A problem has been detected with a core component of Plex Media Server.
server-drobo
#1
I’ve been running plex on my Drobo5N for a while, recently i was having trouble with the dashboards in plex. after much attempts to fix, i decided to reinstall all my plex files. after uninstall and reinstall i’m running into the an issue that says
“A problem has been detected with a core component of Plex Media Server.
Please visit the forums and provide your logs, as described here .”
i get the above message after the “Please wait a moment while Plex starts” message.
forums link brings me here
here link takes me to a 404 page (https://support.plex.tv/hc/en-us/articles/200250417-log-file-locations)
when i try to add a folder for tv or movies i get a “Your changes could not be saved.” message and i cant seem to add the folder
anyone else have this issue? please help and thank you in advance.
see attached for images.
#2
This error arises if the agents fail to start or are too slow starting up
See if the problem clears up after reboot / restart
A zip of the logs would help - together with screenshot showing error and time of error
The Logs and Logs\PMS Plugin Logs are below the Plex Media Server directory
See https://support.plex.tv/articles/202915258-where-is-the-plex-media-server-data-directory-located/
The issue with links to articles giving an error is being looked into
#3
so... the problem kinda just fixed itself. after all the failed attempts last night. i completely removed plex and shut down the drobo and went to bed. today after work, i reinstalled plex and everything seems to be working fine now
¯_(ツ)_/¯
thanks for your reply @sa2000
