A problem has been detected with a core component of Plex Media Server.
server-mac
#1
Noob here, be patient. Can't get ANYWHERE with Plex... MacBook Pro (for now), can't add libraries, it all starts with the title: "A problem has been detected with a core component of Plex Media Server." Server ok as far as I can tell.
#2
Logs attached.
#3
Logs attached.
Do you have vpn or proxy software installed or another application using tcp port 32400?
HTTPError: HTTP Error 407: Proxy Authentication Required
and why is the Plex Media Server.app installed within ~/Applications instead of /Applications -
There are some errors accessing the application files there
Mar 11, 2018 18:48:07.058 [0x700001718000] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/Users/VOiDMiX/Applications/Plex Media Server.app/Contents/Resources/Plug-ins-6de959918/LastFM.bundle/Contents/Code", couldn't check file: /Users/VOiDMiX/Applications/Plex Media Server.app/Contents/Resources/Plug-ins-6de959918/LastFM.bundle/Contents/Code
Mar 11, 2018 18:48:07.058 [0x700001612000] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/Users/VOiDMiX/Applications/Plex Media Server.app/Contents/Resources/Plug-ins-6de959918/Fanart-TV.bundle/Contents/Code", couldn't check file: /Users/VOiDMiX/Applications/Plex Media Server.app/Contents/Resources/Plug-ins-6de959918/Fanart-TV.bundle/Contents/Code
Mar 11, 2018 18:48:07.058 [0x700001695000] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/Users/VOiDMiX/Applications/Plex Media Server.app/Contents/Resources/Plug-ins-6de959918/HTbackdrops.bundle/Contents/Code", couldn't check file: /Users/VOiDMiX/Applications/Plex Media Server.app/Contents/Resources/Plug-ins-6de959918/HTbackdrops.bundle/Contents/Code
Mar 11, 2018 18:48:07.058 [0x700001718000] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/Users/VOiDMiX/Applications/Plex Media Server.app/Contents/Resources/Plug-ins-6de959918/LastFM.bundle/Contents/Info.plist", couldn't check file: /Users/VOiDMiX/Applications/Plex Media Server.app/Contents/Resources/Plug-ins-6de959918/LastFM.bundle/Contents/Info.plist
A corrupt install ?
Disk space issue?
Permissions?
#4
I forgot I had my proxy on... turned it off and it's now working. Thank you.
#5
Which VPN do you use?
I use PIA without issue
