Can't log into the Plex website or claim my Server on my iMac (running OS 12.1)
It crashes once a day? Seemingly randomly or at specific times?
Yeah but usually only while im using Plex. Theres no specific time it happens. I’ve got it on just now & its OK so far.
Hi Bigwheel, im having insecure connections again & cant access plex.tv securely. Is there anything that can be permanently done to fix this? Do you want to see the logs? Thanks again.
Edit - Still insecure connections & Plex has been crashing all day & then freezes the full 2015 Shield. Need to wait ages until I get any functionality back.
@DWH30 I just reset it again. Still can’t figure out why you are crashing so much.
Just throwing this thought into the mix. Many VPN products are having issue with Monterey and it seems the only solution is to turn off split tunnelling completely even if you are not using it. Meaning having application exceptions and or Website exceptions, active.
One of the main reasons I have not migrated to MacOS 12 as yet.
@SE56 his server runs on a Shield
I see, just a bit mixed up with the Discussion heading from OP. So a different subject.
