Jump to content
[REL] SS Plex
tv movies streaming downloading
  • Please log in to reply
1679 replies to this topic
#1661 dwanthny
dwanthny
    Dedicated Member
  • Members
  • PipPipPip
  • 375 posts
Posted 18 May 2015 - 04:42 AM
What does the 'information' page say?
Answered in post 1655.
#1662 TornadoContest
TornadoContest
    Member
  • Members
  • PipPip
  • 73 posts
Posted 18 May 2015 - 04:47 AM
version of ss-plex
tv download location
movie download location
media downloads using curl
all mine says
& are you able to interact with those as editable fields or are they just straight text telling you your settings?
#1663 eetjtl
eetjtl
    Dedicated Member
  • Members
  • PipPipPip
  • 122 posts
Posted 18 May 2015 - 04:48 AM
Here is a screenshot
  • dwanthny likes this
#1664 eetjtl
eetjtl
    Dedicated Member
  • Members
  • PipPipPip
  • 122 posts
Posted 18 May 2015 - 04:52 AM
They are read only. The download via is pulled from ssplex settings settings and download to is pulled from plex library settings
#1665 japsander
japsander
    Newbie
  • Members
  • Pip
  • 5 posts
Posted 18 May 2015 - 05:44 AM
what clients access this server ?
Any DLNA devices ? If yes post the dlna.log
In particular do you have a LGTV on your network ?
clients that access are:
roku LT
fire tv (main)
nook HD+
LG-G2 phone (regular)
win 8 tablet
plex web on main pc (regular)
android set top box
log attached
cheers
#1666 eetjtl
eetjtl
    Dedicated Member
  • Members
  • PipPipPip
  • 122 posts
Posted 18 May 2015 - 02:06 PM
What do you see when you browse to http://127.0.0.1:324...ibrary/sections ?
#1667 eetjtl
eetjtl
    Dedicated Member
  • Members
  • PipPipPip
  • 122 posts
Posted 18 May 2015 - 05:25 PM
roku LT
fire tv (main)
nook HD+
win 8 tablet
android set top box
log attached
cheers
What I was looking for was a dlna log around the same time as the downloads.   This dlna is from 5-18 and the log bits you pasted were from 5-17
Do you have a dlna.log1  or 2 or 3 that is from 5-17 ?
#1668 eetjtl
eetjtl
    Dedicated Member
  • Members
  • PipPipPip
  • 122 posts
Posted 18 May 2015 - 05:54 PM
How do you access plex on the lgmobile ? Hopefully some other way than dlna.
From the log it appears the only device using dlna to your plex server is the LGmobile.
LG "smart share"(dlna) has been known to cause issues with 3rd party channels on Playon maybe it's doing the same with ssplex.
http://www.playonscr...=forums&p=15635
If possible I would turn off dlna from the plex server settings and see if the mystery downloads continue.
  • japsander likes this
#1669 japsander
japsander
    Newbie
  • Members
  • Pip
  • 5 posts
Posted 18 May 2015 - 09:20 PM
sorry, my oldest logs only start after yesterdays mystery downloads
i only use plex to connect on all devices
ill try with DLNA turned off for a few days to see if it makes a difference
thanks for the suggestion :)
#1670 JamminR
JamminR
    Plexpresso
  • Members
  • PipPipPipPipPipPip
  • 1633 posts
Posted 20 May 2015 - 03:19 AM
all mine says
version of ss-plex
Server - HW: Intel Core I5-4670K,16GB DDR3, 4TB RAID1 - SW: Win7x64 Ult. + PMS v0.9.11.13
Clients - 1x Roku 3 (95% primary), 2x Roku2 XS, 1x Android, 2x iOS devices,1x Win PHT (PHT least used)
Shares - From: 0  -  To: 9(2)  -   Proud PlexPass subscriber!
ISP: ~6mbps up/300GB monthly "cap" (avg usage ~170gb/mo)
Common WIKI FAQs I answer - How do I find the Plug-Ins folder? - How do I manually install a channel?
Agents/Plugins I use/like/favor - DVD Order Agent - Unsupported Appstore - SS Plex (Watch searches later!!!) - G2G.FM  Full Movies on Reddit
#1671 japsander
japsander
    Newbie
  • Members
  • Pip
  • 5 posts
Posted 22 May 2015 - 05:51 PM
id just like to say thanks @eetjtl
4 days without random episodes of nonsense messing up my library. turning off DLNA worked like a charm
#1672 javajunkie
javajunkie
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 22 May 2015 - 10:10 PM
Two questions.
I can't seem to get LMWT to work.  I've read multiple posts in different areas on the forums, and different sites, that this is an issue but they are dated a year ago.  Is anyone else currently having an issue getting this channel to work?  I state this because the first thread says the LMWT channel was added by SS Plex (otherwise I would ask this else where).
I bring this up because LMWT is the only channel I can find Frozen on to stream on the TV.  If we're all just waiting till LMWT gets fixed, could SS Plex please add Frozen?  I'd appreciate not having to hand my PC over vrquently, and being able to duck out so I don't have to hear "Let It Go" for the umpteenth time.
#1673 eetjtl
eetjtl
    Dedicated Member
  • Members
  • PipPipPip
  • 122 posts
Posted 22 May 2015 - 10:16 PM
try the LMWT- kiss version
https://forums.plex....s-kiss-edition/
#1674 markymanmark
markymanmark
    Member
  • Members
  • PipPip
  • 18 posts
Posted 25 May 2015 - 10:09 AM
hi ss-plex was working fine for me,installed and working for quite a while,lst week or two it then dissapeared from channel list,re-installed same again etc,even dissapears from plugins folder.any help would be much appreciated.
#1675 TornadoContest
TornadoContest
    Member
  • Members
  • PipPip
  • 73 posts
Posted 25 May 2015 - 02:58 PM
I was having the same thing happen. Do you happen to have JWSolve's Watch Series Online aka WSO.bundle installed? The SS-Plex cache files are also known as WSO, for some reason, and this causes a conflict. Getting rid of WSO.bundle and installing Sock Bramson's SS-Plex fork solved the problem for me. It was baffling to watch the plugin vaporize from the folder every time I "cleaned bundles". Hope this helps.
  • markymanmark likes this
#1676 markymanmark
markymanmark
    Member
  • Members
  • PipPip
  • 18 posts
Posted 26 May 2015 - 06:39 AM
hi yes did have wso installed,uninstalled now everything fine so many thanks.
  • TornadoContest likes this
#1677 xrider12
xrider12
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 26 May 2015 - 10:04 PM
Not sure if this was addressed but is there any way to switch the first source picked for streaming videos? Seems like most of the videos don't play or stutter unless i pick a better source manually in the "view all sources" option.
#1678 JamminR
JamminR
    Plexpresso
  • Members
  • 1633 posts
Posted 27 May 2015 - 03:42 AM
Unfortunately, Nope.
#1679 wammy70
wammy70
    Newbie
  • Members
  • Pip
  • 8 posts
Posted Yesterday, 10:25 PM
Is it just me or did as plex suddenly stop working? All downloads stall at 0 of 0%. Previously this worked fine.
Shrugs.
#1680 eetjtl
eetjtl
    Dedicated Member
  • Members
  • PipPipPip
  • 122 posts
Posted Yesterday, 10:41 PM
Nope still downloads for me.
What does your sslog say ? ( it's in the plugin folder unlike other channels)
Are you using curl or wget ?
Do you have a sample for me to try here and see if it's a particular video issue?
Also tagged with one or more of these keywords: tv, movies, streaming, downloading
