Jump to content
Quicksilver
  • Please log in to reply
128 replies to this topic
#121 dadrepuS
dadrepuS
    Dedicated Member
  • Members
  • PipPipPip
  • 288 posts
Posted 20 April 2014 - 05:20 PM
Hi Frankie. Maybe you can help me too.
I followed instructions on where to put Quicksilver but my pathway is slightly different:
 ~/Library/Application Support/Plex Media Centre/Content/Resources ... and then no Addon folder???
I am running Lion. Any ideas?
You don't want the media center application you want the "Plex Media Server".
PMS- Mac Mini 2.53
Clients- AppleTV 1, Roku 3, Mac Mini, Amazon Stick
Storage- 12TB external WD.
#122 dlanor
dlanor
    Plex Star
  • Members
  • PipPipPipPipPipPip
  • 1818 posts
Posted 22 April 2014 - 08:07 AM
Sorry, but that's wrong. Skins are never installed for the PMS server.
Skins are installed for Plex client programs. (Individually for each one.)
----- switch of reply target -----
I don't use a mac myself, so I can't check the precise mac paths here. But I do know that on other systems there are two different paths related to each plex client. One path for the installed program with its basic components and another path for its application data and user add-ons. So you probably need to search for another path than the one you mentioned above.
Like I said, I don't use any mac myself, but I have saved generic instructions for skin installs of PMC for reference, and those instructions include the following statements:
Place the skin folder into ~/Application Support/Plex/addons/
or for Win7 c:\Users\your_user_name\AppData\Local\Plex\addons\
or for WinXP c:\Documents and Settings\your_user_name_1\Local Settings\Application Data\Plex\addons\
Here the first of the quoted line refers to a mac install, though it may be for a different OSX version than yours.
(It's a pretty old quote.)
On the other hand, since your post was made almost five months ago, I assume you've either solved the problem since then, or moved on beyond it...
Best regards: dlanor
#123 BigWheel
BigWheel
    Keeps Turning
  • Plex Employee
  • 6297 posts
Posted 24 April 2014 - 12:55 AM
for PHT the path to install skins on OS X is
~/Library/Application Support/Plex Home Theater/addons/
note on OSX the user library folder is hidden by default. see my link in my sig below
Please do not send me private messages unless requested.
Splinter A great little horror/monster movie
The Knick my new addiction
Need help? Having trouble?
» Visit the Support Site for documentation, guides, and more - including the Getting Started section
» Provide Log Files when reporting issues Name and Organize your content correctly for best results
#124 AtariBaby
AtariBaby
    Member
  • Members
  • PipPip
  • 67 posts
Posted 03 February 2015 - 01:01 AM
FYI the screenshots in the original post are DEADDDDDDDDD.
#125 BigWheel
BigWheel
    Keeps Turning
  • Plex Employee
  • 6297 posts
Posted 03 February 2015 - 05:51 AM
the author has not worked on this in 2 years. it most likely does not work with the current versions of Plex Home Theater at all
#126 \0
\0
    Rock Star
  • Members
  • PipPipPipPipPip
  • 942 posts
Posted 03 March 2015 - 12:28 AM
So why is it still pinned? Makes the place look... . .abandoned..
#127 AtariBaby
AtariBaby
    Member
  • Members
  • PipPip
  • 67 posts
Posted 03 March 2015 - 01:09 AM
Based on this, I've decided to just stay away from skins. I don't want to have weird problems lol I'll stick with the program.
  • \0 likes this
#128 \0
\0
    Rock Star
  • Members
  • PipPipPipPipPip
  • 942 posts
Posted 03 March 2015 - 01:12 AM
Lol. great, a 2 year old OOD skin pinned and not updated has put a user off using skins...
#129 Reddragon220
Reddragon220
    Skinning God
  • Members
  • PipPipPip
  • 277 posts
Posted 30 March 2015 - 02:19 AM
Well then, I suppose that it has been quite a while since I've dropped by and worked on this project. I just gave Quicksilver a cursory look on Plex Home theater to confirm that it more or less works. I'm sure that there are now additional dialogues and whatnot but at the very least the main menu as well as the various library navigation screens all seem to more or less function. I'm sure that there are more than a few rough edges that need to be smoothed over.
Anyways, I've refreshed the screenshots and updated the installation path on the main post. Oh and pushed a small update to fix the broken media tags that I had been holding onto for a year or two.
  • \0 and T1ffer like this
