Cannot set country for second tuner to a different one than the first.
When I add a second tuner device and choose a different country for the EPG data for it, the resulting channel list shows me the channels on the second tuner but epg data from the country on the first tuner no matter which country I choose. Is this a bug?
For example:
Tuner 1 - Select UK, Plex asks me to maps UK channels to UK EPG channels.
Tuner 2 - Select Germany, Plex asks me to map German channels to UK EPG Channels.
that sounds like you need Multiple DVR’s which is not currently supported, there is a thread discussing it, but it has several major issues and I would not recommend trying.
Also looking to get this setup working.
Understood but I’m a sucker for trying stuff! Can you point me at the thread? Is it this one?
https://forums.plex.tv/discussion/273860/multiple-dvr-devices-hdhomerun-prime-and-connect-only-one-program-guide
