BugReport - thetvdb metarefresh causes CRITICAL error and doesn't get metadata
Server Version#: 1.18.9.2578-513b381af - in docker updated 3/31/2020 via plexpass
Player Version#: Version 4.30.2
I noticed the issue when the show’s icon was just a gray box. I went in and tried to refresh the metadata. Took a bit but it never finished and the icons for all shows went to gray.
com.plexapp.agents.thetvdb.log
2020-04-01 00:57:43,625 (7ff1e6ffd700) :  DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/series/278518/episodes?page=1'
2020-04-01 00:57:44,933 (7ff1e6ffd700) :  DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/series/278518/episodes?page=2'
2020-04-01 00:57:46,004 (7ff1e6ffd700) :  DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/series/278518/episodes?page=3'
2020-04-01 00:57:51,320 (7ff1e6ffd700) :  DEBUG (threadkit:244) - Parallel task set UpdateEpisodes ended
2020-04-01 00:57:51,324 (7ff1e6ffd700) :  CRITICAL (agentkit:1091) - Exception in the update function of agent named 'TheTVDB', called with guid 'com.plexapp.agents.thetvdb://278518?lang=en' (most recent call last):
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-513b381af/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/agentkit.py", line 1089, in _update
    agent.update(obj, media, lang, **kwargs)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-513b381af/TheTVDB.bundle/Contents/Code/__init__.py", line 1108, in update
    self.processExtras(xml, metadata.seasons[season_num], lang, ivaNormTitle)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-513b381af/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/threadkit.py", line 233, in _parallelize_decorator
    f(*args, **kwargs)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-513b381af/TheTVDB.bundle/Contents/Code/__init__.py", line 895, in UpdateEpisodes
    ordering = media.settings.get('showOrdering', 'aired') if media.settings else 'aired'
AttributeError: 'NoneType' object has no attribute 'settings'
2020-04-01 00:57:51,328 (7ff1e6ffd700) :  DEBUG (model:229) - Serializing to /config/Library/Application Support/Plex Media Server/Metadata/TV Shows/4/57e94b79735362818e8f89c72a66a0052026bbb.bundle/Contents/com.plexapp.agents.thetvdb/Info.xml
2020-04-01 00:57:51,332 (7ff1e6ffd700) :  DEBUG (runtime:88) - Sending packed state data (607 bytes)
2020-04-01 00:57:51,333 (7ff1e6ffd700) :  DEBUG (runtime:924) - Response: [200] str, 16 bytes
Did any part of the metadata come from another installation (Windows is a primary cause of such issues)
If not, can you please provide me show name information and I will attempt to recreate
No, everything has always been Linux based … it was converted to a docker container (image: plexinc/pms-docker:latest or image: plexinc/pms-docker:plexpass) ~3 years ago. It was recently (within the last 4 months) moved from one docker host (centos 7, 1 * intel i3, Drobo DAS) to a new docker host (centos 8 - 2 * xeon, internal SAS HW RAID). Users/groups and permissions were duplicated in the migration and mostly verified.
Those are the only significant changes… The show is The Walking Dead from TBS.
This one?
[chuck@lizum The Walking Dead.525]$ ls
Season 00/  Season 01/  Season 02/  Season 03/  Season 04/  Season 05/  Season 06/
[chuck@lizum The Walking Dead.526]$ ls *
Season 00:
The Walking Dead - S00E01 - Season 1 Sneak Peak.mkv                            The Walking Dead - S00E19 - Inside The Walking Dead- Chupacabra.mkv
The Walking Dead - S00E02 - The Making of The Walking Dead.mkv                 The Walking Dead - S00E20 - Inside The Walking Dead- Secrets.mkv
The Walking Dead - S00E03 - Torn Apart (1) A New Day.mkv                       The Walking Dead - S00E21 - Inside The Walking Dead- Pretty Much Dead Already.mkv
The Walking Dead - S00E04 - Torn Apart (2) Family Matters.mkv                  The Walking Dead - S00E22 - Inside The Walking Dead- Nebraska.mkv
The Walking Dead - S00E05 - Torn Apart (3) Domestic Violence.mkv               The Walking Dead - S00E23 - Inside The Walking Dead- Triggerfinger.mkv
The Walking Dead - S00E06 - Torn Apart (4) Neighborly Advice.mkv               The Walking Dead - S00E24 - Inside The Walking Dead- 18 Miles Out.mkv
The Walking Dead - S00E07 - Torn Apart (5) Step Mother.mkv                     The Walking Dead - S00E25 - Inside The Walking Dead- Judge, Jury, Executioner..mkv
The Walking Dead - S00E08 - Torn Apart (6) Everything Dies.mkv                 The Walking Dead - S00E26 - Inside The Walking Dead- Better Angels.mkv
The Walking Dead - S00E09 - Inside The Walking Dead- Days Gone By.mkv          The Walking Dead - S00E27 - Inside The Walking Dead- Beside the Dying Fire.mkv
The Walking Dead - S00E10 - Inside The Walking Dead- Guts.mkv                  The Walking Dead - S00E28 - Cold Storage- Hide and Seek.mkv
The Walking Dead - S00E11 - Inside The Walking Dead- Tell it to the Frogs.mkv  The Walking Dead - S00E29 - Cold Storage- Keys to the Kingdom.mkv
The Walking Dead - S00E12 - Inside The Walking Dead- Vatos.mkv                 The Walking Dead - S00E30 - Cold Storage- The Chosen Ones.mkv
The Walking Dead - S00E13 - Inside The Walking Dead- Wildfire.mkv              The Walking Dead - S00E31 - Cold Storage- Parting Shots.mkv
The Walking Dead - S00E14 - Inside The Walking Dead- TS-19.mkv                 The Walking Dead - S00E32 - The Oath- Alone.mkv
The Walking Dead - S00E15 - Inside The Walking Dead- What Lies Ahead.mkv       The Walking Dead - S00E33 - The Oath- Choice.mkv
The Walking Dead - S00E16 - Inside The Walking Dead- Bloodletting.mkv          The Walking Dead - S00E34 - The Oath- Bond.mkv
The Walking Dead - S00E17 - Inside The Walking Dead- Save the Last One.mkv     The Walking Dead - S00E35 - Inside The Walking Dead.mkv
The Walking Dead - S00E18 - Inside The Walking Dead- Cherokee Rose.mkv         The Walking Dead - S00E36 - Inside The Walking Dead- Walker University.mkv
Season 01:
The Walking Dead - S01E01 - Days Gone Bye.mkv  The Walking Dead - S01E03 - Tell It to the Frogs.mkv  The Walking Dead - S01E05 - Wildfire.mkv
The Walking Dead - S01E02 - Guts.mkv           The Walking Dead - S01E04 - Vatos.mkv                 The Walking Dead - S01E06 - TS-19.mkv
Yes, that’s it. Still not getting any metadata for me.
Have you “Plex Danced” the series?
Given everyone has the same metadata code, there are only a couple possibilities.
  1. File names ambiguous (embedded tags)
  2. Bad match in the database
  3. Networking.
I found the problem … Plex somehow had created a weird file (and was expecting a directory) in the metadata directory of the database. I deleted the file and refreshed the metadata and it came through.
... /Library/Application Support/Plex Media Server/Media/localhost/8
# ls fe793975450b89b65adbc6306d46721ca6dab4f.bundle
crwxrwxr-x .....
As far as I can tell there should never be a file here …
