Anyone else have to play a video twice for it to start?
android-tv
fire-tv
#1
(Latest firestick, latest plex version as of May 11 2018). I press, plex plays maybe 5 seconds, then jumps back. I press play again and then it plays for real. This happened with one of the newer updates somewhere a few weeks ago, I think.
#2
Yes I have that issue too no idea what it is…
#3
I’m using the Nvidia Shield TV and have the same problem. It’s actually been happening to me for a while now.
#4
Same issue on both my Fire TV Gen 3 pendants. Haven’t checked to see if occurring on my Fire TV Gen 1 or my Roku TV
#5
Have the same issue on my latest Fire Stick. Plays for a second then if in playlist moves to the next video and plays fine or if stand alone video it asks if I want to replay the video as if it’s completed. Happens every single time I select a video to play. All are direct play.
#6
Yea. This seems to only be a issue for the first media file that is being played.
#7
Same issue
#8
same on firetv2, firetv3, fire stick.
#9
Same exact issue for me as well. I’m running the shield TV as well.
#10
Same here. Latest firestick and plex client from the Amazon store (which is not the latest available on the release page BTW). Also getting the crashes mid-playback that others are reporting and when hitting play to resume at that point I’ve also had the client just hang and not load the movie requiring that I exit back to the menu manually and try to restart it again.
#11
Yes, but not every time. I’ve watched 2 videos today and didn’t have the problem.
I have the Fire TV 2nd gen. Using it with wired Ethernet.
#12
Yes. It stalls when starting and I have to back out and restart the video in order for it to start buffering/playing. This is on Fire TV 3
#13
I’ve been having the same problem for good while on a SONY KD49XD8305. It always stops playing after a few seconds on the first try, then next try it works. Curiously, subtitles continue playing on that first try.
I’ve tried everything. Made sure I have the newest Android TV version and app version, I’ve reinstalled the app (and cleared all data), I’ve changed around settings on the server and in the app. Nothing makes a difference.
Please fix this.
#14
This has been happening to me as well. Fire TV 2nd Gen. This only started happening recently, within the last few months I believe. I recently purchased a Roku 4 and it does NOT happen on that device.
#15
Same problem here, happens on. FireTV stick (2nd gen) other devices are fine… Been happening a long time now, not sure when they’ll fix it?
The weird thing is, if I leave it sitting there frozen then back to menu it will show play progress that whole time (e.g. 3 minutes). So, it seems like server is still sending content and client just doesn’t display correctly.
#16
Same issue here. FireTV 2nd Gen and FireTV Stick 2nd Gen. Started about 2 months ago. Server and apps are all fully patched. Playback crashed after a few seconds but works fine the 2nd attempt. Definitely annoying.
#17
Yep, it is very annoying. Shield here.
#18
+1 nvidia shield
#19
Does it on shield, nexus player and our Bravia tv… for months now.
It’ll either show the circular buffer animation, so I have to leave the playback and start it again, or it’ll show the content for a second, then it looks like it’s playing in the progression bar, but obviously isn’t so I’ll have to restart the media again.
Also, jumps to the screen with the countdown to next episode on occasion, crashes when flying fast through recently added or whatever. Sometimes crashes or freezes when I use the jump back 10 seconds.
This seriously needs fixing. It’s nothing to do with the Oreo update because the bravia is on nougat and my shield was doing it on nougat while my nexus player has been on Oreo for ages.
More likely to do with the fact plex changed to exoplayer or something. But it’s been doing it for months I know that much at least.
#20
If you go back to version 6.12 it fixes it.
