Can not connect to my account (HTTP error 408)
plex-vr
#1
Trying to connect my Plex account on Oculus Go - it sits at “Signing In” for about a minute, then gives “HTTP Error Code 408” as the error message.
I am the primary account holder, have lifetime Plex Pass... server is up to date...
Not sure what else I can do??
Suggestions appreciated.
#2
Same thing with Plex on Mirage Solo :frowning:
#3
408 is a timeout message, you can try again later in case it was a transient server-side issue. Otherwise, is there anything special about your network security? Any issues signing into other apps?
#4
No issues with other apps on the headset. The network also has iOS, tvOS, Android, Roku, and macOS Plex clients running without issue.
As for the network security - it is an insanely complicated network at my parents house in the middle of nowhere. LTE network connection distributed between their house and four outbuildings, always-on VPN at the router w/ a static IP for 1/2 the network (anything that requires incoming connections) and split tunneling for 1/2 of the 1/2 :slight_smile:
That said, everything else works fine. Perhaps it /was/ transient and since all the other Plex devices were already authenticated, it will work the next time I try it. Just seemed super unusual…
