A New Experimental Plex Front End
Genus is now officially live on the Apple TV. I really appreciate the support, testing and feedback. If I can get a decent amount of sales, I will be able to start work on support DVR (need to buy some hardware), so please spread the word.
Not available in Austria
 Is EU release planned?
Is Dolby Vision/HDR supported with this build, of not will it be in future versions? I am currently using Infuse which supports pretty much everything. I would like support continued development of this project.
Well done for doing what Plex developers can’t seem to do.
It is, but I need to jump through some EU hoops I wasn’t aware of. Working on it now.
Yes, if the version of DV and HDR that your files have are supported by the native AVPlayerkit, they will play fine.
Can’t seem to get either one of my Plex servers to load up. Just get “Updating” in upper right. One is remote and the other is local.
Hm okay. Could you create a ticket here with all the details you can? DIdn’t run into this with anything of our beta testers, etc.
Submitted. I think it has something to do with only showing the LAN addresses for all servers I own and a part of. Even my friends servers show their LAN address. I’m using a custom domain on one server and the other is behind the Docker Network.
QQ do you have secure connections set to “Required” on your server? If so you running into the issue I’ve been running into myself.
I just tried out the last TestFlight version and still ran into the error. It might be that, simple quick check to verify.
Yeah the current test flight version doesn’t have that fix. I am prepping a new beta with some new features now, that will include that fix.
No my secured connection is set to “Preferred” for both my servers. Maybe it’s related.
Dolby Vision appears working in the new Betas but the highlights are clipped, not tone mapping as it should. Media files are Profile 8 and supported on the ATV. Is it reasonable to expect this will ever get fixed? No issues with Infuse on playing back the same file.
Possibly. this will be fixed in the next beta. Its fixed in the released version already.
if its something that has to do with the Plex side, absolutely. If its a limitation of AVPlayer, then not until Apple fixes it, since we use AVPlayer.
I just submitted the first beta of v1.1 which has the secure connection fix and support for PMS upgrades from within Genus. Hopefully you’ll get notices in the next hour!
I tried it but my remote server using a custom domain name is failing to connect. I get a red “could not connect to the server” message.
when selecting my local server, I get a red message after a minute of “request timed out”
hmm wonder why it’s not connecting to the plex servers. Is there a way to get logs?
Love the direction of this app.
Very interested to see what you do with Live TV/DVR @chrisjdavis ! I’m sure it’ll look as pretty as the rest of the app!
Any plans to bring this to iOS/iPadOS? Love apps that use AVPlayer.
yeah I am doing some POC for an iPadOS app and a native desktop app. iOS will require a full redesign, so leaving that to last.
There should be logs for Plex on whatever machine you are hosting it on. Are you using the newest beta that came out yesterday via the testing list?
Yes latest beta was used. 1.1 build 1.
I’ll have to test when I get home tonight and see if the PMS logs show any hits. This newer version does not show the IP address like the old build did, so if it’s not hitting PMS then I wont have any logs to share.
