Can't find mismatch in very large Movies section.
server-mac
#1
Hey guys.
I added the movie, "the conjuring" but it seems to be stacked on top of a mismatch.
My problem is, I have over 1600 movies, and have no idea where that movie is.
How do I find my movie back and match it to the right title?
thanks.
p.s. I tried giving the movie the imdb tt number to make sure its matched correctly but it does not help.
#2
Take it out of scanning folder, run a scan, empty trash, and put it back in, named correctly.  "The Conjuring" is not named correctly.
#3
if it was stacked with another movie it would have a blue number 2 on the poster. in which case you can filter by duplicates and just view those. i would imagine there are not too many.
if it was ignored for some reason and not added to the Plex database at all then you can use dane22s Find Unmatched
I would move "the conjuring" out of your movie folder, update library, empty trash, clean bundles, put the file in a folder called "The Conjuring (2013)" and put that back in your movie folder and update library again
#4
okey, spend the last 45 min searching though the stacked movies. Found out I had more double files then I thought.
I did find the movie, with the right cover art but a wrong name.
Very strange.....
I was called "The warren files" editing the file manually.
