Jump to content
Cannot load M3U8: 404 not found
  • Please log in to reply
38 replies to this topic
#21 wavydavy
wavydavy
    Dedicated Member
  • Members
  • PipPipPip
  • 167 posts
Posted 24 January 2013 - 06:20 AM
I seem to be having the same issue. I shut down zonealarm (firewall) and the problem goes away. i have all the programs associated with plex on the zonealarm trusted list but still get the problem when zonealarm is on maybe i'm missing something. Has anyone else had any luck
I have the same issue but with TCPblock on Snow Leopard.
When I disable TCblock the movie will stream, enable it and I get the same error again.
#22 heatherwolf
heatherwolf
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 25 January 2013 - 09:10 PM
Hi all,
in my case i set new file restriction to solved the problem. At first i make it accessable for everyone. Sorry for my bad english.
greetz
#23 wavydavy
wavydavy
    Dedicated Member
  • Members
  • PipPipPip
  • 167 posts
Posted 27 January 2013 - 06:01 PM
I just found that my firewall was blocking the Plex transcoder, added Plex Transcoder to my firewalls whitelist and I am no longer getting the "Cannot load M3U8: 404 not found" error, plays everything fine now.
#24 jhaveman
jhaveman
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 18 February 2013 - 09:47 PM
I was having this problem and fixed this and other related problems with play back. I noticed that the files that had the playback error had a 00:00:00 duration. Also, other movies/shows didn't playback as expected when their duration didn't match reality. For example, a movie that is 2 hours long reported it had a duration of 00:12:00. In other words, PLEX was having a problem playing movies that had the internal duration off. Here is how I fixed the internal clock.
First of all, I am a windows 7 user, but I still wanted to report my fix. I downloaded ffmpeg from ffmpeg.org. There are linux, mac and windows downloads available. This software allows you to do all kinds of stuff in terms of transcoding files from one type to another. The command I used was:
ffmpeg -i "filename.ext" -c:v copy "newfilename.ext"
What this does, is it remuxes the file using the same video bit rate and fixes the timing. (The timing is what PLEX didn't like.)
--The first part [-i "filename"] is where you specify the input filename.
--The second part [-c:v copy] is where you specify that you are not changing the video bit rate. (You can add [-c:a copy] if you want to copy the audio as-is)
--The third part is where you specify the output file name.
For example, if I have "my movie.VOB" with a duration of 00:00:00 (or something incorrect), I will get a new file "my movie 2.VOB" with the correct time (like 01:42:30, or whatever the duration is). I then delete the bad file and rename the new. I do a refresh on the section in PLEX, maybe have to rematch and the movie now plays in PLEX (and on my Roku).
Each file takes about 3-5 minutes. **Important note, because I am not specifying [-c:a copy], my video files all have 2 channel audio (ffmpeg default??).** For me, this is fine because my computer and main tv run stereo only. I know this is not great for everyone, but there is plenty of documentation on ffmpeg.org. Maybe it will work for you. If you get it working, please post back your fix.
I'm guessing PLEX is confused by the internal timing of the files. It needs to be able to ignore the internal timing and just play the file.
I hope this was not too confusing.
#25 angstman
angstman
    Member
  • Members
  • PipPip
  • 17 posts
Posted 19 February 2013 - 02:54 AM
Can this have anything to do with my media being on a USB drive formatted with NTFS? I am reformating as ext4 to give that a try. I have an internal drive formatted with NTFS, too since I used to run Win7 on here. The pure Ubuntu server I use has never given me these troubles. I have no firewall running.
#26 jhaveman
jhaveman
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 19 February 2013 - 12:23 PM
I have everything on a couple of external USB 2TB drives formatted NTFS. My only problem has been the internal timing in my VOBs.
#27 flemmingk
flemmingk
    Member
  • Members
  • PipPip
  • 28 posts
Posted 23 March 2013 - 01:45 PM
No matter what media I try to access via the web client, I get "Cannot load M3U8: 404 not found". Maybe my google foo is off, but I have been searching for the source of this problem for 7 hours now and cannot find an answer. Any ideas?
Hi Scotty
I just learned on the chat line that Plex doesn't support DVD-rips. I.e. VIDEO_TS and AUDIO_TS.
The recommendation is to transcode by means of makemkv.
BR
Flemming
#28 flemmingk
flemmingk
    Member
  • Members
  • PipPip
  • 28 posts
Posted 23 March 2013 - 01:47 PM
Hi
Plex doesn't support VOBs. You might convert to MKV by means of makemkv.
BR
Flemming
#29 crossbred900
crossbred900
    Newbie
  • Members
  • Pip
  • 5 posts
Posted 24 March 2013 - 11:49 PM
I was having this problem in windows until I changed the directory that Plex used for transcoding
#30 VBM
VBM
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 13 May 2013 - 01:01 PM
Hello i have similar problem when trying to watch movies using web client
PLEX Media Server: 0.9.7.26
PLEX WEB: 1.1.0
I get: "Cannot load M3U8: 404 Not found"
Here is part of my logfile
May 13, 2013 15:01:19 [0x48f0b490] DEBUG - Request: GET /video/:/transcode/universal/start.m3u8?path=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F4&mediaIndex=0&partIndex=0&session=9x08nszp6szwipb9&protocol=hls&offset=0&fastSeek=1&directPlay=0&directStream=1&videoQuality=75&videoResolution=1280x720&maxVideoBitrate=3000&subtitleSize=100&audioBoost=100&X-Plex-Client-Identifier=9x08nszp6szwipb9&X-Plex-Product=Web+Client&X-Plex-Device=Linux&X-Plex-Platform=Chrome&X-Plex-Platform-Version=26&X-Plex-Version=1.1.0&X-Plex-Device-Name=Plex%2FWeb+(Chrome)&X-Plex-Account=862053&X-Plex-Username=VBM [10.0.0.1:59134] (3 live)
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * path => http://127.0.0.1:32400/library/metadata/4
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * mediaIndex => 0
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * partIndex => 0
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * session => 9x08nszp6szwipb9
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * protocol => hls
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * offset => 0
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * fastSeek => 1
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * directPlay => 0
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * directStream => 1
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * videoQuality => 75
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * videoResolution => 1280x720
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * maxVideoBitrate => 3000
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * subtitleSize => 100
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * audioBoost => 100
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * X-Plex-Client-Identifier => 9x08nszp6szwipb9
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * X-Plex-Product => Web Client
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * X-Plex-Device => Linux
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * X-Plex-Platform => Chrome
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * X-Plex-Platform-Version => 26
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * X-Plex-Version => 1.1.0
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * X-Plex-Device-Name => Plex/Web (Chrome)
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * X-Plex-Account => 862053
May 13, 2013 15:01:19 [0x48f0b490] DEBUG -  * X-Plex-Username => VBM
May 13, 2013 15:01:19 [0x48f0b490] VERBOSE - Completed request: GET /video/:/transcode/universal/start.m3u8?path=http%3A%2F%2F127.0.0.1%3A32400%2Flibrary%2Fmetadata%2F4&mediaIndex=0&partIndex=0&session=9x08nszp6szwipb9&protocol=hls&offset=0&fastSeek=1&directPlay=0&directStream=1&videoQuality=75&videoResolution=1280x720&maxVideoBitrate=3000&subtitleSize=100&audioBoost=100: 404
Could you please help me?
#31 x-techsolucoes
x-techsolucoes
    Member
  • Members
  • PipPip
  • 41 posts
Posted 25 May 2013 - 04:35 AM
I had the same problem running on a linux (self-built) server. The issue was that librtmp.so.0 couldn't be found. I didn't have it on the system and the sever wasn't using the one that came bundled. I have added a symbolic link from my lib directory to the plexmediaserver/librtmp.so.0 and now I can play everything. It looks like a bug to me.
Hi could you be more specific here ?
i am having the same issue trying to play some video contents in m3u8 format on my plex server 0.9.7.7 web plex  and its giving me the same error.
i have compiled from source and installed rtmpdump2.3.2 and 2.4 on my ubuntu-server, rtmpdump also compiled the lib librtmp.so.0
i have stopped and restarted the plex server via terminal but its still not playing the contents via the plexweb..
if u can be more specific how u linked it, i would appreciate.
thxs
#32 smokeyelf
smokeyelf
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 12 June 2013 - 08:07 PM
I had the same M3U8 404 not found error (DS111).  I suspected that it had to do with a missing codec or links to libraries.  I also noticed that I did not have ffmpeg installed (ipkg list_installed | grep ffmpeg).  I installed ffmpeg (ipkg install ffmpeg).  Seems like this fixed the problem. I no longer get the M3U8 error, at least on the few files that were previously I was previously unable to stream.  However, I'm getting "Error while opening file." with some videos.  I haven't yet checked librtmp.so.0 but will.
#33 war59312
war59312
    Member
  • Members
  • PipPip
  • 47 posts
Posted 29 June 2013 - 04:51 PM
I am having this issue as well now on Ubuntu 13.04 Server. Pretty sure this started after the upgrade from Ubuntu 12.10.
Already installed here:
sudo apt-get install librtmp0
Reading package lists... Done
Building dependency tree
Reading state information... Done
librtmp0 is already the newest version.
librtmp0 set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
No suck luck after setting: Settings > Advanced > Transcoder > "Transcoder temporary directory"
No suck luck here. Turned firewall off completely and same error.
Relevant part of log:
Jun 29, 2013 12:49:56 [0x7f570dffb700] DEBUG - Using profile Web
Jun 29, 2013 12:49:56 [0x7f570dffb700] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/6734
Jun 29, 2013 12:49:56 [0x7f570dffb700] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/metadata/6734
Jun 29, 2013 12:49:56 [0x7f56d6ffd700] DEBUG - Request: GET /library/metadata/6734 [127.0.0.1:53764] (7 live)
Jun 29, 2013 12:49:56 [0x7f56d6ffd700] DEBUG - It took 0.010000 sec to serialize a list with 1 elements.
Jun 29, 2013 12:49:56 [0x7f570dffb700] DEBUG - Caching document http://127.0.0.1:32400/library/metadata/6734 as 2274dc82d35776242d7cd113668b193f0eaee882
Jun 29, 2013 12:49:56 [0x7f570dffb700] INFO - Legends of Flight - video.width limitation applies: 1920 > 1280
Jun 29, 2013 12:49:56 [0x7f570dffb700] DEBUG - Transcoding to hls/mpegts/h264/mp3
Jun 29, 2013 12:49:56 [0x7f570dffb700] DEBUG - Found session GUID of ygv6sedpxyt7f1or in session start.
Jun 29, 2013 12:49:56 [0x7f570dffb700] DEBUG - Using session GUID ygv6sedpxyt7f1or for new transcode session.
Jun 29, 2013 12:49:56 [0x7f570dffb700] DEBUG - Cleaning directory for session ygv6sedpxyt7f1or (/home/rob/plex/plex-transcode-ygv6sedpxyt7f1or-62c86090-043c-4f2b-ab1b-a00358456935)
Jun 29, 2013 12:49:56 [0x7f570dffb700] DEBUG - Universal profile computed resolution bounding box of 1280x720.
Jun 29, 2013 12:49:56 [0x7f56d77fe700] DEBUG - Request: GET /video/:/transcode/universal/session/ygv6sedpxyt7f1or/base/index.m3u8 [192.168.1.105:27899] (7 live)
Jun 29, 2013 12:49:56 [0x7f56d77fe700] INFO - Legends of Flight - video.width limitation applies: 1920 > 1280
Jun 29, 2013 12:49:56 [0x7f56d77fe700] DEBUG - Transcoding to hls/mpegts/h264/mp3
Jun 29, 2013 12:49:56 [0x7f56d77fe700] DEBUG - Starting a transcode session ygv6sedpxyt7f1or at offset -1.0 (stopped=1)
Jun 29, 2013 12:49:56 [0x7f56d77fe700] WARN - WARNING: Couldn't create directory /home/rob/plex/plex-transcode-ygv6sedpxyt7f1or-62c86090-043c-4f2b-ab1b-a00358456935
Jun 29, 2013 12:49:56 [0x7f56d77fe700] DEBUG - Job running: /usr/lib/plexmediaserver/Resources/Plex New Transcoder -i http://127.0.0.1:32400/library/parts/6343/file.mkv -threads 0 -y -segment_format mpegts -f segment -loglevel quiet -loglevel_plex error -map_metadata -1 -progressurl http://127.0.0.1:32400/video/:/transcode/session/ygv6sedpxyt7f1or/progress -vcodec libx264 -crf 20 -maxrate 3000k -bufsize 6000k -vsi 1280x720 -preset veryfast -x264opts cabac=0:me=dia:subme=0:me_range=4:no_chroma_me:8x8dct=0:bframes=0:rc_lookahead=1:qcomp=0.50:qpmin=10:qpmax=51:qpstep=4:partitions=none:cabac=0 -flags -global_header -segment_time 3 -segment_start_number 0 -force_key_frames expr:gte(t,n_forced*3) -map 0:0 -sn -acodec libmp3lame -ac 2 -aq 2 -map 0:2 media-%05d.ts
Jun 29, 2013 12:49:56 [0x7f570cff9700] DEBUG - Request: GET /library/parts/6343/file.mkv [127.0.0.1:53765] (7 live)
Jun 29, 2013 12:49:56 [0x7f570cff9700] DEBUG - Content-Length of /home/rob/imax2/Legends Of Flight (2010)/IMAX.Legends.of.Flight.2010.1080p.BluRay.mkv is 5474388587.
Jun 29, 2013 12:49:57 [0x7f56d7fff700] INFO - [Transcoder] Input #0, matroska,webm, from 'http://127.0.0.1:32400/library/parts/6343/file.mkv':
Jun 29, 2013 12:49:57 [0x7f570d7fa700] INFO - [Transcoder]     Stream #0:0(eng): Video: h264, yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Jun 29, 2013 12:49:57 [0x7f56d6ffd700] INFO - [Transcoder]     Stream #0:1(rus): Audio: dts, 48000 Hz, 5.1(side), fltp, 1536 kb/s (default)
Jun 29, 2013 12:49:57 [0x7f570dffb700] INFO - [Transcoder]     Stream #0:2(eng): Audio: dts, 48000 Hz, 5.1(side), fltp, 1536 kb/s
Jun 29, 2013 12:49:57 [0x7f570cff9700] DEBUG - Request: GET /library/sections/7/recentlyAddedGrandparents [50.18.245.203:51728] (7 live)
Jun 29, 2013 12:49:57 [0x7f570cff9700] DEBUG - We found auth token (GqNmNMzvV7svFA3YBBPF), enabling token-based authentication.
Jun 29, 2013 12:49:57 [0x7f570cff9700] DEBUG - Came in with the master token, authorization succeeded.
Jun 29, 2013 12:49:57 [0x7f570cff9700] DEBUG - It took 0.000000 sec to serialize a list with 4 elements.
Jun 29, 2013 12:49:57 [0x7f56d77fe700] ERROR - Failed to start session successfully.
Jun 29, 2013 12:49:58 [0x7f56d7fff700] DEBUG - Request: GET /library/sections/4/recentlyAddedGrandparents [50.18.245.203:51730] (7 live)
Jun 29, 2013 12:49:58 [0x7f56d7fff700] DEBUG - We found auth token (GqNmNMzvV7svFA3YBBPF), enabling token-based authentication.
Jun 29, 2013 12:49:58 [0x7f56d7fff700] DEBUG - Came in with the master token, authorization succeeded.
Jun 29, 2013 12:49:58 [0x7f56d7fff700] DEBUG - It took 0.000000 sec to serialize a list with 25 elements.
Jun 29, 2013 12:49:58 [0x7f5737fff700] ERROR - handle_stream_read error 2 End of file
Jun 29, 2013 12:49:58 [0x7f5737fff700] DEBUG - Removing notification stream because of error.
So it can NOT write to /home/rob/plex which is wired since I just made the folder trying to fix this problem.
Well I tried:
sudo chmod -R 777 /home/rob/plex
sudo chown -R plex:plex /home/rob/plex
Jun 29, 2013 13:16:50 [0x7f0d5b7fe700] DEBUG - Using profile Web
Jun 29, 2013 13:16:50 [0x7f0d5b7fe700] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/6734
Jun 29, 2013 13:16:50 [0x7f0d5b7fe700] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/metadata/6734
Jun 29, 2013 13:16:50 [0x7f0d7cff9700] DEBUG - Request: GET /library/metadata/6734 [127.0.0.1:54117] (6 live)
Jun 29, 2013 13:16:50 [0x7f0d7cff9700] DEBUG - It took 0.000000 sec to serialize a list with 1 elements.
Jun 29, 2013 13:16:50 [0x7f0d5b7fe700] DEBUG - Caching document http://127.0.0.1:32400/library/metadata/6734 as 2274dc82d35776242d7cd113668b193f0eaee882
Jun 29, 2013 13:16:50 [0x7f0d5b7fe700] INFO - Legends of Flight - video.width limitation applies: 1920 > 1280
Jun 29, 2013 13:16:50 [0x7f0d5b7fe700] DEBUG - Transcoding to hls/mpegts/h264/mp3
Jun 29, 2013 13:16:50 [0x7f0d5b7fe700] DEBUG - Found session GUID of ygv6sedpxyt7f1or in session start.
Jun 29, 2013 13:16:50 [0x7f0d5b7fe700] DEBUG - Using session GUID ygv6sedpxyt7f1or for new transcode session.
Jun 29, 2013 13:16:50 [0x7f0d5b7fe700] DEBUG - Cleaning directory for session ygv6sedpxyt7f1or (/home/rob/plex/plex-transcode-ygv6sedpxyt7f1or-b717ed6c-37c6-46ec-956f-370c9ec9cf54)
Jun 29, 2013 13:16:50 [0x7f0d5b7fe700] DEBUG - Universal profile computed resolution bounding box of 1280x720.
Jun 29, 2013 13:16:50 [0x7f0d7d7fa700] DEBUG - Request: GET /video/:/transcode/universal/session/ygv6sedpxyt7f1or/base/index.m3u8 [192.168.1.105:32789] (6 live)
Jun 29, 2013 13:16:50 [0x7f0d7d7fa700] INFO - Legends of Flight - video.width limitation applies: 1920 > 1280
Jun 29, 2013 13:16:50 [0x7f0d7d7fa700] DEBUG - Transcoding to hls/mpegts/h264/mp3
Jun 29, 2013 13:16:50 [0x7f0d7d7fa700] DEBUG - Starting a transcode session ygv6sedpxyt7f1or at offset -1.0 (stopped=1)
Jun 29, 2013 13:16:50 [0x7f0d7d7fa700] DEBUG - Job running: /usr/lib/plexmediaserver/Resources/Plex New Transcoder -i http://127.0.0.1:32400/library/parts/6343/file.mkv -threads 0 -y -segment_format mpegts -f segment -loglevel quiet -loglevel_plex error -map_metadata -1 -progressurl http://127.0.0.1:32400/video/:/transcode/session/ygv6sedpxyt7f1or/progress -vcodec libx264 -crf 20 -maxrate 3000k -bufsize 6000k -vsi 1280x720 -preset veryfast -x264opts cabac=0:me=dia:subme=0:me_range=4:no_chroma_me:8x8dct=0:bframes=0:rc_lookahead=1:qcomp=0.50:qpmin=10:qpmax=51:qpstep=4:partitions=none:cabac=0 -flags -global_header -segment_time 3 -segment_start_number 0 -force_key_frames expr:gte(t,n_forced*3) -map 0:0 -sn -acodec libmp3lame -ac 2 -aq 2 -map 0:2 media-%05d.ts
Jun 29, 2013 13:16:50 [0x7f0d7e7fc700] DEBUG - Request: GET /library/parts/6343/file.mkv [127.0.0.1:54118] (6 live)
Jun 29, 2013 13:16:50 [0x7f0d7e7fc700] DEBUG - Content-Length of /home/rob/imax2/Legends Of Flight (2010)/IMAX.Legends.of.Flight.2010.1080p.BluRay.mkv is 5474388587.
Jun 29, 2013 13:16:50 [0x7f0d5bfff700] INFO - [Transcoder] Input #0, matroska,webm, from 'http://127.0.0.1:32400/library/parts/6343/file.mkv':
Jun 29, 2013 13:16:50 [0x7f0d7cff9700] INFO - [Transcoder]     Stream #0:0(eng): Video: h264, yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Jun 29, 2013 13:16:50 [0x7f0d5b7fe700] INFO - [Transcoder]     Stream #0:1(rus): Audio: dts, 48000 Hz, 5.1(side), fltp, 1536 kb/s (default)
Jun 29, 2013 13:16:50 [0x7f0d7e7fc700] INFO - [Transcoder]     Stream #0:2(eng): Audio: dts, 48000 Hz, 5.1(side), fltp, 1536 kb/s
Jun 29, 2013 13:16:50 [0x7f0d5bfff700] DEBUG - Request: GET /library/sections/11/recentlyAddedGrandparents [54.241.42.63:46838] (6 live)
Jun 29, 2013 13:16:50 [0x7f0d5bfff700] DEBUG - We found auth token (GqNmNMzvV7svFA3YBBPF), enabling token-based authentication.
Jun 29, 2013 13:16:50 [0x7f0d5bfff700] DEBUG - Came in with the master token, authorization succeeded.
Jun 29, 2013 13:16:50 [0x7f0d5bfff700] DEBUG - It took 0.020000 sec to serialize a list with 1 elements.
Jun 29, 2013 13:16:51 [0x7f0d7cff9700] DEBUG - Request: GET /library/sections/1/recentlyAdded [54.241.42.63:46840] (6 live)
Jun 29, 2013 13:16:51 [0x7f0d7cff9700] DEBUG - We found auth token (GqNmNMzvV7svFA3YBBPF), enabling token-based authentication.
Jun 29, 2013 13:16:51 [0x7f0d7cff9700] DEBUG - Came in with the master token, authorization succeeded.
Jun 29, 2013 13:16:51 [0x7f0d7cff9700] DEBUG - It took 70.000000 ms to retrieve 89 items.
Jun 29, 2013 13:16:51 [0x7f0d7cff9700] DEBUG - It took 0.020000 sec to serialize a list with 89 elements.
Jun 29, 2013 13:16:51 [0x7f0d7d7fa700] ERROR - Failed to start session successfully.
Jun 29, 2013 13:16:52 [0x7f0dae355700] ERROR - handle_stream_read error 2 End of file
Jun 29, 2013 13:16:52 [0x7f0dae355700] DEBUG - Removing notification stream because of error.
So no more error about not being able to create the folder and I see in my plex folder it does indeed create a new random folder. But nothing is within that folder.
#34 suki
suki
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 09 July 2013 - 12:32 PM
I too had the same error. I realise I am posting in the wrong forum, as I have plex running on Synology, but maybe it helps you as well.
Plexserver versions tested:
0.9.7.28.33
0.9.8.0.36
0.9.8.1.46
On Synology Intel.
Somehow the temporary transcode folder was not set during the installations. In my case the temporary folder that is made by the installer was:
/volume2/Plex/tmp_transcoding/
After I set the temp transcode folder using the webinterface, settings, advanced settings, transcoder, 'temp folder for transcoding' the dreaded "Cannot load M3U8: 404 not found" was gone.
#35 PlexZone
PlexZone
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 14 July 2013 - 07:49 PM
Thanks a lot SUKI !!! This works have been looking for this solution for days, now works in windows and ATV3
Solution
Change webinterface "advanced settings" => transcoder => fill the emty field ex. "TempTranscoder"
#36 Benjo-Kazooie
Benjo-Kazooie
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 17 November 2013 - 06:19 PM
i have this error come up. but the same tv show works perfectly with ipad. but not on plex web. wtf?
#37 Trudge
Trudge
    Gone off to greener pastures....
  • Members
  • PipPipPipPipPipPip
  • 9403 posts
Posted 18 November 2013 - 01:13 AM
Each client is capable of direct playing different formats. With plex/web it comes down to what browsers you are using and what os you are running it on.
Primary PMS: Ubuntu 13.10, i7-4771, 16GB Ram, Samsung 840 Pro 512GB
Media Storage: 2 x ReadyNas Pro Business 18TB mounted by NFS to Plex Server
Desktop Clients: 1 x Windows 7 27", 1 x 15.4 Retina MBP, 2 x17" MBP, 1 x 13" MB, 1 x13" MBA
Mobile Clients: 2 x iPhone 5s, 3 x iPhone 5, 3 x iPhone 4s, 3 x iPhone 4, 2 x iPad 3, 2 x iPad 2
Airplay & PlexConnect Targets: 4 x ATV3
#38 singularetantum
singularetantum
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 08 December 2013 - 08:21 PM
Have the same Problem try to acces a shared libary thou webacces on his DSM 411j with Plex Server 0.9.8....
Home directory is working fine but by accesing the shared libary (its throug a different port random) i always got this problem. He dont has Plexpass).
#39 Trudge
Trudge
  • Members
  • 9403 posts
Posted 10 December 2013 - 02:55 AM
that NAS does not support transcoding.  you'll need to use a client that supports whatever format the media is in.
