Accent in french in movies description
samsung-smart-hub
#1
Hello
On my server the description of the movies is displayed in French correctly.
On the Plex app of my DVD Player all accented characters are incorrect.
Example:
é replace é
é replace è
ê replace à
Do you have any suggestions for solving this problem?
I did the installation recently everything works well, except also for accents in French in another request for support.
Thank
#2
If the file is a .srt file, make sure the encoding is UTF-8 and check if the characters are actually correct inside the file.
If it's inside the video, it's not something we can fix.
