All embedded subtitles (VOBSUBS) for Extras do not show when Direct Playing.
android-tv
fire-tv
#1
Client: Plex for Android 6.11.2
Plex Media Server 1.11.0.4633
@kinoCharlino
@"MovieFan.Plex"
If an Extra (e.g. /Behind The Scenes) is played back on the Nvidia shield in 'Original Quality' then the subtitles will not play; if the quality is changed to Automatic then the subtitles will show. This is a bug.
Media info of subtitle.
Format : VobSub
Codec ID : S_VOBSUB
Codec ID/Info : Picture based subtitle format used on DVDs
Language : English
Default : Yes
Forced : No
My subtitles are NOT compressed.
To allow you to reproduce the issue:
https://drive.google.com/file/d/1QpOYT6It3nGHrj_S6OQDkQhC2a5keFg2/view?usp=sharing
Best streaming device to minimize transcoding?
VOBSUBS stop showing; then plex app on shield tv will crash
#2
This is an issue with zlib compression applied to vobsub subtitles inside mkv container, I already reported this issue, see more here:
#3
http://forums.plex.tv/discussion/296437/bug-report-mi-box-plex-for-android-tv-wont-display-vobsub-subtitles-with-zlib-compression
That’s not my issue. You’ll notice my subs are not compressed. My issue is with extras.
#4
They should be compressed, check with mediainfo to see their status…
#5
They don’t have to be compressed. As I said this is a different issue. Yes, my first post had all that.
#6
Anyone? @kinoCharlino @“MovieFan.Plex”
#7
Anyone experience this?
#8
@“MovieFan.Plex” This is still an issue 5 months on. Here is a sample file that will allow you to reproduce the issue:
#9
That’s why I stopped using Plex and switched to another app/service.
#10
I am rather hoping that @“MovieFan.Plex” notices this time around.
#11
I doubt it, I’ve been waiting for months on very important issues I’ve reported, but plex devs don’t seem to care, I’m tired of waiting.
#12
@delacosta78 said:
I doubt it, I’ve been waiting for months on very important issues I’ve reported, but plex devs doesn’t seem to care, I’m tired of waiting.
That’s a horrid shame. What are you using now? I was thinking of giving ‘Plex for Kodi’ a try; I have an lifetime Emby pass too. I tend to prefer plex though so it’s a shame that subtitles still has these issues. I don’t usually push issues but subtitles are important in my home so I am going to try and stay on this one.
#13
I’m using the one where the forums really work for us, where they really hear their customers and try to fix the issues as soon as possible, I feel so satisfied by that more than the app itself, at least, the app is getting better in every release, and I’ve seen the issues I reported finally fixed faster than what I experienced in Plex.
#14
I thought plex missed this; they had not. @“MovieFan.Plex” sent me this:
No, I didn’t miss it. I provided the info to the developers. It was looked into but not deemed a priority. It’s still on the backlog.
Bummer.
#15
@Afullmark said:
Bummer.
Told you so…
#16
@delacosta78 said:
@Afullmark said:
Bummer.
Told you so…
Indeed you did. I’ve noticed you on the emby forums; how’s their Vobsub support? No inbuilt, out the box, SSL with them though.
#17
VobSub wasn’t supported until the recent beta update (1.5.73g) (I’m enrolled in the beta program which we can’t in Plex unless we’re a pass subscriber), I was having issues with other video codecs (reported by me) which are now fixed in the same update.
#18
@“MovieFan.Plex” have you confirmed this and filed as a bug yet?
#19
@“MovieFan.Plex” do you need anymore info regarding this issue or is it logged as an a confirmed issue?
