ./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-13.ac3
    ./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to Dolby Digital Plus (Max Quality - 1024 kbps)
    ./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 2ch or less)
    ./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to Dolby Digital Plus (High Quality - 384 kbps)
    ./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to Dolby Digital (High Quality - 640 kbps)
