Cant play vlc recordings.
android-mobile
#1
Hey,
does anyone has an Idea why i cant play this Video.
It was recorded with the VLC mediaplayer.
The Error message is "This server is not powerful enough to convert video."
Codec MPEG2VIDEO
Bitrate 5885 kbps
Ref Frames 1
Stream Identifier 480
Codec AC3
Channels 5.1
Bitrate 448 kbps
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Stream Identifier 128
Codec SRT
Language Deutsch
Codec SRT
Language English
Media
Duration 1:54:25
Bitrate 6333 kbps
Container MPEG
Part
Duration 1:54:25
File 123.mpg
Size 5.06 GB
Container MPEG
#2
Looks like your server is not powerful enough to trans-code on the fly that video.
I know my Android does not support AC3 so it has to convert to AAC.
So you gotta figure out why its trans-coding and go from there.
#3
Thanks for your answer,
I don't know if it helps but I have a synology DS 216play.
Also I have tested it on android, Windows 10(Edge, Windows store app and Firefox),Windows 7 Internet Explorer and on a Samsung smart TV. Maybe I should change from the android forum to general, but I don't know how to do it.
So if there isn't any other solution I probably have to convert the Videos. Any suggestions?
So far I have used Handbrake, but I am always struggling which codec for Audio/media and which Container to use.
Which are you using, or which would you recommend ?
I don't know much about codecs and which are popular. Mpeg-4 or H.264 and which Container ?
I would really appreciate your help :)
For example this video was easily playable on all my devices.
Media:
Width 1920
Duration 2:04:50
Video Profile high
Has 64bit Offsets 1
Web Optimized Yes
Video Frame Rate 24p
Container MP4
Aspect Ratio 2.35
Height 816
Bitrate 7184 kbps
Video Resolution 1080p
Part:
Size 6.26 GB
Duration 2:04:50
Video Profile high
Has 64bit Offsets 1
Web Optimized Yes
Container MP4
File 1234.m4v
Has Thumbnail 1
Language English:
Width 1920
Height 816
Bitrate 6243 kbps
Stream Identifier 1
Ref Frames 5
Profile high
Level 4.1
Frame Rate 23.976 fps
Chroma Subsampling 4:2:0
Bit Depth 8
Codec H264
Language English
Bitrate 384 kbps
Stream Identifier 4
Codec AC3
Channels 5.1
Language English
Codec SRT
Language Deutsch
Codec SRT
