I don’t suppose this has any support for indie PPVs? Like ROH, PWG, Progress, NJPW, Evolve?
I really need something that does. I would gladly partner with someone who knows what they are doing on the technical side of things to make this happen.
@akkifokkusu . I’ve been looking a correct way to rename my WWE RAW/Smackdown/Wrestlemania/Survivor series. I want a main folder "WWE to appear on plex library, then sub folders “WWE RAW, WWE Smackdown. WWE Wrestlemania and so on.” I don’t know in which directory to put the wrestling.bundle, also I’d appreciate if you can give me step by step direction to do it correctly. I don’t want to experiment as I’m afraid I’d screw up whole settings and files in plex.
@Propellarhead9 said:
@whoispez said:
I don’t suppose this has any support for indie PPVs? Like ROH, PWG, Progress, NJPW, Evolve?I really need something that does. I would gladly partner with someone who knows what they are doing on the technical side of things to make this happen.
I’m working on something like this right now for myself, I’ll consider releasing it if I complete it.
I have a wrestling related question:
Currently I have a WWE library (movies) and was wanting to add folders such as: PPV, Raw, Smackdown, shoot interviews etc.
If I create new folders within this library, how do you add images to the folders?
