Alternate directory for Optimized files
server-windows
#1
My media is housed on a NAS, but I'd like to store the optimized versions of the files on a local hard drive on my Plex server. Is that possible? I can't find an option for it in the server config, and the directory option when optimizing a file is only the same directory where the file is housed, or the root directory on the NAS.
#2
Yes, this is possible.
Create a folder on your local hard drive for every library which has “optimizeable” videos.
Then add these folders to the libraries (with Add I mean literally adding them - additionally to the location on your NAS)
After you did that, you can choose, in which of the folders you added to the library the optimized files will be stored.
#3
Thank you!
#4
I know this is old but I have it set so the on deck is always optimized but no folder options are available besides "in folders". I added the option to the TV library which is where all of the deck items are but i understand why that wouldn't work also.
Is there any way for me to have the optimized in one folder?
#5
No, this is not possible. You must strictly separate movies and tv shows into separate folders.
This also applies to optimized versions.
If you must, you can use subfolders.
\optimized
\movies <-- add this folder to the movies library
\series <-- add this folder to the tv shows library
#6
\optimized
this looks like command line? can you enplane newbie here
#7
No, this is just meant to illustrate the folder hierachy.
Ìn this case are movies and series both subfolders of optimzed
#8
HI,
SO now I can choose where to save the optimised version each time I chose to optimise.
But when i ask for a sync directly from my ipad, I cannot get this option?
How to change the default optimised directory?
#9
Once the sync is done, the optimised copy only exists on your iPad.
What do you want to redirect?
