A few questions about using plex server with multiple firesticks.
server-windows
#1
Hello, I have 3 firesticks and I am trying to do a system that plays a playlist on all three firesticks. I have a few questions regarding updating the play list, and how to use the logs to troubleshoot connectivity issues.
Question 1: I have the server set to scan the libary every hour, how do I get new videos added to the playlist automatically, and the old videos removed?
Questions 2: I have the Plex server installed as a Hyper-V host (Windows 10 enterprise), I was able to connect all the firesticks to the plex server, load the play list, shuffle, and repeat all. However, after about 1 - 2 hours the firesticks loose access to the server. I need to know where these drops in connectivity are logged so I can try to figure out what the cause it. It is a full gigabit network, all on the same subnet, all the other Hyper-V host do not loose connectivity, all other wireless devices have good signal in the same area as the tvs, low ping times when pinging firesticks from the server..
#2
That’s not possible in Plex, AFAIK.
Once a playlist is started, it stays as it was. Even if you have a ‘smart’ playlist which updates itself dynamically, you’d have to stop playback of this playlist and then restart it for the new additions to be included.
You might want to look for a software solution from the field of ‘Digital Signage’
Questions 2: after about 1 - 2 hours the firesticks loose access to the server. I need to know where these drops in connectivity are logged so
On the server side, a loss of connectivity during playback should get noted in the main Plex Media Server.log. You need to have ‘Debug Logging’ activated on the server.
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
You could also inspect the logs of the Firesticks themselves.
https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/
No wireless network has never any interruptions.
If you want guaranteed availability, go with wired clients.
There could even be an issue with the hardware itself, if they overheat after 2 hours of uninterrupted use with high-bitrate content.
Nonetheless, here is a tip which is good for both Plex Servers and clients on Windows:
#3
Thanks I will check into your suggestions
#4
Okay, sorry for the delay. I purchased fire stick Ethernet adapters, ran cabled, migrated the server off a vm to a physical device, entirely gigabit network, and disabled power management for the LAN connection. Still same issues.
