2017 4K LG OLED - OLED55B7 native client
smart-tv
#1
Hello,
Is there any plans to address the official plex client for the new (2016+) LG OLED TV's? It does not have the correct profiles set for the tv. For this platform am I being forced to purchase a 3rd part app (XPlay) because plex dropped this platform 1+ Years ago?
I know the network stack is junk, but it would be nice to have a official client that worked.
#2
I have the OLED65B7P and am interested to know what the problems are. As far as I know Plex is ok other than 4k.
Also what troubles are there with the network stack and how does that impact the TV?
#3
@sheptard said:
Hello,
Is there any plans to address the official plex client for the new (2016+) LG OLED TV’s? It does not have the correct profiles set for the tv. For this platform am I being forced to purchase a 3rd part app (XPlay) because plex dropped this platform 1+ Years ago?
Really, please explain your statement of dropping support of LG WebOS. As far as I know this statement is absolute rubbish.
I’m not being personal but please explain where and why you have come to this conclusion?
#4
Lol, I sure hope it was an automated system marking your comment as an answer.
The LG App store says the client hasn’t been updated in a year.
This TV has been out for a year and plex hasn’t figured out how to use the built in media player on the TV itself to play 4k content?
The network stack sucks because the ethernet port is only 100mbit, and the wifi is junk with the 2 ap’s I’ve tested so far, and makes it impossible to watch 80mbps 4k hdr content so far. 50mbps plays kinda okay on wifi, but still far from ideal. far less than the 1300 mbps claimed by LG that the TV can achieve.
#5
Once again I must explain. The app is automatically updated. If you check your app on TV, settings/about . You will find current app version, also in PMS/settings/devices you will find it also.
This page will list all the updates:
#6
once again you must explain?
Hey thats great, but the clients still crap. I’m now now using the plex client for the nvidia shield tv which is only slightly less terrible.
#7
The LG content store app doesn’t seem to display the version numbers correctly. Maybe it’s showing the first version it was registered… I don’t know. Once the app is installed, you’ll find it newer than what it actually displayed on the store. The best way to check the actual version of Plex is looking at the app settings menu as explained above.
In the mean time, it’s also true that the latest version (3.13.1) of Plex app is not available to at least some LG models (2017) on webOS 3. I have an open issue for asking updates, but no luck as of yet.
#8
Why do i need to explain a known fact that i have shown you with proof.
#9
Yeah it would be good if people can answer questions instead of being so hostile, I also have an Lg Oled and the Plex client is pretty poor, for example as i can’t play anything that is transcoded, direct play is fine but as soon as transcoding kicks in the app fails to play the stream - server says its transcoding but all you get is an error on the tv.
#10
Why do you think it the app and not the beta Plex media server. The server does the trans coding.
#11
I have the same issue with you, Plex’s official page for Smart TV only lists the direct playback support for the 2013 NetCast Models
Additional Direct Play video support:
  • ASF container with vc1 or wmv3 video encoding
  • MKV container with H.264 video encoding
  • MPEG-TS container with mpeg2video video encoding
Additional Direct Play music support:
  • ASF container with wmav2 audio encoding
  • OGG container with vorbis audio encoding
  • WAV container with pcm_u8 or pcm_sb16e audio encoding
#12
I have stopped using the Plex app all together, and use the built-in DLNA client. It works well, and will mark content as viewed when you finish it. (Which is about all i need). I’m missing out on all the extra movie info though. The PlayX app seems to have a few quirks too.
Didn’t know the B6V (or 7 series) only has a 100mbit ethernet port, thats just… pathetic. Now i see why it was stuttering so bad when using high bitrate 4k movies.
#13
Hmm ok so ive got a 4k clip of Elysium with an overall bitrate of 60Mbps, video is HEVC at 57Mbps, using the built in player from LG it runs butter smooth and looks fantastic and I can see network activity at around a constant 52Mbps, and plex reports its Direct playing, yet the official plex app will only transcode ??? why
#14
Need to edit the profile file. Works beautifully then, including HDR :*
#15
Mind helping with a detailed post or link to what how-to fir what exactly should be changed?
I am sure I can RTM and eventually get there, but if you have it figured out or followed some other post it would be greatly appreciated!
#16
where is this profile file kept ?? I’m running windows 10
#17
also which log file shows what profile it is using ??
#18
In Windows 10 x64, profiles are in ‘%ProgramFiles(x86)%\Plex\Plex Media Server\Resources\Profiles’. These get replaced after a server upgrade so I created a folder called ‘Profiles’ in ‘%localappdata%\Plex Media Server’
The profile used in my case is HTML TV App.xml. You can find the correct one in ‘Plex Media Server.log’
Files will be direct streamed for mkv.
#19
so why hasn’t plex themselves sorted this out if its just a simple file edit ??? why is there no LG or WebOS profiles ?
#20
I’m only guessing but would it be Generic.xml or even Universal tv.xml
