4K buffering
roku
#1
After figuring out the setting I needed to turn on to get the tv to get it to work right, I’m getting constant buffering. Here is the stream info.
#2
This is over 802.11 ac. You can see I’m getting almost 200 mbps. It says the original is only 76 mbps. This should work right?
#3
This is interesting. I am having a problem with direct play constant buffering on my rokuTV as well. Remote server, but everything direct play with plenty of bandwidth and still buffering. I do not understand. Other remote clients are playing the same media with no problem.
#4
Also, Roadzy, that number that says Bandwidth is actually the Bandwidth Required not your actual bandwidth.
