Jump to content
could not connect to 127.0.0.1:32400
  • Please log in to reply
51 replies to this topic
#21 ezeben20
ezeben20
    Newbie
  • Members
  • Pip
  • 5 posts
Posted 29 April 2013 - 01:05 PM
I have server 2012 essentials and plex media server 0.9.7.23  I have the  same problem:
(not connect to 127.0.0.1:32400 on the browse)
Nobody has a real  solution for this problem.......!!!!!!!!!
#22 Trudge
Trudge
    Gone off to greener pastures....
  • Members
  • PipPipPipPipPipPip
  • 9403 posts
Posted 29 April 2013 - 01:08 PM
Post your Plex Media Server.log file
http://wiki.plexapp....#Plex_Log_Files
Primary PMS: Ubuntu 13.10, i7-4771, 16GB Ram, Samsung 840 Pro 512GB
Media Storage: 2 x ReadyNas Pro Business 18TB mounted by NFS to Plex Server
Desktop Clients: 1 x Windows 7 27", 1 x 15.4 Retina MBP, 2 x17" MBP, 1 x 13" MB, 1 x13" MBA
Mobile Clients: 2 x iPhone 5s, 3 x iPhone 5, 3 x iPhone 4s, 3 x iPhone 4, 2 x iPad 3, 2 x iPad 2
Airplay & PlexConnect Targets: 4 x ATV3
#23 ezeben20
ezeben20
    Newbie
  • Members
  • Pip
  • 5 posts
Posted 29 April 2013 - 03:20 PM
#24 Trudge
Trudge
  • Members
  • 9403 posts
Posted 29 April 2013 - 03:42 PM
so, from the machine running PMS, this does not work -> http://127.0.0.1:32400/web ?
and from any other machine, this doesn't work http://192.168.1.148:32400/web ?
#25 ezeben20
ezeben20
    Newbie
  • Members
  • Pip
  • 5 posts
Posted 29 April 2013 - 04:01 PM
through this address is does not work http://192.168.1.148:32400/web
when i restart the plex server it works for a few minutes and then it stop
  • Attached File  111.jpg   15.85KB   19 downloads
  • Attached File  2222.jpg   36.29KB   17 downloads
#26 ezeben20
ezeben20
    Newbie
  • Members
  • Pip
  • 5 posts
Posted 30 April 2013 - 11:56 AM
#27 Crumlett
Crumlett
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 01 May 2013 - 01:27 AM
Here is a useful link for full removal. Any problems let us know.
http://wiki.plexapp....ks#Uninstalling
Had the same issue.
Stopped all services
Uninstalled Plex
deleted the user directory
deleted the registry key
reinstalled the app
Seems to be working now
#28 aah choo
aah choo
    Member
  • Members
  • PipPip
  • 29 posts
Posted 01 May 2013 - 03:57 AM
This works for me:  http://127.0.0.1:324...tml#!/dashboard
#29 Brianmoose
Brianmoose
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 03 May 2013 - 11:20 AM
I am having a similar issue...
I am running on Windows 8
I can open http://127.0.0.1:32400/ via IE 10 in desktop mode BUT when I open the Windows IE 10 App (Metro UI) I get the error...
Any ideas?
#30 Trudge
Trudge
  • Members
  • 9403 posts
Posted 03 May 2013 - 11:27 AM
Any ideas?
You've just discovered MS's new totally stupid security policy of not letting Metro apps talk to localhost *sometimes*
you can try this -> http://forums.plexap...e-2#entry321471
http://blogs.msdn.co...-exemption.aspx
#31 sigfrid
sigfrid
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 06 May 2013 - 11:29 PM
Yeah, I have the exact same problem. Windows 8. PMS 0.9.7.22. The application still runs but I can't access the media manager or the actual server from any device. I even did a complete fresh install and it didn't fix the problem.
I'm having the same problem, running PMS on Windows Server Essentials 2012, everything will run fine for a while and then it crashes.  I can see the PMS server still running, but can't access it remotely or locally.  The port is still open and the app/services are all still running but PMS stops responding completely.
Sucks having to constantly restart it
same problem as described above, is there a solution ? I don't understand how to solve, if a solution has been found....
I haven't the problem of server and client on the same machine, simply the server after some time doesn't respond anymore and i have to reboot machine in order to make it work again
Running  Windows 8. PMS 0.9.7.22
#32 sigfrid
sigfrid
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 07 May 2013 - 09:36 PM
No one having this issue or that have solved in any way ?
I think that i will be forced to abandon plex, because with this issue isn't usable...
#33 TechnoAg
TechnoAg
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 27 June 2013 - 02:34 AM
I had a similar problem after upgrading to Windows 8.1 Preview, the dashboard stopped working. I tried disabling the firewall, using the actual IP Address as well as the computername/dns of the local PC. Eventually switching to localhost worked for me. So give this one a try:
http://localhost:32400/web
  • jmk94903 likes this
#34 jmk94903
jmk94903
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 04 July 2013 - 05:02 AM
Hi TechnoAg,
This worked for me also on Windows 8.1, but the key was including the http:// which shouldn't be necessary.
I retried http://127.0.0.1:32400/web, and it fails.  They should be equivalent, but they are not.  Weird!
Thanks for getting me to try this one more time, the right way, and to succeed.
Now, who knows how can the setting in Plex Media Server be changed to look to http://localhost:32400/web instead of the failing 127...?
John
#35 nnssserver
nnssserver
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 27 July 2013 - 04:09 AM
I had the same problem. Instead of typing "127.0.0.1:32400" into your browser,
try replacing it with this:
"localhost:32400"
without the quotes of course :)
worked for me :)
Wait a sec nevermind... didn't see the reply.. do what TechnoAg is saying to do.
Is a repair of plex an option?
Edited by nnssserver, 27 July 2013 - 04:11 AM.
#36 jimbobwayatx
jimbobwayatx
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 22 August 2013 - 10:25 PM
Since there doesn't appear to be any fix in sight, I'm abandoning Plex over this, since I can't use it in its current form.  Sad but I don't see any other option.  Hopefully this will be repaired one day.
#37 maeckes
maeckes
    Member
  • Members
  • PipPip
  • 10 posts
Posted 30 August 2013 - 06:33 PM
From one day to to another I couldn't connect to Plex via my LG TV.
I also couldn't connect to localhost:32400 or 127.0.0.1:32400
So I uninstalled Plex, deleted the plex folder in c:/users/Appdata and also deleted the folder in registry.
Then I tried to install Plex again -> still the same problem!
My System: Windows Home server 2011 (nearly the same like Windows 7)
#38 encosat
encosat
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 10 September 2013 - 10:54 AM
Hi phat78boy,
Thank you very much for advice.Works great!
For those who still can't connect to PMS please try tips from phat78boy.
Cheers!
#39 TheSatman
TheSatman
    Dedicated Member
  • Members
  • PipPipPip
  • 113 posts
Posted 23 December 2013 - 12:48 PM
Had a likewise situation after installing the update 0.9.8.17.282-c844f09. Both from the local machine 127.0.0.1 and localhost, and by the dedicated IP 192.168.xxx.xxx (local and over LAN). Not sure what the cause was but this is how I solved it: Windows control panel, remove Plex. I did not remove the folders, nor did I deleted the registry key. Then, without a reboot, install Plex again. Plex then tells you it needs a system reboot (something I did not see when installing the new version over the old). After the reboot, Plex started and I see that the library was updated (a windows popup with a green progress line). After that, all worked fine again.
The era of movie viewing in the dark has passed!!!
Plex Server 1:             Windows 7 64-bit VM on VMware ESXi 5.1.0, HP ProLiant N54L
Plex Server 2:             Linux Flawless Plex 64-bit VM on VMware ESXi 5.1.0, HP ProLiant N54L
Media Storage 1:         2 + 1 TB Network shared USB Hard Drive
Media Storage 2:         3 TB XPEnology NAS server DSM 5.0-4458 VM on VMware ESXi 5.1.0, HP ProLiant N54L
Plex Clients:                Roku Streaming Stick 3500R with official Plex app + RARflix //
                                    Multiple Android devices // iPad1 // iPad3 // Plex/Web
Home entertainment:  Pioneer VSX-921 // Pioneer BDP-140 // Philips projector LC-6131 //
                                    85" Mocom 2D /HD, Passive/Active 3D Projection Screen - 20 Gain //
                                    Finlux 32" HDMI TV // 50Mb-50Mb Fiber internet connection
#40 sa2000
sa2000
    Plex Star
  • Members
  • 13767 posts
Posted 23 December 2013 - 04:13 PM
I do not know how the Ninja's would go about troubleshooting this - but i would start this way:
For each of the 2 PMSs:
Screenshots of PMS Settings with Show Advanced Settings for myPlex and Network.
Output from http://localhost:324...dex.html#!/info
Information on what Plex\Web sessions or Plex Client (eg PHT) that are signed in to myPlex on that computer
ipconfig /all or if unix ifconfig -a or whatever is equivalent for Mac
Any portforward from the router to the IP address of the PMS
Sign in to myPlex in a browser to http://my.plexapp.com
and after sign in, change the url to https://my.plexapp.com/pms/servers and copy the output to a text file. You can obfuscate part of the WAN IP Addresses - but leave the local IP Address and attach
Help given free on forums.      Fee-Based Personal Support & Help.
_______________________________________________________________________________________
Getting Started     Downloads     PlexPASS     Channels     FAQs     Changing PMS Data Location     Changing Media Location    Plex Downloads md5 checksums
Supported Plex Companion/Remote Control Apps               Resetting System & Framework Bundles (include WebClient.bundle if Plex/Web loading issues)
Diagnostics:   Troubleshooting   Plex Media Server:   Reporting Issues    Logs    Crash Dumps         Plex Home Theater: Reporting Issues     Logs     Crash Dumps            Plex Web App: Debug Log
Plex for iOs:   Console Log & Crash Dumps                 Plex for Android:     Email Device Logs          Roku: Logs   FAQs            Samsung:  Plex User Manual
Server Connect for Remote Access: Plex Media Server - Connect     Network Ports to allow     Connecting a Server   Troubleshooting Server Connections (incl Double NAT check)
Sharing of Connected Server
Current Issues:
- Plex Sync for Whole (Large) Library Sections crashes out the Plex Media Server on Windows (memory):
- Locked out from server if PlexHome and server removed or password changed - see new support page {Password Change issue fixed in 0.9.11.16}
- Curl 52 Errors and MTU Size - Seen on Linux/NAS platforms on 0.9.11.13 - see this PlexPASS post
- Third Party and Malware and AdWare dll's that crash mswsock.dll leading to Plex Media Server crashes on windows systems
AsProxy.dll, BDL.dll, CatWSPrx.dll, ColorMedia.dll, CovenantEyesProxy.dll,cwalsp.dll, EasyRedirect.dll, GfKLSPService.DLL, HMIPCore.dll, ICProxy.dll, LavasoftTCPService.dll, MintCastNetworks.dll, MyOSProtect.dll, MyRadioPlayer.dll, mza.dll, N1Service.dll, PCProtect.dll, Plsapp.dll, QProxy.dll, Rslsp.dll, SafeIPs.dll, sendori.dll, SmoothPingProxy.dll
