Hello,
i can’t chose the new ordre from fox with tvdb
https://www.thetvdb.com/series/american-dad
it’s possible to fix it?
thanks!
Hello,
thanks!
I’m sorry Plex only imports aired and DVD order.
Can’t you adjust by renaming your files?
Yes but he would have to manually alter any metadata for episodes that do not line up with whichever of the two available orders
ahhhh American Dad!
Choose your series and episode numbering carefully. what you think is Season 15 may in fact be Season 14
Well, with disney+ and fox… we have a new order that fit perfectly… i will do that manually…
one of the earlier seasons needs to be basically chopped in half from memory and then current releases are essentially a season out of sync and all the metadata will scrape perfectly for you.
