Agents settings not sticking in 0.9.16.0
server-windows
#1
Hi All,
I was changing the Agent settings in the newest 0.9.16.0 PMS on a windows 2012 server. For some reason when you activate/disable the options within the agents, they don't show up unless you refresh the connection to the server.
Bug?
chaos
#2
Yep this is happening to me too, I thought that it was forgetting settings. But your right if you refresh then you can see your settings have stuck.
Version 0.9.16.3 PMS Linux
Super confusing. Happened to me on the TheTVDB agent configuration.
