[BUG] Smart playlist and iOS sync loop (flac)
ios
#1
For the last month I have had problems syncing smart playlist (filter: rating more than 1, sorted by play count) to iOS. This would result in an FLAC conversion infinite loop on a particular track (01 - Giving Up the Ghost.flac). This resulted in my mobile data plan got drained, because the iOS app doesn't check connection switch states WIFI to 4G (i guess). I started the sync on WIFI and later switched to 4G. This actually drained my mobile data plan in one day. Devs says a possible fix should be out soon. Perfect!
Yesterday i tried again, since I installed the latest PMS. I noticed that it ones again did a loop on one specific FLAC track. I removed this track from the smart playlist, and the sync completed (finally).
When i add the track again and let it sync on iOS. It ones again starts the loop. This must be some kind of bug. I can play the specific track by itself on Plex for iOS. If PMS fails to convert a track, shouldn't it just exclude it or stop the conversion and return an error?
I cleared the Logs directory before testing. PMS and Plex for iOS logs attached. (est. time: 11:49)
PMS: 1.7.2.3878
Plex for iOS: 4.12.1
#2
Bump - anyone?
PMS: 1.7.3.3937
Plex for iOS: 4.13
#3
Bump ...
PMS: 1.7.4.4017
Plex for iOS: 4.14
#4
Bump ... more than one month old ...
#5
Grrrrr ... More than 4 months old and without any response. None of the bugs has been fixed. This is a joke! What does one have to do, to get anyone at Plex acknowledge this? ... This problem was first reported April 23.
PMS: 1.8.3.4235
Plex for iOS: 4.17
A simple response like "noted" would be acceptable!
#6
Bump! I did another test, and the same happens. FLAC sync conversion in a infinite loop.
Oct 07, 2017 11:16:13.864 [0x7f2313335700] DEBUG - Sync: packaging add at 10724553 for sync list 18777244, metadata item 3019: 10724553 > 10724547
Oct 07, 2017 11:16:13.875 [0x7f2313335700] WARN - Sync: embedded stream ID 2147483634 not found packaging transcoded sync list 18777244, metadata item 3019, media item 6918, part 54956
Oct 07, 2017 11:16:13.876 [0x7f2313335700] DEBUG - Sync: mismatch between processing and assembly for sync list 18777244, item 3019 media 6918, scheduling for reprocessing
Oct 07, 2017 11:16:13.876 [0x7f23197ff700] DEBUG - Cleaning directory for session b62204a8-9273-4283-9551-bd1e14741d3e (/share/CACHEDEV1_DATA/.tmp/Transcode/Sessions/plex-transcode-b62204a8-9273-4283-9551-bd1e14741d3e-34026693-b791-40e0-be5a-fcdbee2117c9)
Oct 07, 2017 11:16:13.876 [0x7f23197ff700] VERBOSE - [IDLE] Removing (1->0) work item transcoder - b62204a8-9273-4283-9551-bd1e14741d3e
Oct 07, 2017 11:16:13.876 [0x7f23197ff700] VERBOSE - [IDLE] Server is now idle
Specific this line:
#7
Bump ... anyone!?
