A Imdb.com agent.
The storyline’s on freebase.com sems to be to general. can there be made a IMDB.com agent to be used?
example:
from freebase:
from IMDB.com
HI,
Put themoviedb agent higher on the priority list than freebase, then you will get it's plot summaries.
from themoviedb
Themoviesdb can give you some "foreign" movie posters though, so best to also place the moviepostersdb agent above it.
i.e.
![post-7970-0-98343900-1346533460.jpg|542x500](upload://RWOm9TSTyfivE6R8EIcpcTNyJe.jpg)
or, there is an IMDB agent floating around somewhere in the forums.
How is it possible I dont have the menu “Agents” in my Preferences? :o
If you are on a mac, you get to them from the star/gear icon towards the top left of the media manager screen.
If you only have access to either web manager can you still do this (linux PMS)? I too really don’t like all the stuff about release date etc
Edit - found it in the general preferences of the old web manager. Excellent, thanks for the tip Trudge!!
If you have a Linux or windows PMS you will have the screenshot above under preferences in the media manager.
I guess now I need to do a deep scan to change all the plots?
Full Refresh (Shift+ icon)
Hmm had already chosen Deep Scan :frowning: Now I can’t even access either the old web manager or the new web client…
Tried a shift + icon and that seems to kill the server as well.
No obvious errors in the logs - just a line that says this:
Sep 02, 2012 23:56:47 [0xabeffb70] WARN - WebSocket: Ignoring message since we’re closing the connection
