A server could not be found.
server-linux
#1
A server could not be found. Download and install Plex Media Server, and it will appear here.
on GCE ( Ubuntu 16.04 LTS is on google cloud engine)
how to fix issue ?
#2
https://support.plex.tv/hc/en-us/articles/200288666-Opening-Plex-Web-App
If you're on a different network than the server computer, you'll first need to set up a SSH tunnel so that you can access things as if they were local. This is only necessary for the initial setup. After initial setup, you should be able to access by using the network IP address as normal.
#3
Thanks Peter_W
i have more question
I can add media Storage on linux server ( GCE) ?
#4
working thanks
#5
Never used GCE so I will not be able to answer that question, though adding various storage locations to Linux in general, and get them to be visible for Plex specifically, is doable (albeit can be hard if you do not know enough about permissions and ownership). What this "media storage" is, and how you would add it to GCE, is perhaps best asked to the support of that cloud platform.
Also, remember that Plex has its own cloud platform service - https://support.plex.tv/hc/en-us/articles/226645727-Getting-Started-with-Plex-Cloud
