Jump to content
PleXBMC client for XBMC
  • Please log in to reply
2380 replies to this topic
#2361 saitoh183
saitoh183
    Dedicated Member
  • Members
  • PipPipPip
  • 145 posts
Posted 24 May 2015 - 04:07 AM
For me it's very rare to get PlexBMC script errors with Amber in any normal usage, except that it often happens directly on launching Kodi, which I ascribe to some critical race condition between the initialization of the PlexBMC addon vs the initialization of Kodi resources that the addon needs. But with Titan I get this error every time I return to the main menu from any submenu or media section as well as every time I open the Kodi 'Settings' menu.
The fact that I get these errors and you don't must be due to some difference beween our setups or their configuration.
I just noticed that I'm not using the latest PlexBMC version on the test system (which I thought I did), so possibly this has messed up my results.
I'll update to the latest PlexBMC version from hippojay's github pages now, to see if this improves my results.
Best regards: dlanor
Maybe if you see my log file, you could tell me what is wrong?
This is a log with Amber enabled and plexbmc script error everytime i try to access Tv Shows
http://pastebin.com/1naC86g8
#2362 dlanor
dlanor
    Plex Star
  • Members
  • PipPipPipPipPipPip
  • 1818 posts
Posted 24 May 2015 - 04:26 AM
Sorry about the confusion! Apparently most of the problems were due to me having missed updating PlexBMC on the system where I tested the Titan skin.
I've now installed the latest of hippojay's PlexBMC betas, which is 4.0.0~beta4, and with this version the Titan skin works much better.
But it's still not perfect as I can't find my "TV Shows" section anywhere. There is a section entry named "TV Shows", but it's empty and I assume it's a placeholder for the native XBMC library's 'TV Shows' (which I don't use), just like there is an extra "Movies' entry which is also empty, in addition to the real "Movies" entry where I find all the movies of my Plex library, and also some other such empty sections. Those 'native' entries with empty sections appear below/after the list of working entries for my Plex libraries (using Titan's vertical menu layout), which however do not include my "TV Shows" section.
Possibly there is some limit on the number of Plex sections that can be included by Titan, and since I have several custom sections (which are accessible in Titan), and "TV Shows" is the last Plex library section alphabetically, a limit on the section count could be responsible for its exclusion.
It's also possible that I've missed some configuration option that affects what Plex sections get imported, as I'm still unaccustomed to this skin and its features.
Edit:
Further testing with attempts to use the "Configure Shortcuts" submenu has shown that the media category "PlexBMC Collections" only contains the first 10 of my media sections, so apparently 10 is the limit for Plex sections to be included, which means that I'd have to reorganize my PMS library in order to access my "TV Shows" section through this skin. And that's something I'm not going to do. So my use of this skin is dependent on finding a way to raise that limit.
#2363 saitoh183
saitoh183
    Dedicated Member
  • Members
  • PipPipPip
  • 145 posts
Posted 24 May 2015 - 04:30 AM
But it's still not perfect as I can't find my "TV Shows" section anywhere. There is a section entry named "TV Shows", but it's empty and I assume it's a placeholder for the native XBMC library's 'TV Shows' (which I don't use), just like there is an extra "Movies' entry which is also empty, in addition to the real "Movies" entry where I find all the movies of my Plex library, and also some other such empty sections. Those 'native' entries with empty sections appear below/after the list of working entries for my Plex libraries, which however does not include my "TV Shows" section.
Settings > Skin Settings > Configure Shortcuts is what your looking for
I tried in Amber again and i cant open any library set as TV shows (anime, French tv and Tv shows) but i can open them just fine under titan (even if it is somewhat slow to load content)
Did you have a look at my log?
#2364 saitoh183
saitoh183
    Dedicated Member
  • Members
  • PipPipPip
  • 145 posts
Posted 24 May 2015 - 04:44 AM
Was able to figure out the error in Amber. I was the the setting in Plexbmc to force views that was causing the script failure. Since there isnt any for titan , everything was working. This was also effecting the speed at which the content was loading in titan...now my only issues is to figure out why banners arent working.
#2365 dlanor
dlanor
    Plex Star
  • Members
  • 1818 posts
Posted 24 May 2015 - 05:12 AM
That's very odd, as I've never had any problem using TV shows from Amber.
I have three media sections of that type. Two which are scanned using normal PMS agents, and one which is scanned only with the special agent "Personal Media Shows" (so I have full control over all metadata). All three work perfectly in Amber, and always have...
Two of them work in Titan as well, apparently because their names make them be sorted as two of the first ten Plex sections.
Those are "Barnserier (Svenska)" and "Doc Shows". But the main show section is named "TV Shows" which makes it be sorted beyond the tenth entry.
And apparently that makes Titan ignore it (and any others beyond the tenth).
I did, but I couldn't make out what's happening. Over 8 megabytes of fairly cryptic text requires someone used to this particular log format to make sense of the contents.
Btw: I see from the quote you made of my post that you probably missed some of the info I added to it by editing the post, so please read it again.
It appears that my current problem to access Plex "TV Shows" in Titan is due to a limit on the number of Plex sections used.
Another oddity, since forced views work fine for me in Amber. I always set most of them to "Big Panel", except for "Season View" and "Music View" which I set to "Icons".
Well, banners aren't well supported by Plex, as far as I know. (Since the native skins never used banners.)
So it could just be that your PMS server hasn't downloaded the kind of banners Titan wants in its metadata scans...
When I tried it just now, the 'banners' produced were just brutal cutouts from the normal fanart, with superimposed titles.
#2366 saitoh183
saitoh183
    Dedicated Member
  • Members
  • PipPipPip
  • 145 posts
Posted 24 May 2015 - 12:51 PM
In titan I know that banners are not added. Made author aware. But I saw Amber with banners in the other plexbmc thread and I have banners for all my shows in the server
#2367 dlanor
dlanor
    Plex Star
  • Members
  • 1818 posts
Posted 24 May 2015 - 03:22 PM
In any case I think my experiments with the Titan skin are now a closed chapter.
This skin is currently limited to a maximum of 10 Plex sections, which makes it unusable for me.
I could live with losing my "Photos" section. (This would be section number 11.)
But losing all access to "TV shows" is unacceptable. (That would be section number 12.)
It's a powerful skin for those with only the 'standard' Plex sections.
But for anyone with several custom sections the limit on 10 Plex sections can make it useless.
#2368 saitoh183
saitoh183
    Dedicated Member
  • Members
  • PipPipPip
  • 145 posts
Posted 24 May 2015 - 03:42 PM
you where unable to add the additional sections via Configure Shortcuts?
#2369 dlanor
dlanor
    Plex Star
  • Members
  • 1818 posts
Posted 24 May 2015 - 04:18 PM
Yes. I did find all the necessary commands, but the list from which I can select Plex media sections only contains 10 entries.
Those entries correspond to the 10 first of my Plex media sections when sorted alphabetically.
My "Photos" and "TV Shows" would have been the 11'th and 12'th entries if present.
So it's clear that the current Titan skin imposes a limit of at most 10 Plex media sections imported into its lists.
I've made a post about this matter in that other forum you linked to earlier, and there I also replied to a post of yours about the 'banner issue'.
Hopefully Marcel can modify the section limit, or suggest some other workaround that will allow Titan to work well for me.
Edit:
I should clarify that I can define a shortcut to my "TV Shows" by navigating through the addons link, instead of  using the "PlexBMC Collections" list, but when I do that the new home menu entry does NOT work right. No 'recently added' or 'on deck' fanouts, since the skin doesn't recognize it as a proper media section. It's just a shortcut to the main list of the section, just as we can use in any skin with a 'favorites' list, without any specific Plex support. So this is just a 'non-support' workaround. And thus unsatisfactory.
Another problem with this skin (and most XBMC skins) is the lack of forced viewmodes.
I have well over one thousand TV shows in my library, and I hate the default viewmodes for Season and episode lists.
This means that in order to configure a skin which memorizes modes individually per show, I must perform well over two thousand individual mode selections...
#2370 RockyCJC
RockyCJC
    Member
  • Members
  • PipPip
  • 45 posts
Posted 27 May 2015 - 06:27 PM
I am running the latest stable version of Kodi (14.2), latest PleXBMC from Hippojay's github, and the latest update from the repo for Amber (17).
When I try to open up Kodi, the screen flickers but my libraries do not appear and I get a Script Failed error for Plexbmc. I still have access to my Plex libraries because if I go into the add on through the add ons menu I can see the sections on my server, I am just not seeing them on the main screen. The following is the kodi log I took :
01:17:42 T:1783596656 NOTICE: special://profile/ is mapped to: special://masterprofile/
01:17:42 T:1783596656 NOTICE: -----------------------------------------------------------------------
01:17:42 T:1783596656 NOTICE: Starting Kodi (14.2 Git:2015-03-26-7cc53a9-dirty). Platform: Android ARM 32-bit
01:17:42 T:1783596656 NOTICE: Using Release Kodi x32 build
01:17:42 T:1783596656 NOTICE: Kodi compiled Mar 26 2015 by GCC 4.8.0 for Android ARM 32-bit API level 14 (API level 14)
01:17:42 T:1783596656 NOTICE: Running on Matricom G-Box Q with Android 4.4.2 API level 19, kernel: Linux ARM 32-bit version 3.10.33
01:17:42 T:1783596656 NOTICE: FFmpeg version: 14.2rc1-Helix-5-g7cc53a9-xbmc-2.4.6-Helix
01:17:42 T:1783596656 NOTICE: Host CPU: ARMv7 Processor rev 1 (v7l), 2 cores available
01:17:42 T:1783596656 NOTICE: Product: matricom_k200, Device: k200, Board: k200 - Manufacturer: Matricom, Brand: G-Box, Model: G-Box Q, Hardware: amlogic
01:17:42 T:1783596656 NOTICE: ARM Features: Neon enabled
01:17:42 T:1783596656 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
01:17:42 T:1783596656 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
01:17:42 T:1783596656 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
01:17:42 T:1783596656 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
01:17:42 T:1783596656 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
01:17:42 T:1783596656 NOTICE: The executable running is:
01:17:42 T:1783596656 NOTICE: Local hostname: localhost
01:17:42 T:1783596656 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
01:17:42 T:1783596656 NOTICE: load settings...
01:17:42 T:1783596656 DEBUG: static int CAndroidFeatures::GetVersion(): android.os.Build.VERSION 19
01:17:42 T:1783596656 NOTICE: aml_present, rtn(0)
01:17:42 T:1783596656 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
01:17:42 T:1783596656 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
01:17:42 T:1783596656 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
01:17:42 T:1783596656 NOTICE: Found 1 Lists of Devices
01:17:42 T:1783596656 NOTICE: Enumerated AUDIOTRACK devices:
01:17:42 T:1783596656 NOTICE: Device 1
01:17:42 T:1783596656 NOTICE: m_deviceName : AudioTrack
01:17:42 T:1783596656 NOTICE: m_displayName : android
01:17:42 T:1783596656 NOTICE: m_displayNameExtra: audiotrack
01:17:42 T:1783596656 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
01:17:42 T:1783596656 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
01:17:42 T:1783596656 NOTICE: m_sampleRates : 48000
01:17:42 T:1783596656 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
01:17:42 T:1783596656 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
01:17:42 T:1783596656 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
01:17:42 T:1783596656 NOTICE: Default DVD Player: dvdplayer
01:17:42 T:1783596656 NOTICE: Default Video Player: dvdplayer
01:17:42 T:1783596656 NOTICE: Default Audio Player: paplayer
01:17:42 T:1783596656 NOTICE: Disabled debug logging due to GUI setting. Level 0.
01:17:42 T:1783596656 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
01:17:42 T:1783596656 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
01:17:42 T:1783596656 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
01:17:42 T:1783596656 NOTICE: Loaded playercorefactory configuration
01:17:42 T:1783596656 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
01:17:42 T:1783596656 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
01:17:42 T:1802312632 NOTICE: Thread ActiveAE start, auto delete: false
01:17:42 T:1802390096 NOTICE: Thread AESink start, auto delete: false
01:17:42 T:1783596656 NOTICE: Running database version Addons16
01:17:42 T:1783596656 NOTICE: ADDONS: Using repository repository.xbmc.org
01:17:42 T:1783596656 ERROR: Unable to load libcec.so, reason: (null)
01:17:42 T:1783596656 ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
01:17:42 T:1802300440 NOTICE: Thread PeripBusUSB start, auto delete: false
01:17:42 T:1783596656 WARNING: aml_permissions: missing su, playback might fail
01:17:42 T:1783596656 NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: android
01:17:42 T:1783596656 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
01:17:42 T:1783596656 NOTICE: Previous line repeats 1 times.
01:17:42 T:1783596656 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
01:17:42 T:1783596656 NOTICE: Found (1920x1080@60.000000) at 16, setting to RES_DESKTOP at 16
01:17:42 T:1783596656 NOTICE: Checking resolution 16
01:17:42 T:1783596656 NOTICE: GL_VENDOR = ARM
01:17:42 T:1783596656 NOTICE: GL_RENDERER = Mali-450 MP
01:17:42 T:1783596656 NOTICE: GL_VERSION = OpenGL ES 2.0
01:17:42 T:1783596656 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
01:17:42 T:1783596656 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug
01:17:42 T:1783596656 NOTICE: No Joystick name specified, loading default map
01:17:42 T:1783596656 NOTICE: Previous line repeats 36 times.
01:17:42 T:1783596656 NOTICE: Running database version ViewModes6
01:17:42 T:1783596656 NOTICE: Running database version Textures13
01:17:42 T:1783596656 NOTICE: Running database version MyMusic48
01:17:43 T:1783596656 NOTICE: Running database version MyVideos90
01:17:43 T:1783596656 NOTICE: Running database version TV26
01:17:43 T:1783596656 NOTICE: Running database version Epg8
01:17:43 T:1783596656 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
01:17:43 T:1783596656 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
01:17:43 T:1783596656 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
01:17:43 T:1783596656 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
01:17:43 T:1844686400 NOTICE: Thread LanguageInvoker start, auto delete: false
01:17:43 T:1783596656 NOTICE: Previous line repeats 2 times.
01:17:43 T:1783596656 NOTICE: initialize done
01:17:43 T:1783596656 NOTICE: Running the application...
01:17:43 T:1783596656 NOTICE: starting zeroconf publishing
01:17:43 T:1783596656 NOTICE: starting upnp renderer
01:17:43 T:1848178632 NOTICE: Thread LanguageInvoker start, auto delete: false
01:17:43 T:1849449440 NOTICE: Thread JobWorker start, auto delete: true
01:17:43 T:1849243360 NOTICE: Thread ZerocconfEmbedded start, auto delete: false
01:17:43 T:1783596656 NOTICE: ES: Starting event server
01:17:43 T:1854962672 NOTICE: Thread TCPServer start, auto delete: false
01:17:43 T:1854959208 NOTICE: Thread EventServer start, auto delete: false
01:17:43 T:1854959208 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
01:17:43 T:1854959208 NOTICE: UDP: Listening on port 9777
01:17:43 T:1783596656 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
01:17:43 T:1783596656 NOTICE: GL_VENDOR = ARM
01:17:43 T:1783596656 NOTICE: GL_RENDERER = Mali-450 MP
01:17:43 T:1783596656 NOTICE: GL_VERSION = OpenGL ES 2.0
01:17:43 T:1783596656 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
01:17:43 T:1783596656 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug
01:17:43 T:1815986920 NOTICE: Thread AirPlayServer start, auto delete: false
01:17:43 T:1849399448 NOTICE: Thread JobWorker start, auto delete: true
01:17:43 T:1844687328 NOTICE: -->Python Interpreter Initialized<--
01:17:44 T:1870235864 NOTICE: Previous line repeats 3 times.
01:17:44 T:1870235864 NOTICE: Thread JobWorker start, auto delete: true
01:17:44 T:1891965584 NOTICE: Thread LanguageInvoker start, auto delete: false
01:17:44 T:1892547944 NOTICE: Previous line repeats 2 times.
01:17:44 T:1892547944 NOTICE: Thread JobWorker start, auto delete: true
01:17:44 T:1891991136 NOTICE: Thread RSSReader start, auto delete: false
01:17:44 T:1892188640 NOTICE: -->Python Interpreter Initialized<--
01:17:45 T:1891965584 NOTICE: Previous line repeats 2 times.
01:17:45 T:1891965584 NOTICE: ===== PLEXBMC START [id: 1432617465.01] =====
01:17:45 T:1892188640 NOTICE: ===== PLEXBMC START [id: 1432617465.02] =====
01:17:45 T:1848178632 NOTICE: StorageServer Module loaded RUN
01:17:45 T:1848178632 NOTICE: StorageClient-2.5.4 Starting server
01:17:45 T:1891965584 NOTICE: PleXBMC -> Reading settings configuration
01:17:46 T:1891965584 NOTICE: Previous line repeats 1 times.
01:17:46 T:1891965584 NOTICE: PleXBMC.plexserver -> <module> : Using Requests version for HTTP: 2.6.0
01:17:46 T:1891965584 NOTICE: PleXBMC -> Running PleXBMC: 4.0.0~beta4
01:17:46 T:1891965584 NOTICE: PleXBMC -> Script argument is ['default.py', 'amberskin', 'nocat']
01:17:46 T:1891965584 NOTICE: PleXBMC -> Running Python: (2, 6, 5, 'final', 0)
01:17:46 T:1891965584 NOTICE: PleXBMC -> CWD is set to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.plexbmc-helix
01:17:46 T:1891965584 NOTICE: PleXBMC -> Platform: Linux/RPi
01:17:46 T:1891965584 NOTICE: PleXBMC -> Setting debug: debug+
01:17:46 T:1891965584 NOTICE: PleXBMC -> FullRes Thumbs are set to: True
01:17:46 T:1891965584 NOTICE: PleXBMC -> Settings streaming: 0
01:17:46 T:1891965584 NOTICE: PleXBMC -> Setting filter menus: True
01:17:46 T:1891965584 NOTICE: PleXBMC -> Flatten is: 0
01:17:46 T:1891965584 NOTICE: PleXBMC -> Setting stream Control to : PLEX CONTROL
01:17:46 T:1891965584 NOTICE: PleXBMC -> Force DVD playback: False
01:17:46 T:1891965584 NOTICE: PleXBMC -> SMB IP Override: False
01:17:46 T:1891965584 NOTICE: setting: nasoverrideip is :
01:17:46 T:1891965584 NOTICE: PleXBMC -> NAS IP:
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> __init__ : Running with cache location: special://profile/addon_data/plugin.video.plexbmc/cache/servers/
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [plexhome_user.pcache]: attempting to read
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [plexhome_user.pcache]: read
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [plexhome_user.pcache]: data: [(dp1
S'plexhome_user_cache'
p2
S''
sS'plexhome_user_avatar'
p3
S'http://www.gravatar.com/avatar/20d9e16860fd37079aae941b76258534?d=https%3A%2F%2Fplex.tv%2Favatars%2F7EB0D5%2F52​%2F1'
p4
sS'plexhome_enabled'
p5
I00
sS'myplex_signedin'
p6
I01
sS'myplex_user_cache'
p7
S'<omitted>'
p8
s.]
01:17:46 T:1891965584 NOTICE: PleXBMC.plex -> load_tokencache : plexhome_cache data loaded successfully
01:17:46 T:1891965584 NOTICE: PleXBMC.plex -> setup_user_token : Myplex is logged in
01:17:46 T:1891965584 NOTICE: PleXBMC.plex -> setup_user_token : No user set. Will default to admin user
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> writeCache : CACHE [plexhome_user.pcache]: Writing file
01:17:46 T:1891965584 NOTICE: PleXBMC.plex -> setup_user_token : myplex userid: <omitted>
01:17:46 T:1891965584 NOTICE: PleXBMC.plex -> setup_user_token : effective userid: <omitted>
01:17:46 T:1891965584 NOTICE: PleXBMC -> get_params : == ENTER ==
01:17:46 T:1891965584 NOTICE: PleXBMC -> get_params : Parameter string: nocat
01:17:46 T:1891965584 NOTICE: PleXBMC -> Detected parameters: {}
01:17:46 T:1891965584 NOTICE: PleXBMC.plex -> load : Loading cached server list
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> checkCache : CACHE [discovered_plex_servers.cache]: exists
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> checkCache : CACHE [discovered_plex_servers.cache]: mod[1432617067] now[1432617467] diff[400]
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> checkCache : CACHE [discovered_plex_servers.cache]: current
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [discovered_plex_servers.cache]: attempting to read
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [discovered_plex_servers.cache]: read
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [discovered_plex_servers.cache]: data: [(dp1
S'Commit:02b2d81'
p2
(iplexserver
PlexMediaServer
p3
(dp4
S'protocol'
p5
S'http'
p6
sS'plex_home_enabled'
p7
I00
sS'owned'
p8
I1
sS'discovered'
p9
I00
sS'plex_identification_string'
p10
S'X-Plex-Platform=KODI&X-Plex-Client-Platform=KODI&X-Plex-User=<omitted>&X-Plex-Device-Name=Livingroom&X-Plex-Provides=player&X-Plex-Token=UeRSfDzEqKohiYdrg3wM&X-Plex-Model=unknown&X-Plex-Platform-Version=Linux/RPi&X-Plex-Client-Identifier=4b6fb3d6-5f26-45ee-86df-804b1ee6a742&X-Plex-Device=PleXBMC&X-Plex-Product=PleXBMC&X-Plex-Language=en&X-Plex-Version=4.0.0%7Ebeta4'
p11
sS'external_port'
p12
S'13020'
p13
sS'plex_identification_header'
p14
(dp15
S'X-Plex-Platform'
p16
S'KODI'
p17
sS'X-Plex-Client-Platform'
p18
g17
sS'X-Plex-User'
p19
S'<omitted>'
p20
sS'X-Plex-Device-Name'
p21
S'Livingroom'
p22
sS'X-Plex-Provides'
p23
S'player'
p24
sS'X-Plex-Token'
p25
S'UeRSfDzEqKohiYdrg3wM'
p26
sS'X-Plex-Model'
p27
S'unknown'
p28
sS'X-Plex-Platform-Version'
p29
S'Linux/RPi'
p30
sS'X-Plex-Client-Identifier'
p31
S'4b6fb3d6-5f26-45ee-86df-804b1ee6a742'
p32
sS'X-Plex-Device'
p33
S'PleXBMC'
p34
sS'X-Plex-Product'
p35
g34
sS'X-Plex-Language'
p36
S'en'
p37
sS'X-Plex-Version'
p38
S'4.0.0~beta4'
p39
ssS'uuid'
p40
g2
sS'server_name'
p41
S'CarusoNAS01'
p42
sS'local_port'
p43
NsS'access_port'
p44
g13
sS'master'
p45
I1
sS'local_address'
p46
(lp47
S'192.168.1.130'
p48
asS'offline'
p49
I00
sS'_PlexMediaServer__revision'
p50
S'1.0.7'
p51
sS'discovery'
p52
S'myplex'
p53
sS'class_type'
p54
S'primary'
p55
sS'section_list'
p56
(lp57
sS'user'
p58
g20
sS'client_id'
p59
g32
sS'external_address'
p60
S'<ommitted>'
p61
sS'best_address'
p62
S'address'
p63
sS'device_name'
p64
g22
sS'token'
p65
g26
sS'access_address'
p66
g61
sbs.]
01:17:46 T:1891965584 NOTICE: PleXBMC.plex -> load : Server list is now: {'Commit:02b2d81': <plexserver.PlexMediaServer instance at 0x71c74c70>}
01:17:46 T:1891965584 NOTICE: PleXBMC -> amberskin : == ENTER ==
01:17:46 T:1891965584 NOTICE: PleXBMC -> amberskin : Using list of 1 servers: [<plexserver.PlexMediaServer instance at 0x71c74c70>]
01:17:46 T:1891965584 NOTICE: PleXBMC.plexserver -> talk : URL is: /library/sections
01:17:47 T:1892188640 NOTICE: PleXBMC.plexserver -> <module> : Using Requests version for HTTP: 2.6.0
01:17:47 T:1892188640 NOTICE: PleXBMC -> Running PleXBMC: 4.0.0~beta4
01:17:47 T:1892188640 NOTICE: PleXBMC -> Script argument is ['default.py', 'channelShelf']
01:17:47 T:1892188640 NOTICE: PleXBMC -> Running Python: (2, 6, 5, 'final', 0)
01:17:47 T:1892188640 NOTICE: PleXBMC -> CWD is set to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.plexbmc-helix
01:17:47 T:1892188640 NOTICE: PleXBMC -> Platform: Linux/RPi
01:17:47 T:1892188640 NOTICE: PleXBMC -> Setting debug: debug+
01:17:47 T:1892188640 NOTICE: PleXBMC -> FullRes Thumbs are set to: True
01:17:47 T:1892188640 NOTICE: PleXBMC -> Settings streaming: 0
01:17:47 T:1892188640 NOTICE: PleXBMC -> Setting filter menus: True
01:17:47 T:1892188640 NOTICE: PleXBMC -> Flatten is: 0
01:17:47 T:1892188640 NOTICE: PleXBMC -> Setting stream Control to : PLEX CONTROL
01:17:47 T:1892188640 NOTICE: PleXBMC -> Force DVD playback: False
01:17:47 T:1892188640 NOTICE: PleXBMC -> SMB IP Override: False
01:17:47 T:1892188640 NOTICE: setting: nasoverrideip is :
01:17:47 T:1892188640 NOTICE: PleXBMC -> NAS IP:
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> __init__ : Running with cache location: special://profile/addon_data/plugin.video.plexbmc/cache/servers/
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [plexhome_user.pcache]: attempting to read
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [plexhome_user.pcache]: read
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [plexhome_user.pcache]: data: [(dp1
p2
S''
p3
I00
p4
p5
sS'myplex_signedin'
p6
I01
p7
S'<omitted>'
p8
s.]
01:17:47 T:1892188640 NOTICE: PleXBMC.plex -> load_tokencache : plexhome_cache data loaded successfully
01:17:47 T:1892188640 NOTICE: PleXBMC.plex -> setup_user_token : Myplex is logged in
01:17:47 T:1892188640 NOTICE: PleXBMC.plex -> setup_user_token : No user set. Will default to admin user
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> writeCache : CACHE [plexhome_user.pcache]: Writing file
01:17:47 T:1892188640 NOTICE: PleXBMC.plex -> setup_user_token : myplex userid: <omitted>
01:17:47 T:1892188640 NOTICE: PleXBMC.plex -> setup_user_token : effective userid: <omitted>
01:17:47 T:1892188640 NOTICE: PleXBMC.plex -> load : Loading cached server list
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> checkCache : CACHE [discovered_plex_servers.cache]: exists
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> checkCache : CACHE [discovered_plex_servers.cache]: mod[1432617067] now[1432617467] diff[400]
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> checkCache : CACHE [discovered_plex_servers.cache]: current
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [discovered_plex_servers.cache]: attempting to read
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [discovered_plex_servers.cache]: read
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [discovered_plex_servers.cache]: data: [(dp1
S'Commit:02b2d81'
p2
(iplexserver
PlexMediaServer
p3
(dp4
S'protocol'
p5
S'http'
p6
p7
I00
sS'owned'
p8
I1
sS'discovered'
p9
I00
p10
p11
sS'external_port'
p12
S'13020'
p13
p14
(dp15
S'X-Plex-Platform'
p16
S'KODI'
p17
p18
g17
sS'X-Plex-User'
p19
S'<omitted>'
p20
p21
S'Livingroom'
p22
sS'X-Plex-Provides'
p23
S'player'
p24
sS'X-Plex-Token'
p25
p26
sS'X-Plex-Model'
p27
S'unknown'
p28
p29
S'Linux/RPi'
p30
p31
p32
sS'X-Plex-Device'
p33
S'PleXBMC'
p34
sS'X-Plex-Product'
p35
g34
sS'X-Plex-Language'
p36
S'en'
p37
sS'X-Plex-Version'
p38
S'4.0.0~beta4'
p39
ssS'uuid'
p40
g2
sS'server_name'
p41
S'CarusoNAS01'
p42
sS'local_port'
p43
NsS'access_port'
p44
g13
sS'master'
p45
I1
sS'local_address'
p46
(lp47
S'192.168.1.130'
p48
asS'offline'
p49
I00
p50
S'1.0.7'
p51
sS'discovery'
p52
S'myplex'
p53
sS'class_type'
p54
S'primary'
p55
sS'section_list'
p56
(lp57
sS'user'
p58
g20
sS'client_id'
p59
g32
p60
S'<omitted>'
p61
sS'best_address'
p62
S'address'
p63
sS'device_name'
p64
g22
sS'token'
p65
g26
sS'access_address'
p66
g61
sbs.]
01:17:47 T:1892188640 NOTICE: PleXBMC.plex -> load : Server list is now: {'Commit:02b2d81': <plexserver.PlexMediaServer instance at 0x72b37ee8>}
01:17:47 T:1892188640 NOTICE: PleXBMC -> shelfChannel : == ENTER ==
01:17:47 T:1892188640 NOTICE: PleXBMC -> shelfChannel : Disabling channel shelf
01:17:47 T:1892188640 NOTICE: PleXBMC -> clearChannelShelf : Done clearing channels
01:17:47 T:1892188640 NOTICE: ===== PLEXBMC STOP [id: 1432617465.02]: 2.43537402153 seconds =====
01:17:47 T:1891965584 NOTICE: PleXBMC.plexserver -> talk : URL was: http://<omitted>/library/sections?X-Plex-Platform=KODI&X-Plex-Token=UeRSfDzEqKohiYdrg3wM&X-Plex-Platform-Version=Linux%2FRPi&X-Plex-Client-Platform=KODI&X-Plex-User=<omitted>&X-Plex-Client-Identifier=4b6fb3d6-5f26-45ee-86df-804b1ee6a742&X-Plex-Device=PleXBMC&X-Plex-Product=PleXBMC&X-Plex-Language=en&X-Plex-Model=unknown&X-Plex-Device-Name=Livingroom&X-Plex-Provides=player&X-Plex-Version=4.0.0~beta4
01:17:47 T:1891965584 NOTICE: PleXBMC.plexserver -> talk : Response: 200 OK - Encoding: utf-8
01:17:47 T:1891965584 NOTICE: PleXBMC.plexserver -> talk : ===XML===
<?xml version="1.0" encoding="UTF-8"?>
<MediaContainer size="13" allowSync="0" identifier="com.plexapp.plugins.library" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1431042673" title1="Plex Library">
<Directory allowSync="1" art="/:/resources/photo-fanart.jpg" composite="/library/sections/20/composite/1432567236" filters="1" refreshing="0" thumb="/:/resources/photo.png" key="20" type="photo" title="ChrisPhonePics" agent="com.plexapp.agents.none" scanner="Plex Photo Scanner" language="xn" uuid="0b53cac8-3507-47fa-8a28-1a7f84af5712" updatedAt="1432567236" createdAt="1432318793">
<Location id="25" path="/apps/plexmediaserver/MediaLibrary/Plex Media Server/Media Upload/ChrisPhonePics" />
</Directory>
<Directory allowSync="1" art="/:/resources/movie-fanart.jpg" composite="/library/sections/21/composite/1432569036" filters="1" refreshing="0" thumb="/:/resources/video.png" key="21" type="movie" title="Home Videos" agent="com.plexapp.agents.none" scanner="Plex Video Files Scanner" language="xn" uuid="84ad603c-ba62-404c-bff7-df10706e60f9" updatedAt="1432569036" createdAt="1432386250">
<Location id="26" path="/CarusoVol01/media/Family Videos" />
</Directory>
<Directory allowSync="1" art="/:/resources/movie-fanart.jpg" composite="/library/sections/1/composite/1432567237" filters="1" refreshing="0" thumb="/:/resources/movie.png" key="1" type="movie" title="Kid Movies" agent="com.plexapp.agents.imdb" scanner="Plex Movie Scanner" language="en" uuid="224ebb3f-a564-4e81-9291-da4e160ff798" updatedAt="1432567237" createdAt="1424573600">
<Location id="1" path="/CarusoVol01/media/Kids/Movies" />
</Directory>
<Directory allowSync="1" art="/:/resources/show-fanart.jpg" composite="/library/sections/3/composite/1432567239" filters="1" refreshing="0" thumb="/:/resources/show.png" key="3" type="show" title="Kid Shows" agent="com.plexapp.agents.thetvdb" scanner="Plex Series Scanner" language="en" uuid="b9417575-575c-4a82-808b-9b2a6224e1b0" updatedAt="1432567239" createdAt="1424580761">
<Location id="3" path="/CarusoVol01/media/Kids/Shows" />
</Directory>
<Directory allowSync="1" art="/:/resources/movie-fanart.jpg" composite="/library/sections/22/composite/1432569038" filters="1" refreshing="0" thumb="/:/resources/video.png" key="22" type="movie" title="Mobile Home Videos" agent="com.plexapp.agents.none" scanner="Plex Video Files Scanner" language="xn" uuid="61a82f85-205c-44c2-8905-7fe180192bab" updatedAt="1432569038" createdAt="1432466215">
<Location id="27" path="/CarusoVol01/Mobile/Family Videos" />
</Directory>
<Directory allowSync="1" art="/:/resources/movie-fanart.jpg" composite="/library/sections/11/composite/1432567240" filters="1" refreshing="0" thumb="/:/resources/movie.png" key="11" type="movie" title="Mobile Kids Movies" agent="com.plexapp.agents.imdb" scanner="Plex Movie Scanner" language="en" uuid="c9dc5030-7d61-4c0b-ab1d-b4b39c919862" updatedAt="1432567240" createdAt="1426941097">
<Location id="13" path="/CarusoVol01/Mobile/Kids/Movies" />
</Directory>
<Directory allowSync="1" art="/:/resources/show-fanart.jpg" composite="/library/sections/12/composite/1432567242" filters="1" refreshing="0" thumb="/:/resources/show.png" key="12" type="show" title="Mobile Kids Shows" agent="com.plexapp.agents.thetvdb" scanner="Plex Series Scanner" language="en" uuid="5c0918a9-e661-4bd6-bcae-59c5343a9858" updatedAt="1432567242" createdAt="1427131136">
<Location id="14" path="/CarusoVol01/Mobile/Kids/Shows" />
</Directory>
<Directory allowSync="1" art="/:/resources/movie-fanart.jpg" composite="/library/sections/7/composite/1432567291" filters="1" refreshing="0" thumb="/:/resources/movie.png" key="7" type="movie" title="Mobile Movies" agent="com.plexapp.agents.imdb" scanner="Plex Movie Scanner" language="en" uuid="ceb0c7ac-44bb-4c1d-9100-e3a81b7deb31" updatedAt="1432567291" createdAt="1424636462">
<Location id="8" path="/CarusoVol01/Mobile/Theatrical Releases" />
</Directory>
<Directory allowSync="1" art="/:/resources/photo-fanart.jpg" composite="/library/sections/23/composite/1432569039" filters="1" refreshing="0" thumb="/:/resources/photo.png" key="23" type="photo" title="Mobile Photos" agent="com.plexapp.agents.none" scanner="Plex Photo Scanner" language="xn" uuid="4ba67226-7890-42b0-a869-2bfff6179c3e" updatedAt="1432569039" createdAt="1432558697">
<Location id="28" path="/apps/plexmediaserver/MediaLibrary/Plex Media Server/Media Upload/Mobile Photos" />
</Directory>
<Directory allowSync="1" art="/:/resources/movie-fanart.jpg" composite="/library/sections/4/composite/1432567301" filters="1" refreshing="0" thumb="/:/resources/movie.png" key="4" type="movie" title="Movies" agent="com.plexapp.agents.imdb" scanner="Plex Movie Scanner" language="en" uuid="dd5eabb6-8104-4d42-9a45-dbbf46856fc7" updatedAt="1432567301" createdAt="1424584228">
<Location id="4" path="/CarusoVol01/media/Theatrical Releases" />
</Directory>
<Directory allowSync="1" art="/:/resources/artist-fanart.jpg" composite="/library/sections/18/composite/1432567302" filters="1" refreshing="0" thumb="/:/resources/artist.png" key="18" type="artist" title="Music" agent="com.plexapp.agents.plexmusic" scanner="Plex Premium Music Scanner" language="en" uuid="a0cf4eab-390e-42fb-94a3-368af7785b67" updatedAt="1432567302" createdAt="1430851809">
<Location id="23" path="/CarusoVol01/media/Music/Chris" />
</Directory>
<Directory allowSync="1" art="/:/resources/photo-fanart.jpg" composite="/library/sections/9/composite/1432567310" filters="1" refreshing="0" thumb="/:/resources/photo.png" key="9" type="photo" title="Photos" agent="com.plexapp.agents.none" scanner="Plex Photo Scanner" language="xn" uuid="d217628e-35ef-4c88-a853-e91c46e63eb2" updatedAt="1432567310" createdAt="1425433753">
<Location id="10" path="/apps/plexmediaserver/MediaLibrary/Plex Media Server/Media Upload/Photos" />
<Location id="11" path="/CarusoVol01/media/Pictures/Pictures" />
</Directory>
<Directory allowSync="1" art="/:/resources/show-fanart.jpg" composite="/library/sections/5/composite/1432567322" filters="1" refreshing="0" thumb="/:/resources/show.png" key="5" type="show" title="TV Shows" agent="com.plexapp.agents.thetvdb" scanner="Plex Series Scanner" language="en" uuid="aa789d4b-c4c4-42ed-a106-f8e3ffb0e83e" updatedAt="1432567322" createdAt="1424633102">
<Location id="5" path="/CarusoVol01/media/TV Shows" />
</Directory>
</MediaContainer>
===XML===
01:17:47 T:1891965584 NOTICE: PleXBMC.plexserver -> talk : DOWNLOAD: It took 0.89 seconds to retrieve data from <omitted>
01:17:47 T:1891965584 NOTICE: PleXBMC.plexserver -> processed_xml : PARSE: it took 0.02 seconds to parse data from <omitted>
01:17:47 T:1891965584 NOTICE: PleXBMC.plexserver -> get_sections : Returning sections: [<plexserver.plex_section instance at 0x7296e8d8>, <plexserver.plex_section instance at 0x71d40a10>, <plexserver.plex_section instance at 0x71d21888>, <plexserver.plex_section instance at 0x7270cb10>, <plexserver.plex_section instance at 0x72b25050>, <plexserver.plex_section instance at 0x7271b700>, <plexserver.plex_section instance at 0x727bb4b0>, <plexserver.plex_section instance at 0x7276cae0>, <plexserver.plex_section instance at 0x726d4e28>, <plexserver.plex_section instance at 0x72771d80>, <plexserver.plex_section instance at 0x726d4e70>, <plexserver.plex_section instance at 0x726d6cf0>, <plexserver.plex_section instance at 0x72ab9fa0>]
01:17:47 T:1891965584 NOTICE: PleXBMC -> amberskin : =Enter amberskin section=
01:17:47 T:1891965584 NOTICE: PleXBMC -> amberskin : {'art': '/:/resources/photo-fanart.jpg', 'title': 'ChrisPhonePics', 'sectionuuid': '0b53cac8-3507-47fa-8a28-1a7f84af5712', 'location': 'local', 'key': '20', 'path': '/library/sections/20', 'type': 'photo'}
01:17:47 T:1891965584 NOTICE: PleXBMC -> amberskin : =/section=
01:17:47 T:1891965584 NOTICE: PleXBMC.plexserver -> get_fanart : Getting fanart for ChrisPhonePics
01:17:47 T:1891965584 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.UnboundLocalError'>
Error Contents: local variable 'mode' referenced before assignment
Traceback (most recent call last):
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.plexbmc-helix/default.py", line 13, in <module>
plexbmc.start_plexbmc()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.plexbmc-helix/resources/lib/plexbmc.py", line 4120, in start_plexbmc
amberskin()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.plexbmc-helix/resources/lib/plexbmc.py", line 2819, in amberskin
WINDOW.setProperty("plexbmc.%d.year" % (sectionCount) , "ActivateWindow(%s,%s%s%s&mode=%s,return)" % (window, base_url, path, "/year", mode) )
UnboundLocalError: local variable 'mode' referenced before assignment
-->End of Python script error report<--
01:17:51 T:1783596656 NOTICE: Storing total System Uptime
01:17:51 T:1783596656 NOTICE: Saving settings
01:17:51 T:1783596656 NOTICE: stop all
01:17:51 T:1783596656 NOTICE: stop player
01:17:51 T:1783596656 NOTICE: ES: Stopping event server
01:17:52 T:1854959208 NOTICE: ES: UDP Event server stopped
01:17:52 T:1783596656 NOTICE: stopping upnp
01:17:52 T:1783596656 NOTICE: stopping zeroconf publishing
01:17:52 T:1783596656 NOTICE: stop sap announcement listener
01:17:52 T:1783596656 NOTICE: clean cached files!
01:17:52 T:1783596656 NOTICE: unload skin
01:17:53 T:1848178632 NOTICE: StorageServer-2.5.4 Closed down
01:17:53 T:1844686400 WARNING: CPythonInvoker(1, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.skin.widgets/default.py): the python script "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.skin.widgets/default.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui6WindowE,N14PythonBindings31XBMCAddon_xbmc_Monitor_DirectorE,​N14PythonBindings30XBMCAddon_xbmc_Player_DirectorE
01:17:53 T:1783596656 NOTICE: stopped
01:17:53 T:1783596656 NOTICE: destroy
01:17:53 T:1783596656 NOTICE: unload sections
01:17:53 T:1783596656 NOTICE: special://profile/ is mapped to: special://masterprofile/
01:17:53 T:1783596656 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
01:17:53 T:1783596656 NOTICE: application stopped...
#2371 saitoh183
saitoh183
    Dedicated Member
  • Members
  • PipPipPip
  • 145 posts
Posted 27 May 2015 - 07:00 PM
@RockyCJC
Please dont post your log directly in the thread, use a paste site like pastebin and post a link to your log, This will avoid log painful post like you just did :)
#2372 RockyCJC
RockyCJC
    Member
  • Members
  • PipPip
  • 45 posts
Posted 27 May 2015 - 08:35 PM
@RockyCJC
Did you have any comments or ideas on my issue?
#2373 saitoh183
saitoh183
    Dedicated Member
  • Members
  • PipPipPip
  • 145 posts
Posted 27 May 2015 - 09:02 PM
Did you enable the view manager in plexbmc settings for Amber. If you did, disable it and see.
#2374 RockyCJC
RockyCJC
    Member
  • Members
  • PipPip
  • 45 posts
Posted 27 May 2015 - 11:57 PM
I've not seen that setting before. I'll take a look.
#2375 RockyCJC
RockyCJC
    Member
  • Members
  • PipPip
  • 45 posts
Posted 28 May 2015 - 12:07 PM
I couldn't find that specific setting. Someone on the plexbmc forum mention installing the amber skin from the repo vs. Github. Is there a difference between the two?
#2376 saitoh183
saitoh183
    Dedicated Member
  • Members
  • PipPipPip
  • 145 posts
Posted 28 May 2015 - 12:25 PM
I will screen shot the setting I'm talking about. I used the one from the kodi repo.
#2377 ebike
ebike
    Member
  • Members
  • PipPip
  • 47 posts
Posted 31 May 2015 - 07:30 AM
Hi Guys,
I have just installed the latest version (4.0.0Beta4) into Kodi 14.2 and although the addon installs ok and I can log into the plex server with manage myPlex, when I goto Videos->Plugins->plexbmc
all I see is the following:
myPlex Queue
Switch User
Sign Out
Refresh Data
That is all I see. I tried "Refresh Data" but nothing. I installed exactly as the instructions on github  ... what is wrong? Is there a step I am missing?
#2378 RockyCJC
RockyCJC
    Member
  • Members
  • PipPip
  • 45 posts
Posted 31 May 2015 - 10:42 AM
Hi Guys,
What skin are you using?
#2379 ebike
ebike
    Member
  • Members
  • PipPip
  • 47 posts
Posted 31 May 2015 - 10:13 PM
I have sorted it. Had to manually select the server and switched to the amber skin.
Looks good, but have a few issues:
1. For music and Videos, there is no way to see all the albums/videos
2. In music can't sort by artist and it does not sort out multi-artist albums correctly .... displays them all as separate albums.
also, no support for music videos ... like in PHT (Plex Home Theatre)
3. Very sluggish loading fanart .. meta data .. in comparison to PHT
#2380 saitoh183
saitoh183
    Dedicated Member
  • Members
  • PipPipPip
  • 145 posts
Posted 31 May 2015 - 11:14 PM
Try to optimize the db in plex. That fixed it for me
