After upgrade to 1.13.2.5154, Plex Transcoder now randomly starting lots of threads
server-linux
#1
Which sends my system load through the roof (over 30). I can't see any rhyme or reason to why/how these transcoding threads are started. No-one is watching any content through any client apps. Here's an example process list:
plex 5821 2032 66 20:32 ? 00:08:54 /usr/lib/plexmediaserver/Plex Transcoder -codec:0 hevc -ss 120 -i /media/video/TV/Westworld/Season 2/Westworld - S02E04 - The Riddle of the Sphinx - HDTV-1080p.mkv -map_inlineass 0:2 -filter_complex [0:0]scale=w=1920:h=1080[0];[0]format=pix_fmts=yuv420p|nv12[1];[1]inlineass=font_scale=1.000000:font_path=/usr/lib/plexmediaserver/Resources/Fonts/DejaVuSans-Regular.ttf:fontconfig_file=/usr/lib/plexmediaserver/Resources/fonts.conf[2] -map [2] -metadata:s:0 language=eng -codec:0 libx264 -crf:0 16 -maxrate:0 14332k -bufsize:0 28664k -r:0 23.975999999999999 -preset:0 veryfast -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -map 0:1 -metadata:s:1 language=eng -codec:1 copy -copypriorss:1 0 -f segment -segment_format matroska -segment_format_options live=1 -segment_time 1 -segment_header_filename header -segment_start_number 0 -segment_list http://127.0.0.1:32400/video/:/transcode/session/b606280e-6f8f-46be-ade8-3c68a664ddd7/5d5851db-215b-434d-8d1a-fe3f0db9c34c/seglist -segment_list_type csv -segment_list_size 2147483647 -segment_list_separate_stream_times 1 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 chunk-%05d -map 0:2 -f null -codec ass nullfile -start_at_zero -copyts -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/b606280e-6f8f-46be-ade8-3c68a664ddd7/5d5851db-215b-434d-8d1a-fe3f0db9c34c/progress
Last time this happened about a dozen separate processes were started up. They run for a few minutes then go away. This has never happened before . I do have thumbnail generation on, but that only runs during the scheduled tasks window.
My system is running Ubuntu 16.04.4, fully patched and updated.
#2
Please post the full logs so that we can tell you which user / client started the transcode session.
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
#3
After checking the PMS logs, I’ve determined that a rogue client is the cause–the Plex add-on for Kodi Krypton. Restarting Kodi didn’t do the trick, so I rebooted the whole Kodi box and the issue appears to be resolved. Not to say that it won’t reoccur.
