I have tried to install the latest updates, restart the service, clean up the database, and nothing changes this. Recordings are still occurring, but I can’t check any schedules, browse the guide, or add new recordings.
Yes. Refreshed the guide, emptied the trash, optimized the database, optimized bundles, restarted the server, logged in using incognito, tried logging in from a different server, and even reset my pinned libraries and setup again. There has been nothing I can do to change the message
Yes, it looks like the URL as the primary user is bad. If I copy the URL as a secondary user with PVR access, I can switch back to the primary user and paste the URL just fine.
I do not want to remove the DVR - there are quite a few shows set to record, and recreating that will be a nightmare.
Can someone post the guide url? Please replace your token with :left_bracket: token :right_bracket: so we keep things clean in this thread.
Thank you!
Running Version 1.18.2.2029
Got prompted to upgrade to 2058 but in middle of recording MTP so will have to wait. That was the whole reason I needed the guide. To try and watch it live through Plex.
Recreating the DVR should no longer lose your scheduled recordings.
However, if this is happening via Plex web, I recommend trying the following first. Go to Settings, then on the left under PLEX WEB click on Debug (click on Show Advanced if you don’t see Debug), and then click on Restore Defaults – please take note of the accompanying warning!
The above might help, though I’m not entirely sure.
I had done this before and gone through the preferences again when I logged back in. The first time it did nothing. I tried again today and it seems to have worked.
It looks to me like this is happening if I was previously in Browse … it’s OK if I was last in Recommended, Guide or DVR Schedule. Do you see the same thing?
