Can player controls be automatically hidden on video opening?
windows-store-app
#1
I've been curious about this for a while, but only really started to use the Windows 8.1 RT app again recently on my Surface RT and wanted to ask.
Basically, I like to shuffle seasons of shows quite a lot, and it gets a little awkward that every time one episode (or any play queue item, really) ends and a new one begins, the play control overlay (the skip previous / next buttons, play / pause button, and advanced playback controls when enabled) appears, and I have to tap the screen again to hide it.
Is there any way to configure my Surface or the Plex app so that tap is no longer necessary?
#2
I've tried to reproduce the issue, but the controls always disappear for me after a few seconds...
#3
Thanks for responding!
I tried reproducing the issue again, thinking I was just being impatient, and while the controls seem to fade (after ten seconds or more) when starting a new item, I have yet to see them disappear upon skipping to or starting a new item in a play Queue. I waited about five minutes after the new item started, and the controls were still visible.
#4
Thanks pombeirp, I'm not sure if I just wasn't updated to the most recent version or what, but my problem has now been resolved and the controls are hiding as expected. Hooray Surface RT? :D
#5
I know that it’s a very old topic but I had this problem.
To solve, I’ve done:
  • Open Plex
  • Swipe in the right side of screen (To show Windows Menu)
  • Open Settings menu
  • Open Interface option
  • Enable “Keyboard and remote control input”
Thank you!
