Jump to content
How To - Installing Plex on Ubuntu 12.10 64bit
  • Please log in to reply
49 replies to this topic
#41 RocketMan
RocketMan
    Newbie
  • Members
  • Pip
  • 5 posts
Posted 17 July 2013 - 05:20 PM
I am getting the same error on Linux Mint 15.
proteus@proteus-emachine ~/plex-linux $ sudo make install
Copying XBMC binary to /usr/local/lib/xbmc/xbmc.bin
install: cannot stat ‘xbmc.bin’: No such file or directory
make: *** [install-binaries] Error 1
Does anyone know how this can be resolved??? Thanks!
#42 RocketMan
RocketMan
    Newbie
  • Members
  • Pip
  • 5 posts
Posted 18 July 2013 - 08:56 PM
I executed "sudo make -d" to see if I could determine if there were any errors during the make. Following are the last 23 lines. Note the errors for zlib.h:
Live child 0x00a22c20 (FileFactory.o) PID 18818
In file included from FileZip.h:29:0,
                 from FileFactory.cpp:61:
/usr/include/zlib.h:86:5: error: ‘z_const’ does not name a type
/usr/include/zlib.h:94:5: error: ‘z_const’ does not name a type
/usr/include/zlib.h:1324:29: error: ‘voidpc’ has not been declared
/usr/include/zlib.h:1332:32: error: expected initializer before ‘Z_ARG’
/usr/include/zlib.h:1656:5: error: ‘z_off64_t’ does not name a type
/usr/include/zlib.h:1731:15: error: ‘z_crc_t’ does not name a type
In file included from ../PlayList.h:23:0,
                 from FilePlaylist.h:6,
                 from FileFactory.cpp:70:
../FileItem.h: In constructor ‘MediaPart::MediaPart(int, const string&, int)’:
../FileItem.h:107:15: warning: ‘MediaPart::key’ will be initialized after [-Wreorder]
../FileItem.h:106:7: warning:   ‘int MediaPart::duration’ [-Wreorder]
../FileItem.h:102:3: warning:   when initialized here [-Wreorder]
Reaping losing child 0x00a22c20 PID 18818
typedef struct z_stream_s {
    z_const Bytef *next_in;     /* next input byte */
    uInt     avail_in;  /* number of bytes available at next_in */
    uLong    total_in;  /* total number of input bytes read so far */
    Bytef    *next_out; /* next output byte should be put there */
    uInt     avail_out; /* remaining free space at next_out */
    uLong    total_out; /* total number of bytes output so far */
    z_const char *msg;  /* last error message, NULL if no error */
    struct internal_state FAR *state; /* not visible by applications */
    alloc_func zalloc;  /* used to allocate the internal state */
    free_func  zfree;   /* used to free the internal state */
    voidpf     opaque;  /* private data object passed to zalloc and zfree */
    int     data_type;  /* best guess about the data type: binary or text */
    uLong   adler;      /* adler32 value of the uncompressed data */
    uLong   reserved;   /* reserved for future use */
} z_stream;
ZEXTERN int ZEXPORT gzwrite OF((gzFile file,
                                voidpc buf, unsigned len));
make[1]: *** [FileFactory.o] Error 1
Removing child 0x00a22c20 PID 18818 from chain.
make[1]: Leaving directory `/home/proteus/plex-linux/xbmc/FileSystem'
Reaping losing child 0x018b9220 PID 18808
make: *** [xbmc/FileSystem/filesystem.a] Error 2
Removing child 0x018b9220 PID 18808 from chain.
Here's the error lines from zlib.h highlighted in red:
    z_const Bytef *next_in;     /* next input byte */ /* line 86 */
    z_const char *msg;  /* last error message, NULL if no error */ /* line 94 */
} z_stream;
ZEXTERN int ZEXPORT gzwrite OF((gzFile file,   /* line 1324 */
ZEXTERN int ZEXPORTVA gzprintf Z_ARG((gzFile file, const char *format, ...)); /* line 1332 */
#else
#  define gzgetc(g) \
          ((g)->have ? ((g)->have--, (g)->pos++, *((g)->next)++) : gzgetc(g)) /* line 1656 */
#endif
/* undocumented functions */
ZEXTERN const char   * ZEXPORT zError           OF((int));
ZEXTERN int            ZEXPORT inflateSyncPoint OF((z_streamp));
ZEXTERN const z_crc_t FAR * ZEXPORT get_crc_table    OF((void)); /* line 1731 */
ZEXTERN int            ZEXPORT inflateUndermine OF((z_streamp, int));
Does anyone have any idea if this is what's causing xbmc.bin not to be built and, if so, can it be fixed?
Any help here is appreciated. Thanks.
#43 logy
logy
    Newbie
  • Members
  • Pip
  • 9 posts
Posted 27 July 2013 - 07:28 AM
on XUbuntu 13.04 Raring Ringtail i got the same
this does it for me:
1. backup existing zlib.h
mv /usr/include/zlib.h /usr/include/zlib.h.bkp
2. copy zlib.h zconf.h zlib.li from xbmc/lib/zlib folder of the git cloned files to /usr/include
cd ~/
cp plex-linux/xbmc/lib/zlib/z* /usr/include
  • Jason Mehring likes this
#44 cirkator
cirkator
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 04 August 2013 - 07:41 PM
Thanks!
I will try that when I get home from my holidays.
#45 supergillis
supergillis
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 10 August 2013 - 09:36 AM
} z_stream;
} z_stream;
#else
#endif
The bug report on debian.org states that you can just remove xbmc/FileSystem/zconf.h. See http://bugs.debian.o....cgi?bug=707537
Removing that file allowed me to compile it on Debian Jessie. I've forked gewalker's repository and committed the patch. See https://github.com/s...aafc4d65e8b6271
Good luck!
#46 peiopeio
peiopeio
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 19 August 2013 - 01:35 PM
I managed to compile it on my LMDE distro but when I select anything in the menu I get a black screen. I can just go back but obviously it's not usable. Any idea ?
#47 cirkator
cirkator
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 20 August 2013 - 09:03 PM
The same is happening to me....
#48 Penetal
Penetal
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 02 September 2013 - 07:20 PM
If you are having problems with the message that xbmc.bin is being an evasive ass, I have found 2 possible things to help you on your way.
from the submodule config I made sure that the address pointing to the xbmc/ffmpeg had ".git" at the end, not sure if that actually matters, but I did add it anyway.
make sure you have libGL.so installed.
From my install:
/usr/lib/x86_64-linux-gnu/libGL.so -> libGL.so.1
This is used during the
make
process.
PS
for me cloning from HTTPS almost always failed during the download. Saying the remote host disconnected or something. So I got myself a github account, and added the ssh key to it. that way I could easily use the git@github.com:gewalker/plex-linux link for cloning instead. This always works without it being interrupted midways.
#49 BoostFlow
BoostFlow
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 02 September 2013 - 11:07 PM
I used the tutorial in this topic to install PMC on a fres install of ubuntu 12.04 LTS. I followed the tutorial with the adjustments for 12.04:
Change libboost1.49-all-dev to libboost-all-dev
Change /usr/lib/x86_64-linux-gnu/libfaad.so to /usr/lib/libfaad.so
Plex Media Center starts up perfect and everything is detected including audio. However when I start a movie / tv show plex popsup with please wait and than nothing. I can resume browsing my videos but there is no playback. Same goes for the YouTube plugin. I tried glxgears and the proprietary amd driver is working. I can also see my movie database and my iOS device detects the PMC running on Ubuntu.
Is there something i'm doing wrong?
#50 stuhad
stuhad
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 16 December 2013 - 01:21 AM
Is it possible to update the client, can someone help me get started with the commands needed? Thanks
