Best agent for nividia sheild
server-nvidia-shield
#1
Hello all i just starte my nividia sheild and plex media server
Its have some problems finding the files and collection of movies with metadata Anyone Can recommend a good one it. I only see images
#2
The agents work the same on all server platforms.
Problems like you describe are usually the result of poor naming and/or embedded metadata. The fix for the second problem is simple; just move the "Local media assets" agent to the bottom in all agents in settings.
The fix for the second is to EXACTLY follow the naming guidelines:
https://plexapp.zendesk.com/hc/en-us/articles/200220687-Naming-Series-Based-TV-Shows
https://support.plex.tv/hc/en-us/articles/200381023-Naming-Movie-files
FileBot is your friend to help renaming if the task seems daunting.
