Low framerate on WP8 - Nokia Lumia 920
I've just set up the Plex server on a Windows 8 machine and the Plex WP7 app on my Nokia Lumia 920. I love the look and feel of everything and I'm very impressed by the library management.
Everything has worked very well so far except that and I've been unable to solve a problem with a very low framerate. It seems to not want to exceed ~15fps.
I've tried changing the stream quality but so far this has had no affect on the framerate.
I'm really excited about being able to use Plex on WP8 and I'd love any tips or ideas as to how I can resolve this issue.
Comments
  • JSSRJSSR Members, Plex Pass Posts: 5 Plex Pass
    I'm also having the same issue on the same phone.
  • justinhowjustinhow Members, Plex Pass Posts: 156 Plex Pass
    edited December 2012
    I have noticed that when transcoding certain mp4 videos the processor is running very high (80%).
    Odd thing is that my SD mp4 files use more server transcoding power than my 720p mp4 files.
    Check whether the server is close to 100% out when you have these slow frame rates.
    PS I am using WP8 and a Nokia 920 and play back is fine as I have a powerful Core i7 proc. Using latest PMS 0.9.7.8
  • mdmagnussonmdmagnusson Members, Plex Pass Posts: 4
    Thank you for the reply. The server version I'm running is 0.9.8.8. I've checked the CPU load during transcoding and it never goes above 27%. The server is running on a Windows 8 system with an Intel i7 2600k processor, no particular load on the 802.11n wireless network. If there's a bottleneck on the server I cant find it.
    When I run the Windows 8 (desktop) Plex client the framerate/transcoding is perfect.
    I'm really at a loss as to what the problem is.
    Ok, I finally figured out the problem and in my case it was very much human error. So for anyone else experiencing the same problem this is what I was **** up:
    I was working under the incorrect assumption that playback quality was defined only on the server and not in the client. As it turns out the the client settings are very low by default even for Wi-Fi and as soon as I tuned them up the frame rate was excellent. I hadn't even realized configuring the streaming quality client side was an option.
    I hope this helps someone else out in the future.
